Question about Kohler CH25 PA-CH730-0040 Command Gasoline Engine
Need torque specs for oil pan - Kohler CH25 PA-CH730-0040 Command Gasoline Engine
  • 252 Answers
Here is website for kohler
http://www.kohlerplus.com/main_frame.asp
select command pro twin
then select tp2428c service manual
it has all the details you need
cheers hope it helps
paul
Posted on Aug 06, 2010
98 jeep wrangler tj 4.0 oil pan bolt pattern or layout. An torch specs
Bobby, oil pan bolt torques for 4.0 Wrangler. Oil Pan Bolts 1/4 84 in-lbs Oil Pan Bolts 5/16 132 in-lbs As far as sequence, see last link, start in center, criss cross pattern tighten snug all, then repeat to torque spec.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Oil Pan Gasket leaking
http://jeephorizons.com/tech/99_40l_torque_specs.html
98 jeep 4 0 oil pan bolt torque sequence specs Google Search
May 21, 2016 | Jeep Cars & Trucks
How to remove oil pan
jack it up, drain oil from drain plug on oil pan when drained remove and replace oil filter also. remove the pan bolts pull off pan and gasket.put new oil pan gasket on if needed.when oil pan bolts are back in, screw them in hand tight, then torque them down to specs and alter nate the tightening so it wont damage pan seal. any auto parts store can tell you the torque on the bolts for your car. good day!
Mar 31, 2014 | 1999 Chevrolet Venture
Need torque specs for 96 yukon 5.7 liter
Here's a link to the oil pan removal guide with pan bolt torque specs.
Jan 13, 2013 | 1996 GMC Yukon
What's is the torque specs for a 2002 se Pontic
90 inch pounds or 8 foot pounds. Good luck. Scott
Aug 29, 2011 | 2002 GMC Savana
Need torque specs for oil pan bolts
torque specs for these bolts can be found in a Haynes or Chilton manual availiable from your local parts store, or maybe at your local library, however these bolts are usually no more than 14 ft pounds, unlike cylinder head bolts, the bolts do not need to have any stretch factor to hold the oil pan gasket in place or sealed.
May 17, 2009 | 1997 Ford Ranger SuperCab
1999 Saab 9-5 oil pan torque spec
they should be torqued with a 3/8 torque ratchet to 30 inch pounds.
Mar 06, 2009 | 1999 Saab 9-5
Kohler CH25 PA-CH730-0040 Command Gasoline Engine Logo
309 people viewed this question
Top Kohler Electrical Supplies Experts
John Trevino
Wayne McNeil
Craig Butler
Craig Butler
Are you a Kohler Electrical Supply Expert? Answer questions, earn points and help others
