Question about NAD T752 Receiver
Right Channel Not Working
The RIGHT front channel of my NAD T752 is not working properly. THere is a faint sound coming form the speaker, but that is all. I have run all normal diagnotics (switched speakers multiple times, changed modes, checked connections and re-wired the speaker connections. I have no idea what this may be. It was working fine recently and all of a sudden this. Please help is you can. Thanks.
  • 2 more comments
  • joebanks Apr 26, 2008
    I did. I am getting a faint sound.. like you get from a turntable with no speakers... just enough to know something is there.
  • joebanks Apr 27, 2008
    THanks, i have tried numerous speakers, i will take to a fixer-uper. thanks again.
  • rpaul May 11, 2008
    Same issue here! I opened the hood to see if anything was obviously wrong (fuse, etc.?), no luck. Not looking forward to the expediture of bringing it in for service.
  • knas Apr 05, 2009
    I have the exact same problem with one channel output, but can not see any obvious soldering problem.
    what have the faulty solderings looked like on your receivers?
    loose, cracked, oxidated?
    Could you please provide a picture or a sketch of the solderings to check?
    (The faulty output on my receiver is the front left.)
I have had the front, left and right channels go out over time. I have fixed all of them, and each time it has turned out to be a cold solder joint. While I love NAD and will continue to purchase there equipment, this generation is plagued with poor workmanship.
To fix the channel going out, I removed the top cover. Back cover and 2nd card from the left (looking at the receiver from the back side). This card handles all of the audio processing. I have found cold solder joints all over this board which has caused channels to suddenly go quite. I have never found a bad component. Also, I have cleaned the interconnect to be backplane (board that the audio processing board connects to) in the case of the center channel going quite.
If you have poor FM reception, the first board from the left (looking at the receiver from the back side) may have a cold solder joint on the coaxial connection for the FM antenna.
Posted on Jul 13, 2008
It's definately a electronical problem in the signal processing part of the reciever. I've had the same problem three times with my T752, on one or more channels.
Posted on Jun 09, 2008
  • 88 Answers
Di you test the balance button?
Posted on Apr 26, 2008
  • Sserpentio
    Sserpentio Apr 27, 2008
    i think that you try to inverse your speakers to see if the problem doesn't come to a bad speaker.
    otherwise you have a defficient component in your reciever and you have to go to a specialist to fix it, sorry for the bad new
Teac A R300 right speaker has s badly distorted sound after 20 minutes. When I turn it off nad turn it on again, Same problem after 20 minutes. Left channel working perfect.
Have you changed the speakers to see if it is a driver, or amplifier, issue? If it follows the speaker, get it reconed. If it follows the channel, look into that channel.
Aug 19, 2014 | Audio Players & Recorders
NAD 272 Channel drop out
well..this is one for the books. Can you tell me what the ratings are between the 252 and the 752 impedance matching wise? even though it might work sometimes, impedance matching can wreak havoc between mismatched amps.
what are you driving from the 752 into the 252?
Mar 10, 2008 | Audio Players & Recorders
My NAD C320 outputs a very low sound volume
Hi there I have a C340 that has similar problem, you must have bought this from ebay, lol.
Nad made a mistake on the C range, the pre - power link can be shorted out. if the pre is shorted out it takes out the pre amplifier stage, I have managed to get the right channel working, I will keep you informed what is the cause of the left channel. I have replaced the pre-amp IC and a couple of Jfets and transistors. Once I have repaired the Amp I could repaire yours if you like???
Apr 14, 2012 | NAD C320 2-Channel Amplifier
YAMAHA RXV 350 Right Speaker not Working
The amplifier for this channel is NOT working.
Feb 09, 2012 | Yamaha RXV-350 Receiver
YAMAHA RXV350 RIGHT CHANNEL NOT WORKING
Adding on again: I have interchanged speakers, if i connect any speaker on the right front channel it will not work. When I do a automated speaker test only right front channel does work.
Jan 26, 2012 | Yamaha RXV-350 Receiver
Hi there .. i have a nad t752 amplifier , i have just got it back from the nad repair shop , they have just reinstalled it , but now the front right speaker is much softer than the left front speaker ,,...
I hate to say this but the repair was not complete. If the sound levels are different with the balance in the middle, then either they missed a problem in one of the pre-amp stages, or they used an incorrect substitution for transistors in one or more stages. This unit should be brought back to complete the repair.
Any additional detail would require that I see the actual unit and poke around inside with test equipment.
Dan
Aug 08, 2010 | NAD T752 Receiver
Center channel sound output
Its not working correctly I have a few different types of center channels and they all have equal sound no matter how many speakers are in them. Connection in speaker box is bad or you may have a blown speaker
Dec 31, 2008 | Pioneer VSX-455 Receiver
NAD C370 Right channel distortion
Sounds like you have lost the power amp transistor(s) or IC for this channel.
Aug 29, 2008 | NAD C370 2-Channel Amplifier
Sound through one channel
Only the right channel had a sound,the left channel is mute, whatever adjustment you did and whatever balancing you done nothigs happen,even you interchange the speakers. The problem is in the power amp. The STK IC there is busted already, it's better to change it with a new one so the performance become normal again.
Jun 14, 2008 | NAD C372 Amplifier
The right channel on my NAD intergrated amplifier C320Bee no longer works.
if you did test for your cable and speaker and you find it fine-your problem will be in output stage of your amp and needs aid of service center.
Jun 11, 2008 | NAD C320 2-Channel Amplifier
NAD T752 Receiver Logo
644 people viewed this question
Top NAD Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a NAD Audio Player and Recorder Expert? Answer questions, earn points and help others
