Question about GE Profile JGS968SHSS Gas Kitchen Range
Ge gas stove display reads loc ref and no buttons work just replaced controll board
    Guru:
  • 310 Answers
The keypad is "locked", hold down the button to remove this (usually "clear") for 5 seconds. Look closely at the buttons, one of them will have a picture of a padlock near it. That's the button that clears the "lock" condition. It's a safety feature to keep the kids from turning on the oven.
Posted on Aug 05, 2010
  • daviddillard Aug 06, 2010
    I got the loc ref to clear now display flashes bake and probe,any suggestions on how to remedy this issue? also oven will not light..
  •  Fix Your Board
    Fix Your Board Aug 06, 2010
    Normally the bake/probe flashing happens when you plug in the probe. If you don't have the probe plugged in, then double check that your wiring connectors are plugged in properly on your new board or that the wires to the probe connector are not shorted.
Replaced the LCD pad computer. getting a LOC rEF code. What does it mean or how do I clear it?
If this is a GE oven:
1. Make sure power to the wall oven is turned off_
2. Completely close the wall oven control panel and return the wall oven to its normal installation_
3. Apply power to the wall oven. Accessing the control panel area but not replacing the control:
4. Enter Special Functions mode by pressing the BAKE and BROIL keys at the same time.
5. Reset the control by pressing the 9 and 0 or the HOUR DOWN and MINUTE DOWN keys for 3 seconds at the same time.
6. Approximately 20 seconds after the time of day is displayed. press the 1 and 5 or the TEMP LIP and MINUTE UP keys. The control should briefly go blank, briefly display all segments. briefly 'display "LOC FIEF," display all segments for 30 seconds, and then display "LOC REF:"
7. Acknowledge the "LOC REF" command by pressing the 6 and 8 or the HOUR DOWN and MINUTE UP keys at the same time. The control should then display the time of day,
8. The oven should be ready for normal operation.
9. Test the functionality of the glass touch contra especially the CLEAR/OFF and/or CANCEL key(s)..
Nov 26, 2015 | Kitchen Ranges
Loc on kenmore stove
Usually reading the manual will tell you this .. but not seeing a modelnumber makes this almost impossible to assist you.
Nov 10, 2015 | Kenmore Kitchen Ranges
Whirlpool loc
From a google search the following is copied:
LOC is a control panel lock not a door lock, see below.
The Control Lock shuts down the control panel pads to prevent
unintended use of the ovens.
When the control is locked, only the CLOCK, TIMER SET and
TIMER OFF pads will function.
The Control Lock is preset unlocked, but can be locked.
To Lock/Unlock Control: Before locking, make sure the ovens,
Timer and Timed Cooking are off. Press and hold START/ENTER
until a single tone sounds and "Loc," a picture of a lock and
"START?" will appear on the oven display, about 5 seconds.
Repeat to unlock and remove "Loc" from display.
If the above does not work have you tried removing power from the uit for a few minutes to see if it will reset.
________________
http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/499415-whirlpool-double-oven-shows-loc-display.html
Jan 26, 2018 | Ovens
After cleaning the outside surfaces of the stove, the oven door is locked and does not unlock if we push the stop button. Display reads LOC. No self cleaning cycle was initiated. The stove is a Kenmore...
What about child lock? Read user manual or try holding button for 10 seconds, might be two at once.
(I bought a $200 control board and travelled 150 kilometers for that one....)
Oct 15, 2013 | Kenmore 49043 Electric Single Oven
My oven/stovetop isn't turning on, and it says "LOC" on the screen. Its like the stove won't ignite. What should I do?
To lock/unlock the controls: Turn all surface burners off.
Touch and hold the GAS/CONTROL LOCKOUT pad for 3 seconds until the display shows LOC.
To unlock the control, touch and hold the GAS/CONTROL LOCKOUT pad for 3 seconds until LOC disappears from the display.
Feb 11, 2011 | Whirlpool Ovens
Touch pad does not work and flashed FO
FO- the touch pad is faulty. replace the eoc(electronic oven control)
May 17, 2009 | Kenmore Ovens
Cannot get display clear on kenmore oven
Unplug the cord behind the oven. You'll need to pull out the oven a bit. Not too far as the flexable gas line is there also. Wait 10 min and replug the oven. This will reset the curcuit board after the power surge.
Apr 29, 2009 | Ovens
Loc ref code
just solved the Loc ref problem by going to Ge customer net. By pushing the 6 and 8 numbers at the same time on the contriol board, will reset the machine. worked for me, hope it does the same for you.
Jan 27, 2008 | GE Profile JTP18 Electric Single Oven
LOCrEF
is this the correct model #?? JGS968??
Jan 26, 2008 | GE Profile JGS968 Gas Kitchen Range
GE Profile JGS968SHSS Gas Kitchen Range Logo
605 people viewed this question
Top Kitchen Ranges Experts
Ismael Rodriguez...
Craig Butler
Craig Butler
Sal De
Are you a Kitchen Range Expert? Answer questions, earn points and help others
