Question about Xerox WorkCentre M20i All-In-One Laser Printer
Is there a fuse or a reset for the power? - Xerox WorkCentre M20i All-In-One Laser Printer
  • 239 Answers
No! there is no reset on this machine. If you have no power you need to replace the power supply.
Good luck.
Posted on Aug 10, 2010
  • jenn_n1 Aug 31, 2010
    Can you tell me where to get it from and how to replace it? Thanks
How do you reset
When you say a power reset button, do you mean the power button you turn on to power it up or a fuse? I doubt any coffee maker has a fuse any longer. If it does have a fuse, it's internal and you'll have to dismantle the coffee maker and find a replacement. You can find some fuses real cheap at Walmart.
Jul 22, 2014 | Black & Decker Spacemaker 10-Cup Coffee...
Resetting sc542 error
Fusing thermistor defective or out of
position
• Fusing lamp open
• Fusing thermostat open
• Fusing thermofuse open
• Power supply board defective
and for reset use prog 5-810 as follow
Resets all level-A service call conditions, such as fusing
errors. (To reset SC 547, switch the machine off/on.)
[0 = No / 1 = Yes]
• After selecting "1", press the Original Type key and the
' key (or OK key) at the same time to execute the
reset. If the reset is successful, the display shows
"Action completed." If the reset fails, the display shows
"Error!!!".
Apr 22, 2014 | Ricoh Aficio 1018D Copier
Intermatic ej500 fuse
Why did fuse blow?
Is timer under-rated for load on line?
Do wire size and breaker size match?
EJ500 is rated incandescent-only with maximum 500 watts, with temp range from 32 to 104 F, maximum distance 100' from load, and timer has 1 year warranty against defects.
http://waterheatertimer.org/Intermatic-timers-and-manuals.html
http://waterheatertimer.org/Color-codewire.html
Try resetting timer.
This will delete both programs and current time settings.
Hold down on-off button, and press and release reset button.
Keep holding on-off button until display changes, and 12:00 is flashing.
If timer will not reset, try changing battery.
Simple power outages, and blown fuses can cause power surge that will knock out timers. This is a common problem, and resetting timer can usually solve problem.
Timers like outdoor power pack, and analog plug-in timers do not have reset button and can easily fail after ordinary power outage.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Jul 29, 2012 | Intermatic EJ500C - Indoor Digital Wall...
Power doest not come on
Assuming ,that the outlet that you plugged your cd player in is working properlly.Try taking the cover to the cd player off. There should be a fuse, somewhere on the circuit board. Check to see if the fuse is blown.If it is replace the fuse, with the same type fuse. There should be writing on the metal part of the fuse,which will tell you the voltage,an amperage of the fuse. If it is blown, take the fuse to a Radio Shack store, they'll be able to match up the fuse for you. There might be more than one fuse, on the circuit board. Also,are you plugging the cd player into a G.F.I. outlet? The outlet could be tripped. If it is, hit the reset button.This should reset power to the outlet. There might be other outlet's that are wired into the G.F.I. If the G.F.I. is tripped then those outlet's won't work until you hit the reset button.
Jun 02, 2012 | Audio Players & Recorders
Toshiba Model 51H84. Power breaker tripped during a storm. Breaker reset, and TV will not power on. Is there a fuse? Is there a reset button of some sort? How should I proceed? Thanks.
Your TV has a fuse on power circuit board ( that is a standard part).You need to resemble your tv to get the fuse ( make sure to disconnect all power and antenna before doing this service). Usually any tvs use a clear glass cover on fuse ( you can see a small conductor inside the glass). Replace the fuse if the small conductor gets broken. If after the fuse replacement, you got no joy on tv, the receiver part could be get problem also ( due to storm attack) and need to repair / replacement.
I hope the storm only attack your TV fuse.
Good luck
Aug 02, 2011 | Televison & Video
I have a panasonic TH-C42HD18. Last night a fuse in my fuse box flipped so I lost power to the tv. I reset the fuse (in the fuse box) but now My tv will not turn on. Everything else plugged in to that...
If you have no power light on TV ,then you must have a blowed Fuse on the power supply board.
Check Fuse and check board for Bad Capacitors they will be vented or swollen on Top.
1000uf 16v 2200uf 10v 3300uf 10v.
Jun 02, 2011 | Panasonic TH-C42HD18 42 in. Plasma TV
Had to jump it, replaced power steering fuse but
You may have blown more than the power steering fuse (#1, 60A). You should check all the fuses in the underhood fuse box and you will probably find at least 1 more.
Also check the inside fuse box in the passenger side of the console.
Jan 08, 2010 | 2006 Chevrolet HHR
The power does not work. Is there a reset button.
If you have already reset the fuse, unplugging the unit for a minute or two should reset it. Inspect the internal for loose wires, wires with bad insulation or burnt parts which may have caused the fuse to trip.
Dec 13, 2009 | Televison & Video
Aficio Ricoh 350e - Warm up error (fuser)
Hi first you have to check the fusing unit and all give you how to reset the error enter the sp mode c 107 ca then use the sp np 5-801 then pres okouble-
shooting
SC542: Fusing temperature warming-up error
-Definition- [A]
The fusing temperature does not reach the fusing standby temperature within
125 seconds after the main power switch is turned on.
- Possible causes -·
Fusing thermistor defective or out of position
· Fusing lamp open
· Fusing thermofuse open
· BICU defective
· Power supply board defective
· Poor fusing unit connection
if the proplem not solved contact me ill give you more detales . thanks
May 22, 2008 | Ricoh Aficio 450 Copier
Error Message C3451
It is a fuser error.
Try resetting. To reset a Rank A error follow these steps:
1. Turn OFF the Main Power Switch.
2. Turn Main Power Switch ON while pressing the Utility/Counter key.
3. Touch [Trouble Reset].
4. Check to make sure that [OK] is displayed and the it has been reset.
5. After turning off the Main Power Switch, turn it on again more than 10 seconds after and check if the machine starts correctly.
If the error recurrs then do the following:
1 Check the Fusing Unit for correct installation (whether it is secured in position).
2 Check the Fusing Unit, PWB-M and PU1 for proper connection and correct or change as necessary.
3 Change Fusing Unit
4 Change PWB-M
5 Change PU1
Oct 02, 2007 | Konica Minolta bizhub C250 All-In-One...
Xerox WorkCentre M20i All-In-One Laser Printer Logo
144 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Philip Hughes
docukaaf
Level 1 Expert
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
