SOURCE: Once i Turn the throttle my goped turns off
it may be over fueling if you have turned the jet id sugest hold at full throttle and adjust jet whilst running it on full power
SOURCE: my mo ped stutters at high speeds
This sounds like a fuel delivery issue. The GSR has a centrifugal clutch, so the sputtering is most likely coming from the engine. There are three main factors; Air intake, Fuel ratio/mixture/delivery, and spark. Check your air/fuel mixture screws first. Then check the Spark Plug, and finally the air filter/fuel filters.
The filters can clog, and starve the engine for air or fuel, depending on the filter. Try to clean the filter, replace the plugs, and adjust the carb. One of these is the verdict, but you must determine which one. Good luck. If you have further tech questions regarding gas powered Go-peds or electric Go-peds, you can visit www.gopednation.com and ask anything there. The most qualified Go-ped Brand scooter technicians and enthusiasts run this site and chat about their experiences.
-Jackson
http://urbanscooters.com/
