Question about Refrigerators
It has stooped cooling - Refrigerators
  • 1 more comment
  • patrickbutto Aug 05, 2010
    This is for Antares vending machine
    It is probable that refrigerant needs to be added how do I do that?
  • patrickbutto Aug 06, 2010
    This problem concerns the Antares vending machine. I will look for the serial number and model number later today with the hope that I can get a repair manual or more details on the trouble shooting and repair.
  • 17,970 Answers
The first thing to understand is that all the cooling in a conventional frost free refrigerator usually originates in the freezer compartment, just a small portion of that air is circulated through the fridge compartment to cool there. (Technically the opposite is true. Warm air is circulated into the freezer compartment where its heat is removed by the refrigeration process leaving behind cooled air.) In any case, if that air flow is hampered in any way, cooling problems will result.
The second thing you need to know is that the compressor (large black dome at the rear of the refrigerator) provides all the cooling ability for the whole appliance. It has to be running in order for any cooling to take place. As long as the compressor is running, the possibilities listed below will need to be checked one at a time. If the compressor is not running or continually trying to start but failing within seconds, clicking and then shutting down, someone will need to look into why. That alone is likely the cause of your cooling problems.
Keep in mind that refrigeration compressors will stop cooling soft drink and food vending machines like the Antares vending machines, once their fins become clogged. There are lots of things that can cause cooling problems. One of the most common causes of poor cooling in a frost free refrigerator is a defrost system failure.
Defrost timers frequently fail and stop keeping time. If this happens during the cooling mode, it will allow excessive frost to accumulate on the cooling coil reducing air flow, eventually stopping it altogether as it never switches into defrost mode to melt it. The timer can also stick in the defrost mode and never advance into the cooling cycle again. The defrost termination thermostat opens the circuit to the heater when it senses a set temperature. This set temperature is usually high enough that the cooling coil should be totally defrosted by then. If this device fails and remains permanently open, the heater would never get power to defrost the evaporator.
If the defrost termination thermostat contacts short out, it will allow the defrost heater to stay on as long as the timer is in the defrost mode. A symptom of that is usually greatly fluctuating temperatures in the freezer compartment possibly causing thawing and re-freezing of food stuffs.
Other possibilities are the condenser (hot part), air flow, air damper or drain problems, you neede to check one by one to determine excalty where is the wrong.
Tell us news.
Posted on Aug 06, 2010
  • 776 Answers
As you have not provided me the make and model no. of your refrigerator to start with I am providing you general tips to resolve the issue:
In your case the problem could be with the basic electrical controls and also a possiblity of boost of refrigerant, as that is one thing that helps with the overall cooling. A big possibility that you may have dirty condenser coils, a door that doesn’t seal tightly, or a defective temperature control.
1) Check the cold control. Be sure it is set to “cold.” Normally, the temperature inside the refrigerator should be about 37 degrees F.
2) Listen for the freezer fan inside the freezer. When the freezer fan is running, it means the defrost timer and the cold control in the refrigerator are both set to cool.
3) Listen for the compressor fan (which will also tell you where the compressor is located—typically behind or beneath the refrigerator). When the freezer fan is operating, the compressor fan should also be working (most of the time).
4) If one of the fans is not working or the compressor is off, the refrigerator will offer very little cooling or none at all.
Also check the article for furter details:
http://www.repairclinic.com/Refrigerator-Troubleshooting
Posted on Aug 05, 2010
  • 6,784 Answers
If you are not hearing the compressor cycle on and off in intervals and there is no air flow present inside the unit, this will confirm that there has been a severe malfunction within the units assembly. You will need to check the following areas for faults:
1. Compressor- Make sure this unit is functioning. if it is not cycling as designed, this will be the culprit. If it is cycling but very hot to the touch when operating, check the condenser coils for debris and clean them if necessary.
2. Compressor start relay - This is the main on/off switch that is attached to the side of the compressor. This relay, when energized by the main control board, starts the compressor. if the relay has failed, it will not start the compressor, thus, rendering the unit inoperable. Pull the relay off and shack it. If it rattles, replace it.
3. Evaporator fan - This is a very important part of the evaporator core. This is the principal air mover of the unit. If this fan fails, the inside freezer and refrigerator will not cool, at all. You will need to remove all the freezer shelves and content to access this unit. It is concealed behind a panel inside the back section of the freezer compartment. Once the concealment panel is removed, you will expose the core and fan. the fan can be tested with a multimeter for proper continuity. You can also jump the terminals with a jumper wire to see if it is still in working order. An external power source will be needed for this test. if the fan fails the test, replace the fan motor.
4. Condenser fan - This is also a very important fan. This fan is mounted near the condenser coils and can fail. You can test it in the same manner as the evaporator fan. replace the condenser fan if it proves to be damaged.
