Question about Vacuums
The ceiling fan does not shut off wire colors: blue,black,gray,white
  • 43,501 Answers
If the fan will not shut off it is most likely not a wiring problem, but a problem with the switch not working properly...
the switch is stuck in the on position even though it may sound like it is working...
use an ohm meter to check the switch out...
heatman101
Posted on Aug 05, 2010
I need to know how to hook the wires up to the start switch. There are two wires from the external cord and two wires from the internal cord.
white wire to neutral black wire to hot if you post colors I could help you red ,orange, black,pink, blue, or violet are usually hot guessing a striped wire is usually neutral please post colors
Apr 14, 2013 | Dyson DC14 All floors Bagless Upright...
The light on a fan is flickering. It doesn't appear to be the light bulbs. This fan has a remote control and it controls the fan OK and turns the light on and off but it flickers. What could be...
Try changing or testing the batteries in the remote or take the remote out of the fans range. See if this stops the flickering. It can also be the individual bulb. Sometimes the monofillament wires become loosened. It won't hurt the fan to use a broken bulb but it will shorten the life of the bulb. They do get the daylights shook out of them! If all the bulbs flicker it can be the twist connects. These are located under the ceiling plate cover. To check, shut off the fan or turn off the braker switch to make sure you don't get a shock (but I really doubt it). Remove the face plate ceiling screws to expose the wiring. There should be a black and a red cap that holds wires together. Black is ground red is power. One at a time hold the wires of the black cap with one hand and give the cap a gentle clockwise twist with your other hand to see if they need tightening. Repeat with the other colored cap. Push the wires back up inside the housing if needed and replace the cover.
These are the simpelist things to try before calling an expert. I hope this helps?
Sep 22, 2011 | Vacuums
I have a hunter with 3 wires black white green how do I wire it to a three wire cable black red white ground the fan also has a light and remote but remote is Brocken want to use it with no remote model...
Black to Black - White to White, Green to Green (copper). Put a wire nut on the red wire.
The Black is suppose to run the light (or the fan) while the Red is suppse to run the fan (or light). The White is common and the ground is ... well the ground.
If you have a light kit on the fan, you can control the light and the fan separately ... or you can run them together.
Let me know how this comes out ...
Thanks for your question @ FixYa.com
Jun 29, 2011 | Vacuums
I am tiring to install a GE touch auto shut-off timer, I have 2 wires in the wall 1 black & 1 white, the switch has 4 wires (1 green[ground?], 1 blue, 1 black & 1 white) when I try to follow the...
You might not be able to use that switch in your configuration. It appears that the power was run to the light and only two wires were run back to the switch. The old switch only closes to connect those two wires completing the circuit at the lighting fixture, but you need a hot and a neutral to operate the electronic switch that you have.
Gary
Apr 18, 2011 | Vacuums
Hunter Fan Mod 21617-001, wire colors Black with white stripe/ Pink/Yellow/Red/Gray/Black/White. This has a floresent light, no chains or switches. The Pink serves the light. Note the wires are not labeled...
Red and white are twisted together,or however you combine wires.I use plastic wirenuts.Always twist clockwise as the wirenuts are most effective that way and the wires will stay together better.Black/white,yellow,and gray are the speeds yes,and the fan wires go to the receiver wires.It sounds like you do not have the receiver?If it isn't already built in,it should be small enough to fit within the smallest part of the fan base.The remote is the transmitter.Here is a link to show you the wiring.Red&white twist together for house power.Black for house ground.It also shows a THIN WHITE wire for the antenna.It is not necessary to hang it outside of the casing.You should make it spread out around the inside in a full circle,that should be fine.Just not wrapped tightly around the motor,loosely is better.It does show the antenna wire hanging out in the diagram.You can do that also,just make sure it isn't hit by the fan,and it will not cause a fire if pinched by the plate.If you do have all the wires connected,it shows that the dip switches on the receiver must match.Make sure the remote has the battery removed when changing these.When they are correct,there is no way to tell what the fan is set to and it could start moving.The dip switches are equivelant to radio stations.If you want 101.9FM,but it is set to 101.1FM,it won't come in.When the switches match,you are tuned in and hear 101.9FM.If you need more help,just comment here and I will get an autolink to your post and reply ASAP.Good luck,Greg The link looks universal for Hunter fans,all wired the same.
http://www.hunterfanhq.com/tools/sales/hunter/preseason/images/owners/41597.pdf
Nov 16, 2010 | Vacuums
I have a broken chain switch that will not allow me to use all four light sockets. presently only using two sockets. Question: can I by pass the switch by combining all the black wires from the leading...
The blue should be for the lights and you can ty this into the black. The red should be the incoming for the motor to the fans. Some models are different and I strongly believe you have got to be talking about a ceiling fan and not a vacuum. Is this a test question? Because it is a darn good one if you do not mind me saying so however you might have not noticed to check or uncheck a box for the fans. Good luck.
Nov 02, 2010 | Vacuums
Would like to know the correct way to install a light fitting into a ceiling fitting
well the black goes to black and the white goes to white. the ground wire if one, can be hooked in ceiling box or to ground wire. have a good day!! ( this is for 12 or 14 guage wire).
Oct 21, 2010 | Vacuums
No manual with my fan, trying to put the fan up, please advise
Kind of hard to help you with this little information you have provided, but this is what I would do. FIRST and most importantly, you MUST use an approved box hanger to hold the (I am assuming a ceiling fan) fan to the electrical box for connection. BE SURE THE POWER SOURCE TO BE USED IS TURNED OFF!!!!!! Determine the power wires for the fan unit (most likely a black, white and green wire) and, observing the proper polarity, connect to the house wiring. Make sure you are using an equipment ground to the fan. This is usually a bare or green wire. If these instructions are not clear to you, you may want to have a professional install the unit. You should also check with your local municipality about the need for a permit to do this installation.
Aug 27, 2010 | Vacuums
GE on/off timer for a bathroom fan - switch has four wires Green - ground White - neutral Black - power Blue - lead My fan has two - white neutral and black lead I have tried...
I would guess that the black wire on the timer is the power in and blue is the power out to the fan (hook it to the black wire going to the fan) The other colors are right.
Mar 23, 2010 | Vacuums
Vacuums Logo
29 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
