Question about Garden
I have a mini maglite - and I cannot remove the batteries. For the price, these certainly can't be disposable lights! Only the narrow end of the light can be removed, the bulb end does not enable you to get to the battery. Help!!!
    Guru:
  • 479 Answers
Try tapping the base of the torch gently on a table, this may dislodge the batteries . Possibly the batteries leaked and corroded and became wedged in the torch ?
Posted on Aug 06, 2010
Testimonial: "It worked - thank you!"
Replace batteries
Marcia Boal... hello,
If our battery has corroded it may be impossible to get the end (opposite the light) cap to come off. The light is designed to be moisture resistant... Likewise even penetrating oil cannot get in...
To guarantee long reliable service it is best to put a tiny dot of grease on the threads on assembly.
Maglite Solitaire makes a wonderful little flashlight...
(all metal construction... single AAA battery)...
((Mini = 2 AAA batteries... opens the same)).
Basic colors included black, red, silver & blue
but this particular light was also quite popular for commercialization... often displaying many BIG NAME
COMPANY LOGOs.
The initial closure of the end cap can be quite loose to be effective because of it's O-ring design... however some folks put the end cap on too tight...
The
It might take some serious force to get it open again.
Consider using a piece of leather in a pair of pliers to avoid marring the case. Reassemble without over-tightening.
Hope this helps!
Maglite Solitaire Incandescent 1 Cell AAA Flashlight Black Basic Handheld...
Amazon com Maglite Solitaire Incandescent 1 Cell AAA Flashlight Blue Home...
Maglite Solitaire LED 1 Cell AAA Flashlight Red Basic Handheld Flashlights...
Maglite Solitaire LED 1 Cell AAA Flashlight Silver Basic Handheld...
Aug 19, 2016 | Camping, Backpacking & Hiking
HOW TO REMOVE CORRODED AAA BATTERY FROM MINI MAGLITE?
Try some baking soda with a few drops of water, it should loosen it up.
Oct 08, 2014 | Mag Instrument AAA Mini Maglite...
The last battery in my 3-cell Maglight (closest to the end, farthest from the bulb) has leaked acid out inside the tube /handle and caused the battery to get stuck, I can't get it out to clean it up and...
Unscrew the lens and remove the bulb, then get a small disposable container and fill it about an inch full with WD-40, or a similar de-seizing fluid. submerge the stuck end in the fluid for a few minutes and it should come off without issue. Make sure to clean the tube completely before replacing the bulb, lens, and batteries.
Feb 28, 2011 | MagLite Mag-Lite& Flashlight
Cant open battery to change.Mini Maglite
My Mini Mag light has a knurled cap on the end opposite the light bulb. It should unscrew to reveal the AAA batteries.
Jan 16, 2011 | MagLite Mag-Lite& Flashlight
Mini Maglite end, where batteries are changed will not open. Is it the same as the D Cell Maglite; ie. the batteries have leaked? If I send it to you can you fix? Thanx, Peggy P Losee
You can send it direct to MagLite for warranty/repair
Go to: http://www.maglite.com/repaircenters.asp
to find the nearest warranty/repair center.
Gary
Jan 11, 2011 | MagLite Mag-Lite& Flashlight
I cannot get the cap off to replace the batteries of my mini maglite 2 cell AA
Probably a leaking battery has coroded the cap. You can send it direct to MagLite for warranty. Go to: http://www.maglite.com/repaircenters.asp
Gary
Nov 14, 2010 | MagLite Mag-Lite& Flashlight
Battery case does not open
make sures its being turned to the left, and if it will not come off, wrap duct tape around it to protect it and use large vice grips or pliers to get it off. Vice grips would be better as the lock but dont' lock them down too tight as you can dent the cap.
Jun 30, 2010 | MagLite Mag-Lite& Flashlight
I have a mini Maglite with one battery stuck in the barrell
I had a similar problem. My wife put two AA rechargeable batteries into her mini maglite. Apparently the AA rechargeables have a slightly larger diameter than alkaline batteries. One of them was stuck in the barrel. I was able to remove it by first removing the lens and bulb so as not to break it. Then I slammed slamming the barrel down hard onto the carpet on our floor. This hard shock jarred the battery loose and it came out of the barrel. Hope this helps someone out.
Jan 15, 2009 | MagLite Mag-Lite& Flashlight
Corroded batteries stuck in a mini AA maglite
yes the bulb assy can be removed as it's basically the switch you need like a special tool for removing it. but first which brand of battery is in it. both energizer and Duracell have warranty about replacing item that the battery has damaged. try that route is my suggestion before trying to remove batteries and possibly breaking the switch. you can get one sent to you by calling up customer service as i replaced one before mini mag lite also.
Oct 04, 2008 | MagLite Camping, Backpacking & Hiking
Garden Logo
81 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