5. Main PCB(Printed Circuit Board)- This is basically your main power controller. This board routes power to all the fans and compressor unit located in the assembly. it also routes power to the lights and ice maker/dispenser, as well. This will be the most expensive repair, in this case. If all the above areas prove to be functional, the main PCB will be the culprit. You can easily locate this board. It is usually mounted on a bracket, near the compressor platform, or behind a concealment panel on the rear of the unit. Once you have gained access, visibly, inspect the board for burn markings at the relay mounts and jumpers. check the entire circuit board for discolorations like brown marks or black burn marks at the plug-in connectors. If this refrigerator is totally dead, this will be the cause.
6. Monitoring thermostats - These are located in each compartment. Replace each thermostat if all the other areas check out ok.
7. Condenser coils- The condenser coils dissipate heat. If dust and debris accumulate around the coils, your refrigerator may not be able to cool properly, it may run continuously or it may stop completely as a result of an overheated compressor. You should clean rear-mounted coils once a year. Unplug the refrigerator before cleaning. Refrigerators are heavy, never tip one forward or backward. Never attempt to move a refrigerator without an assistant. Vacuum or brush the coils. If coils have a filmy build-up, use warm soapy water to clean them. Take care not to spill or drip water onto the components of the refrigerator.You should clean floor level coils at least twice a year. Unplug the refrigerator before cleaning. Vacuum or brush the coils. Remove the grill from the front of the refrigerator and use a vacuum with a wand attachment to remove any dust and debris. The grill should snap off and on. Pull firmly toward you and possibly upward to remove the grill. If it does not come off with a modest effort, check for screws or retaining clips that may hold it in place.
You will find the culprit in one or all of the areas stated above.
  • NOTE_ I will need your entire model number, if possible. This will allow me to post the appropriate service manual that will help you with the component accessing and other testing procedures, as well.
  • Michael Masters
    Michael Masters Aug 06, 2010
    OK, you will need to contact your local vending contractor for the proper recharging procedure. It is recommend to allow a certified refrigerant tech to recharge this type of unit. It cannot be done by the owner, due to the fact that, you will not be able to purchase the refrigerant without a certificate.
My car stoopped responding to the gas and started smoking.
Check the dipstick and see if it looks milky, sounds like you may have a cracked head or blown head gasket. good luck
Nov 07, 2013 | 1996 Oldsmobile Achieva
I have a TH-M50HD18 PANASONIC PLASMA (18 months old) that becomes extremely hot to the touch after being on for only 30 minutes. (So hot that everyone I have asked to touch it for their opinion, jump back...
Check whether the cooling fans have stooped. Might be. If you wish to get more details about the positions of cooling fans inside, check the site linked here. http://electronicshelponline.blogspot.com/ It has disassembly procedure to this TV, which will describe all about it.
Pull up previous posts or type in the brand name and model number to of your set, to its search box, and press 'Enter' or view it in Mosaic / Timeslide option.
Aug 25, 2013 | Panasonic TH-50PHD3U 50 in. Television
My GTA San Andreas shut down autimatically while um playing that giving a message "Gta San Andreas ha stooped working ...any solution????????
You can try running it in Compatibilty mode for earlier versions of Windows and as an administrator.
Feb 03, 2013 | Computers & Internet
My cooling fan stooped working ,my a/c stopped working and i checked all the fuses that are related to that circuit. 2006 crown victoria taxi package. all started off when you turn the key ,and the...
check your vlcm-variable load control module, located in front of the radiator (has fins, and has a large harness attached to it)-the harness may need to be tightened or the module itself may be bad-before to replace it swap relays for the AC with the ABS to see if it is just a bad relay.
Sep 12, 2011 | 2006 Ford Crown Victoria
My maytag stooped cooling and does not sound like it is running
Normally we have seen two issues.In one instance the water feed tube or trough stooped the flow of water to the ice maker and this produce a small transient water leak initially and then it stopped working and leaking eventually as the blocked tube did not thaw.
The other issue was ice in the ice maker that lodged in the blades of the ejector and prevented ice production.
Thanks for contacting Fixya.
Nov 03, 2009 | Maytag SkyBox MBV1976A Beverage Dispenser
Jl w3 stopped working
Take an OHM meter and measure the resistance on both the positive and negitive leads. It should read 2, 4, or 6 OHMS. This depends on the model either a D2, D4, or D6. If you read that reading correctly then see if there is a capacitor located on the the cone itself or in that area. If it is not visible then that would mean that it is located inside of the magnent area.
Mar 15, 2009 | Jl Audio 10W3v2 Car Subwoofer
How do I turn off the freezer section on a fridge freezer?
Unfortunately you can't. Both the fridge and freezer sections are cooled by the same compressor. You can't just have one without the other!
Matt
Apr 16, 2008 | Freezers
My Sharp Notebook PC GP10-CM screen has suddenly stooped working. What can I do to fix this?
can u hear the sound of the processor, if u can i'm afraid you will have to take it to the nearest repair shop.
Apr 07, 2008 | Computers & Internet
Refrigerators Logo
67 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
