Question about Ricoh Aficio 1224C Black and White Copier
I've just replaced my black cartridge and my Aficio 1224 still print with white lines through the text.
  • 67 Answers
Forced toner BK
Posted on Aug 26, 2010
  • li55 Jun 01, 2011
    What does forced toner BK means? What do I actually do? Thanks for your reply.
My ricoh printer cl3500 will not print lettering, color is fine
Replace the Black ink cartridge wth an original type.It's empty.
Apr 15, 2014 | Ricoh Aficio CL3500N Laser Printer
White lines when printing
Usualy white lines are a signal for you that is time to replace a toner cartirdge.
Your machine may inform you that you need to replace a toner cartridge, but sometimes the toner levels are low and the machine doesn't indicate that.
Another thing that you may try is to clean all toner cartridges using each corona wire.
If you need to replace your toner cartridge check this easy and helpful way to replace toner cartridge.
May 16, 2012 | Brother MFC-9320CW Color Laser Printer -...
White lines in my printing and sometimes smudges of black ink
Hi
First before you buy a new cartridge,try doing a 'printhead' cleaning on your machine.Sometimes the printheads need cleaning clogginl.
Mar 03, 2012 | Office Equipment & Supplies
My black cartridge was nearly out of ink and the printing was either ghost text on some lines and on others as if someone had drawn a thin white line thru the text. I have just received a brand new black...
There may be some dust on the contact on the printer, first thing you should do is get a q-tip and clean the contacts carefully to ensure there is no dust or other contaminants on the contacts where the cartridge connects.
Also please could you supply the printers make and model so I can look into this further
Jul 15, 2011 | Office Equipment & Supplies
I have white horizontal lines through the text when printing A4 portrait. What can I do to solve this?
Look at your black development unit, if you see a white band on the development roller, remove the development unit, shake it and turn the gear of the development roller ...
Jun 01, 2011 | Ricoh Aficio 1224C Black and White Copier
Printer creating white lines that distort output
Hello loyasq,
You should do :
1st; Try to fix that by the device's Appliaction
smthing like that
2nd; Uninstall every application for this device and re-install it again.
3rd; If your printer have 1 Cartridge for all colors, Cleanse the part of ink output (the nozzle of ink cartridge) with wet tissue.
Thx for using FixYa.
Apr 15, 2009 | Dell Photo 964 All-In-One InkJet Printer
While printing photos my printer has white vertical lines
Sounds like you need to re-align the print cartridge . The reason the text comes out ok is probably because it is only using the black cartridge for text. The color cartridge is the one that's out of alignment. You may have some sort of Cannon utility running in the task bar that will allow you to easily allign the print cartridges. If not, go to the main "Printers and Faxes" window, RIGHT-click on the printer and select "Properties". You should be able to find a button in the properties that's labeled something like re-align print cartridges. It will print out a series of test pages and ask you to select the set of lines that looks the straightest and type it in. It's a good idea to do this every time you replace a cartrige. Hope this helps, If I was able to FixYa, please remember to rate me. Thanks.
Feb 22, 2009 | Canon MultiPASS F50 All-In-One InkJet...
Ricoh Aficio CL 2000N printing problems
If the colors are good and solid with no fades, only black streaks, then black is the culprit. I suggest replacing the black cartridge.
Feb 20, 2008 | Ricoh Aficio CL2000N Laser Printer
Ricoh Aficio cl2000
Most of the time when I find this happening on a printer, not just Ricoh's it turns out to be the PCU (photo conductor unit). The color PCU is one unit and the black is a seperate unit. Hope this helps.
Dec 17, 2007 | Ricoh Aficio CL2000 Laser Printer
Ricoh Aficio 1224C Black and White Copier Logo
56 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
