Question about Polaroid 3211TLXB 32 in. LCD Television
TV comes on, has good sound but only a gray screen, no picture?
  • 11,361 Answers
Check to see if you get 12vdc at the T-CON board's fuse, it can be no signal from the main board also.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx
Posted on Aug 06, 2010
How do I fix a Panasonic Plasma TV that won't power on?
SOUNDS LIKE NEEDS POWER SUPPLY,CALL PANOSNIC CUSTOMER SUPPORT
Aug 12, 2015 | Panasonic Viera TH-50PZ85U Plasma TV
Picture goes black with gray fuzzy lines ~ 1/2" apart horizontal.
If your LCD TV or monitor has stopped working, or is displaying one of the following
symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can
examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life
of your monitor or TV by several years.
Take it to a repair shop.
Apr 05, 2014 | Sanyo DP50749 50 in. Plasma TV
My LG HD tv screen has a wide, gray band on either side of the picture
Try changing 'perspective' or screen ratio.
This may work, but could also stretch the picture too wide,
On my non-LG TV this is called 'aspect ratio' under the 'picture' menu.
Nov 20, 2017 | LG 42LB1DRA 42 in. LCD Television
Vizio E370VL Gray Screen no buttons work
This sounds like a problem with the main board in the TV. The main board is similar to the motherboard in a computer. You will need a professional to repair/order the parts. I would strongly recommend looking into purchasing a new TV rather than have this one repaired. In most cases the repair for a main board would be within a couple hundred dollars of a new set and often will not last very long.
Oct 19, 2012 | Vizio L37 Television
TV COMES ON NO PICTURE OR SOUND
If screen is gray glowing, the T-CON is bad or it is not getting the 12vdc from the logic board. You may have problem with logic board but do some voltage checking first.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Jun 28, 2010 | Vizio L37 Television
No picture, medium gray screen, sound volume will go up and down, but no "sound" just static.
Hey!
Dude there is a problem with the ( TV turner card ) some component is being over heated or has leak this card should be changed .
This card feeds the TFT with the voltage needed to glow and picture, sound, so should be checked.
Good luck
Nov 30, 2009 | Sony BRAVIA KDL-32S2010 32 in. LCD...
Panasonic CT-27L8SG displays gray screen and white hoizontal line
Is it still under warranty?
If not I would find a good TV Service Shop and have them check out the power supply as there more than likely a 'Capacitor' much like a battery that is going bad.
Blessings,
A/V Media Guy
Nov 22, 2009 | Panasonic CT-27SL14 27" TV
RCA F32665 Shows only gray screen, sound works.
You have a problem in the video circuit. Any video that comes into the set is not getting to the picture tube. The menus come from the system control microprocessor. This shows that the input at the picture tube itself is working. Also you system control is working. The signal would have to be traced through the set to find out where the loss is originating. Stargazer
Jun 14, 2007 | RCA F32665 32" TV
Polaroid 3211TLXB 32 in. LCD Television Logo
50 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
