Poor brightness on TV
Once had a great picture, now very dark even with brightness all the way up.
  • 4 more comments
  • ElPason Apr 27, 2008
    This set is from yr. 2000. I know there are some boards ( 2 or 3 ) that plug in like on a computer. Could this be one of the problems. If so, how do I find out which one it is.
    The Panasonic model # for this set is Pt-51SX60.
    The Panasonic model # is PT-51SX60. Hope this helps!
    Is there any instructions on how to polish the mirrors or replacement of the coolant?
    Slinteriors, thanks for all the information. The link was very informative. I'm a bit of a klutz so I might just have the process done by someone who knows what they are doing. At least I know what the problem is and can relate it to the service man.
  • Anonymous Apr 29, 2008
    I accidentally broke the rear projection mirror, can this be replaced?
    Could I have a local glass company cut the same size and thickness
    material (mirror) or is this some special "mirror" material? Does
    anyone have any idea or suggestion?
  • 8,617 Answers
Try polishing the mirror and CRT lenses. If that doesnt help you may need to change the coolant in the CRTs. If your set is a DLP you may need a new lamp.
Posted on Apr 26, 2008
  • 1 more comment
  • Sonny Berry
    Sonny Berry Apr 27, 2008
    need the model number in order to really be able to offer any suggestions
  • Sonny Berry
    your problem is with the mirror being dull or the coolant needing replacement
  • Sonny Berry
    the mirroe has to be polished by removing the frony screen or just reaching up from the rear panel. The rear panel takes alittle strecthing but is do able. Heres a link that will give info on coolant changing.
    http://www.tv-forums.com/forum/TV_Equipm...
Hi Guys, I have a JVC 32T55EKS TV & the picture is overly dark. When the picture goes through the set-top box the picture gets even darker. The brightness is turned up fully & I have accessed the...
U turn on the contrast level to the max,if still not watchable,tv cathoray tube is dying,radiaton is disappearing.Time to buy another tv.
Feb 14, 2011 | JVC AV-27230 27" TV
The picture is very dark
Unfortunately, there is no easy fix for this. If it were a rear projection TV, I'd suggest a new bulb. Even on a Plasma there are things that can be done. But on a CRT, the repair for a dark screen usually costs more than replacing it.
Sep 20, 2007 | JVC AV-32F702 32" TV
I have a CSC35313 tv. When you first turn it on, the picture is great. After a while, it starts getting a grayish haze over it until you can barely see the picture. Then every once in a while, the haze...
Yes,This problems is easy to fix.U know how to solders?Take the tv aparts.Resolders the video board holes socket that connect the video board to crt tube.
Feb 25, 2010 | Televison & Video
Picture getting dark
My jvc 27" tv was so dark I could hardly see any night scenes, even with the bright all the way on. If you push the sleep button, let go, then hold down the video and display (together), the service menu will come on. Scroll down to #7 (too dark) and adjust the brightness there. Works immediately. Good luck.
Nov 29, 2008 | JVC AV-27530 27" TV
PS2 Picture Problem
Hi MG86,
Most PS2 games are dark and auto brightness controls will casue your LCD tv to brighten up automatically in response the dark video coming from PS2 games. I suggest you get into the menu settings of your TV and find a setting that will shut off the auto picture controls.
Nov 23, 2007 | Sony PlayStation 2 (PS2) Console
JVC AV27320 Screen too dark
Check the lumans circuit. may be jungle IC
Nov 02, 2007 | Samsung HC-P4241W 42" Rear Projection...
Darks too dark
try to open your tv and you can find the flyback ,in flyback you can see the screen and focus to adjust.use and try to rotate the screen,it control the brightness of your unit
Oct 15, 2007 | Toshiba 32AF43 32" TV
Dark picture
sony had a recall on this set see if this is one of yours
http://esupport.sony.com/perl/news-item.pl?news_id=24
Oct 01, 2007 | Sony KP-57HW40 57" Rear Projection...
Picture is very dark
Is there a simple fix for this, yes The picture is very dark it is mostly due to 1 power supply output is low. 2 voltage on crt g2 pin is low. 3 video output supply is low. 4 some components in luminance section might be defective or loose. 5 finally crt getting weak but as you have bought in 2004 so possibility is rear. good luck
hi solution #2 was correct. the adjustment knobs r on what's called the "flyback" i adjusted the bottom knob and the difference was from "night to day" !!!
Oct 12, 2006 | JVC AV-27230 27" TV
Televison & Video Logo
107 people viewed this question
Top Televison & Video Experts
Electro Med Services...
