Question about Tricity Bendix 24 in. DH102 Free-standing Dishwasher
My dishwasher stops mid cycle and the water stays at the bottom, Its a Tricity Bendix DH 102 model. Please help
5 Suggested Answers
SOURCE: My Tricity Bendix won't work
Check out the water inlet solenoid valve if this is clicking then it is probably the water level pressure switch which appears to be controling the flow of water mechanicaly dependent on whether the water is high enough in the machine and therefore giving enough pressure to close the switch .This may be stuck closed.
Posted on Apr 30, 2008
  • 93 Answers
SOURCE: tricity bendix DH 103
Remove from hole. Place on back. You can gain easy access to pump.
Posted on Jul 24, 2008
SOURCE: tricity bendix dishwasher DH 086
the cold water wont come out, just get a load buzzing noise, I think its the water pump but want to be sure. Any ideas ?
Posted on Nov 13, 2008
  • 100 Answers
SOURCE: dishwasher not working
sounds like the heater is not working. it's washing while waiting for it to heat to correct temperature.
if you are not electrically minded i'd get an engineer out or ring one for a quote.
Posted on Jan 27, 2009
Hi I have a Tricity Bendix dishwasher model DH090. Light comes on, starts up, tablet even drops out of the holder but then the dial stops, nothing else happens. It doesn't matter which of the four...
My wife discovered the solution to this problem.
If you place large plates at the front then the flap with the cleaning tab can't open. So only place small plates at the front of the Dishwasher.
Oct 03, 2011 | Tricity Bendix 18 in. DH090 Free-standing...
Water stays in dishwasher goes through cycle but motor not going if turn propelers at back of motor pump kicks in for few seconds.is it pump motor ,is there brushes in these motors
Yes there are brushes in dishwasher motors it sounds like they are either worn out or stuck try tapping motor with the wooden end of a hammer at the rear of motor as brushes clog up as they wear hope this helps
Sep 05, 2009 | Tricity Bendix 24 in. BDW53 Free-standing...
I have a tricity bendix dishwasher.It is not washing properly,also the washing tablet dose not desolve.the model n.o is TDF 200
Dishes not cleaned properly....
  1. Check the water temperature. Should be 125 to 140 F.
  2. Check pump re-circulation., Listen, see if it sounds like it is spraying the water around with enough pressure.
  3. Check water level when the fill cycle has completed. Should be just under the heating element. If not, possibly need to replace the water inlet valve.
  4. Check the spray arm and pump cover for splits or leaks.
  5. Check to make sure dishwasher is draining after each cycle. There should only be a little water in the bottom of the tub.
Nov 23, 2008 | Dishwashers
Tricity bendix dh101
Check pressure from power supply, check if the inlet valve is faulty or obsstructed.
If you enter model number here , you can find parts and diagrams.
Nov 03, 2008 | Tricity Bendix 24 in. DH102 Free-standing...
Tricity bendix dishwasher DH 086 stopped working after main wash cycle - never had any probs before with it.
Jul 12, 2008 | Dishwashers
Tricity bendix DH 103
Jul 04, 2008 | Maytag 24 in. MDB5600A Jetclean II...
Tricity Bendix DH101 dishwasher
my tricity bendix dh101 will not fill up with water what could be the problem
May 09, 2008 | Tricity Bendix 24 in. DH102 Free-standing...
Oct 17, 2007 | Tricity Bendix 24 in. DH102 Free-standing...
Machine stopped mid cycle - door light illuminated
this appears to me that you have had one problem and created another, based on what you say i guess the original fault was the pump or a blockage in the outlet system, now you have dismantled the door catch and made that a fault, if possible replace the door catch with one that is known to work, then retest to get back to original fault its a bit like "my telly doesn't wok it must be the on off switch" there's much more than the switch to anything, hope i have helped, if so rate me please
Sep 18, 2007 | Tricity Bendix AW1400W Front Load Washer
Dishwasher stuck in cycle tricity bendix DH 104
if this is stopping early in the cycle, the timer has just moved a little before it stops then it is highly likely to be a heater fault, check the element for open circuit, this can be accessed from under the machine, work with safety,
Sep 16, 2007 | Tricity Bendix AW1000W Front Load Washer
Tricity Bendix 24 in. DH102 Free-standing Dishwasher Logo
76 people viewed this question
Top Tricity Bendix Dishwashers Experts
Marvin
Marvin
Are you a Tricity Bendix Dishwasher Expert? Answer questions, earn points and help others
