Question about Pool & Spa
Ampac pulsar series. micro spa controller. mod no 20835p s/n 36018 mode pump and blow lights all flashing . does it need new pcb board.
5 Suggested Answers
  • 5 Answers
SOURCE: I have Jandy RS4 system with 4-button poolside
Pull the cover off the control panel. You will probably find a button which would be accessible from outside the panel with a paper clip or pencil but is unlabeled. On the board itself by the button, in small letters it should say "reset". Push the button and see what happens.
Posted on Oct 09, 2009
  • 11 Answers
SOURCE: I have a Hayward H series spa/pool heater. It will not light.
IF stands for ignition failure, one possible cause is that the two sparker prongs are not spaced properly, i have seen this before several times. The correct distance for them to be spaced apart is the width of two quarters side by side... not like this....OO, the other way so the are flat. To access that you have to take out the heat exchanger, which requires unhooking high limit switches in the back, unhooking the pressure switch, thermostat wire, and plumbing...just remember where everything goes. Before you do that though check this simple thing...there are a number of brass orifices that shout gas to the burners, use a 7/16 wrench to take off the one that is to the extreme left, which is on the igniter side of the heater, inspect the orifice to see if there is blockage, like a spider web or something. If it is blocked, clean it out and also look down the burner itself to see if it is free of blockage. And because we all make simple mistakes.......make sure the gas is on.
Posted on Jan 08, 2009
  • 246 Answers
SOURCE: Hayward Colorlogic Light flashes like a strobe
OK I GUESS U HAVE A AUTHOMATIC CONTROL CHECK T RELAY FOR 120 V THAN CHECK FOR V AT THE JUCTION BOX IF V LIGHT MUST BE REPLACE.
Posted on Sep 17, 2009
  • 760 Answers
SOURCE: pool heater is not working properly
So I assume you have pressed the button by pool to select the pool thermostat? If this doesn't work sounds like another mother board problem, or try powering down the unit a few minutes then restart. IF you haven't pressed the pool button, the read this: The heater comes factory set at 78° F. for the pool mode and 100° F. for the spa mode. If it's in spa mode it's trying to get to 100F. Using the up and down arrows,you can set the thermostats to a minimum temperature of 65° F., or a maximum of 104° F. If you desire to heat only one
body of water, the thermostat is capable of an off mode. As an example, if you only wish to heat the pool and not the spa simply depress and hold the spa down arrow, and the thermostat will lower its setting to 65° F. then go to an off mode. Here is a link to your manual :http://www.pentairpool.com/pdfs/MasterTempOM.pdf
Posted on Jul 08, 2010
How do you set up the timer for heating a ampac pulsar series spa?
http://waterheatertimer.org/How-to-set-timers.html
Link above has instruction resources for analog and digital timer modules.
Repost question and describe timer in detail
Gene
Water Heater Timers Save Money
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Jan 04, 2015 | Hardware & Accessories
Why does my pump want to shut off after I enable the heater?
before turning to spa dis able pool heat then try if same happens need new PCB control board
Jun 01, 2014 | Zodiac Jandy AquaLink RS All Button Wired...
Freeze protect drops to -20 degrees
need new air temp sensor trade on board with water temp see if it reads different if not need new PCB board
Feb 06, 2014 | Jandy Aqualink - Rs24 One Touch Pool / Spa...
Turn table does not turn when heating. Interior light does not come on during cooking, works fine when door is opens.
some microwave is have PCB control if pcs is shorted some parts light bult,fan or syncronus motor is on mode we need to replace the pcb but some problem is only is micro switch,if mocro swict is rusty or corroded that the time not working the turn table,but you said every time open the door the ligth is ok,if the turn table also running during open door have problem in your pcb board that we need for replacement,but check the price of parts and make it desicion if you want to repair or buy a new one if your unit is very old.
Dec 28, 2010 | Microwave Ovens
How to set timer on my hottub
Hi, we have an ampac pulsar series timer on our spa. We are not sure how to set it, as we bought it second hand and have no booklets. Can you help?
Mar 21, 2010 | Hayward H Series Pool & Spa Heater 400k...
"Jacuzzi j-400 series" hot tub- F1 code flashes on control panel
Your circulation pump isn't working you should see the flow awitch closing if you have the visible model and hear the pump running.. If its the smaller circulation pump model it needs replacing
May 18, 2009 | Jacuzzi Bath Nova H530 917 Black Soaking...
Pool & Spa Logo
903 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
