Question about Xerox DocuColor 12 Color Copier
DARK MASK UNDER IMAGE PRINT - Xerox DocuColor 12 Color Copier
  • 8 Answers
Check connection cable between fairy & DC MACHINE Its not connected properly
Posted on Aug 23, 2010
Ir 3300 the print out is dark
keep the develop setting between -30 to +30.If the image is too dark then chck the toner you are using as in most case it is the culprit.
Apr 19, 2012 | Office Equipment & Supplies
The printer is printing mirror image which is upside down
You give scant information on your printer, listed under Operating System problem ... so this is a shot in the dark.
Open your printers Properties. Look for a "print mirror image" feature. Turn it off. I would reboot and then try to print. You may choose to select "print test page" to see if the problem is resolved.
Thanks for your question at FixYa.com
Feb 03, 2011 | Computers & Internet
Konika Minolta Copier prints half dark pages
If it is only causing an image problem when you copy and not when you print, then there is something wrong with the optics under the glass. Check and see if you have any mirrors out of place or if the scanner looks crooked. If you have the machine set up to scan try and scan to SMB or email to see if it still has the problem. If everything looks correct under the glass and scans to SMB and email look bad like the copies, you may have a bad CCD assembly, or a bad board.
May 10, 2010 | Konica Minolta Office Equipment & Supplies
Print quality: dark faded, but continuous
Open top cover and remove toner, shake toner cartridge and try a test print. IF image good then problem is low toner level in cartridge.
Apr 01, 2010 | HP LaserJet 4 plus Printer
How to mix two images ? specially at border of picture.
1. Open the first image.
2. Open the image you want to merge or mix with the first image or border.
3. Press Ctrl + A to select the entire image.
4. Press Ctrl + C to copy the selected image.
5. Click in the title bar of the image you opened first.
6. Press Ctrl + V to paste the second image over the first image.
7. If the Layer window is not displayed press theF7 function on your keyboard.
8. Make sure the top layer is highlighted or click on the layer to highlight it.
You should see the border around the image. If you want to hide part of the top image at the bottom lower left of the layer window you will see rectangle with circle which displays add layer mask when you hover the mouse cursor over it. Hold the Alt key and click on the Add Layer Mask Icon. This will hide the top image until you select the brush with a white color and paint the layer mask layer. The Layer Mask is the black rectangle next to the layer image which must have the white rectangle around it when painting with the brush. If you do not see the top image mixing with the bottom image make sure the black rectangle is selected or click on the black rectangle to select it. If the layered image is selected you will be painting it white and alter the image. If you revile part of the image when painting the mask you can hide it by changing the brush color to black and painting the reviled layer to hide it again. Layer masks are very powerful which you will need to look up in the help files for more information to gain full power of the tool.
Jan 20, 2010 | Adobe Photoshop 7.0 for PC
The photos are coming our dark
Hi
Check the Following link for Enhance Image
HP ENHANCE Image
  1. From the application you are printing from, click Print , and then Properties . The Print Properties screen opens.
  2. Click the Paper/Quality tab.
  3. Select dpi (light to dark )
  4. Click OK .
Jan 04, 2010 | HP Photosmart 8250 InkJet Printer
Printing dark tshirt transfers - can't override the flipped image
Hello I think I can help you. I Would not use T shirt transfer when you make up your print I would select poster print or any other form that does not automatically reverse the image. The reason your software is designed to do this is on the regular transfer paper your laying the image down on the shirt, so for it to come out right it has to be reversed. With the dark T shirt transfer paper your peeling off the backing and putting the image face up on the T Shirt.
Dec 23, 2008 | Canon i80 InkJet Printer
Please help me. I haven't printed on a CD with my HP Photosmart D5160 in a while and I either can't remember how to do it, or it doesn't like the new laptop.
I spent a week figuring this answer out. First Do not use the supplied software from HP for this, unless simple text is okay for you. I personally found the software to try to do everything, but nothing well. If you have even a modest image application: Gimp, Photoshop, etc, create a new image at 4.5 inches x 4.5 inches. Set the ppi to 150 at least, 300 for High Quality and create you 'label' there, then go to print.
1. in print dialog box choose 'Preferences'
2. then choose 'printing shortcuts'
3. then choose 'print on CD/DVD' (DVD icon)
(confirm in papersize on right that you are printing on a cd/dvd)
4Then pull down your CD/DVD tray flap on the HP printer and load up a CD to print on. Align it to the arrows, then press print.
As long as the image is 4.5" x 4.5" it will fill the DVD perfectly --especially if you download a 'Mask' template from any printer --which you could google to find one, but it is just to give you an Idea of your 'safe print' zones, and will really come in handy for high quality labels-- don't for get to turn off that 'mask' just before saving--if it's black, or better yet, make it white, then when you save the final image it will create a beautiful white circular edge on the image so that you can better preview and so that you won't waste ink!
Dec 14, 2008 | HP Photosmart D5160 InkJet Printer
Image problems
Sounds like your PCU is worn out. Try replacing it and see how you get on.
Jan 10, 2008 | Epson Aculaser C1100 Printer
Xerox DocuColor 12 Color Copier Logo
35 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Philip Hughes
docukaaf
Level 1 Expert
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
