Question about Panasonic Televison & Video
I have a 27" Panasonic TV that was purchased in 2002. Unfortunately I don't have the owner's manual any more. I am trying to get the colour settings aligned but I am not sure if I am doing it correctly. Can I reset to the manufacturer's settings? If not what is the recommended settings for colour, tint, brightness, picture, sharpness? There is also a setting for video adjustment "Normal" but I can't seem to get that set. How do I do this? Thanks very much
  • 34 Answers
SOURCE: color on vizio 37" lcd
I would recommend a Main board replacement.
Posted on Mar 05, 2008
SOURCE: Video settings reset everytime I turn off TV
Hit the menu button on the remote. Click on Setup. Then click on Set The Quick Start Options. Make sure it is on. That should solve your problem.
Posted on Mar 14, 2008
  • 11 Answers
SOURCE: Picture settings
The settings is on the remote (menu)
Posted on Jul 31, 2008
VOTIT
  • 2071 Answers
SOURCE: Picture washed out, can't get it right
LCD TV TroubleshootingThe defective LCD TV may have the following common symptoms:
Symptom: No picture on screen but LCD TV still has sound.
Solutions: The problem is cause by defective inverter. Replacing ivnerter will solve hte problem. Symptom: Screen flash on and off between 1/2 to a few seconds, but power indicate light stays on and TV still has sound.
Solutions: The problem is cause by defective inverter. Symptom: Blue Screen but no picture
Solutions: The problem is cause by defective Main Board(AD Board). In some cases, this problem may cause by the defective Screen Controller board. Thsi board is mounting on teh back of LCD TV Scree. Symptom: Power light stays on but no display and sound
Solutions: The problem is cause by defective Main Board(AD Board) or Power supply board. Symptom: No Power or Power indicate light does not lits
Solutions: The problem could cause either by defective Power supply board or defective Main Board(AD Board). Symptom: Screen is half dim and half bright
Solutions: The problem is cause by defective LCD Panel.It needs to be replace.
Posted on Sep 21, 2008
Highdefjeff
  • 124 Answers
SOURCE: need help with TV calibration for philips
Try these, Contrast: 53 Brightness: 56 Color: 45 Tint: 2 Sharpness: 2
Color temperature: Off
Dynamic contrast: Off
Digital Natural Motion: Off
DNR: Off
Color enhancement: Off
Active control: Off
Posted on Mar 03, 2009
I can't unlock channels
Try to google the full model number with "manual" which is the owner manual. Aside from that most have a default number for this---if 4 digits try all 0000 and so on, going to need the right remote for this in any case.
If you have the original remote you can call customer service for the brand and ask for the default code.
Dec 18, 2012 | Panasonic CT-27SC14 27" TV
I have a panasonic 52"
The tv projection lamp timer must be reset,read ur ower manual how to do that or call panasonic customers service for the help with the prosedure,sorry i don't remember how to do it anymore.The problems with the HDMI 2 setting all the time.Tries tv unplug,replug the tv back about an hour later for the tv to do a resetting itself back to the factory setting.Than go into the tv Menu changes to all the manually setting and turn off all of the auto functions of the HDMI hubs setting should solved this problems.
May 09, 2011 | Panasonic PT-52DL10 52" Rear Projection...
Hi, i need a replacement for diode number TVSSR2KLV1 for use in Panasonic 27' colour TV. Please help..
It looks like tou can sub this with B0ZAZ0000045 MCMelectronics.com has them for less than $3.00, but there will be shipping of course. They have many other parts and supplies which you might purchase at the same time rather than pay for shipping just one small part.
Nov 18, 2009 | Panasonic CT-36D31 36" TV
Have no manual, need to change the colour manaully
Hi
Could you plz give more info on exactly what Panasonic you do have so i could try and find you a manual on it?
Kind regards
SlitWrists
May 13, 2009 | Panasonic Televison & Video
Sony TV help
sounds like it needs demagnetizing, also make shure you dont have any unshielded speaker close to the set, demagnetizing is performed with a demagnetizing coil, you can purchase one at any tv parts dealer for about 30dollars
Dec 06, 2007 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Set up an a Panasonic TZ-20L3Z
Press MENU button, select PRESET and then , select MANUAL PROGRAM and SEARCH, when search completed the program stops. Give the channel and store.
Aug 19, 2007 | Toshiba 27A34 27" TV
Setting the channels
You can download the manual from the link below: http://safemanuals.com/download_94794.htm Please update the question & let us know if the information given was useful to you - Good Luck!
Where is ny color
HI SIR PLEASE TRY TO CHECK THE COLOUR SYSTEM SETTING SELECT FOR AUTOMATIC OR THE PLACE COLOUR SYSTEM YOU LIVE IN FOR EXAMPLE (NTSC ) FOR USA
Jan 22, 2007 | Panasonic CT-2788YD 27" TV
Can receive only channels 1 thru 27 although connected to cable with 70 channels.
First you need to check if your set is in the cable mode and not antena mode,if the set is in cable make sure is in the standard cable mode and not another type of cable like HRC,if it is change it and try the autoprogram to set the available channels.I hope it helps.
Sep 11, 2006 | Panasonic PV-M1349 Combo
Open Questions:
Televison & Video Logo
20 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
