Question about Kohler CH25 PA-CH730-0040 Command Gasoline Engine
Leaking oil ,stalls out - Kohler CH25 PA-CH730-0040 Command Gasoline Engine
My Toyota Celica continues to try and stall/sputter while either stopped at a light/stop sign and now while I'm driving. Please help diagnose.
A faulty EGR system will also cause this kind of problem, as well as a dirty throttle body. Have then checked.
Feb 09, 2015 | Toyota Cars & Trucks
Toyota corolla oil leak
Where on the car is the leak at? Front right, left, center and what model Toyota is it?
Jun 04, 2017 | 1996 Toyota Corolla
Cylinder misfire code and secondary air f;ow code
could have a cracked head or manifold. have you seen where its leaking from ? if its a cracked head the would explain the loss of power and problems
Mar 04, 2014 | Saab 9 3 Cars & Trucks
My 1997 toyota camry is leaking oil, what do i need to do to fix it?
Sounds like a blown head gasket or cracked block. Take to a mechanic for testing
Dec 31, 2013 | Cars & Trucks
A week ago my 2003 CRV suddenly had the check engine light on, then stalled at stops on the way home. I took it to a Honda dealer who ran the codes. I was told the oil was low (1300 miles after the last...
THAT PARTICULAR CODE IS CAUSED BY A CATALYTIC CONVERTER DEFECT. YOUR OIL BEING LOW SOUNDS MORE LIKE IT COULD BUT MAY NOT POSSIBLY BE YOUR STALLING PROBLEM. IF THE CAT IS STARTING TO GET CLOGGED U WILL START TO GET STALLING MORE ON THE ACCELERATOR THEN OFF. YOUR BACKPRESSURE FROM THE ENGINE NEEDS TO BE CHECKED. THEY SHOULD HAVE NEVER LET U TAKE THE VEHICLE HOME WITHOUT FINDING THE SOURCE OF YOUR OIL LEAK. THE ONLY FLUID ON THIS EARTH THAT DISAPPEARS OVER TIME IS WATER. YOUR OIL IS GOING SOMEWHERE AND IT NEEDS TO BE FIXED. SORRY TO SAY BUT U HAVE MORE THAN ONE PROBLEM. THE CATALYTIC CONVERTER ISSUE NEEDS TO BE FIXED AND YOUR OIL LEAK FOUND. SOME OF THESE DEALERS ARE CROOKS. IF YOUR CAR IS STILL STALLING ALWAYS TRY TO GO BASIC FIRST SOME OF THE SIMPLEST THINGS COULD BE CAUSING YOUR STALLING.
Sep 11, 2010 | 2003 Honda CR-V
94 Lincoln TC engine stalls when slowing/stopping
Most common cause of stalling for Lincolns in that era is the TPS (Throttle Position Sensor). It regulates fuel mixture, idle speed etc. A bad TPS will usually act up in one of two ways:
  1. When cold, car continually stalls
  2. When warm, car stalls when slowing down (especially if AC is on)
As far as valve cover oil leak, it's a problem that should be addressed to keep oil from fouling your spark plugs but highly unlikely to be the cause of your stalling problem. Hope this answers your question. All the best.
Greg
Jun 16, 2009 | 1994 Lincoln Town Car
Jacks stalls 1/2 way up
try opening the hydrolic oil "fill" plug to let air in...Your jack came with a vented plug,for you to put on after shipping...so oil doesn't leak while being transported...I hope this helps,...1nglen
May 04, 2009 | Plumbing
97 Nissan Truck Stalls Black Smoke
CATALYTIC CONVERTER MAYBE! BE MY GUESS AND IT ONLY HELPS THE TRUCK TO HAVE IT CHANGED!
Apr 06, 2009 | 1997 Nissan Pickup
Oil leak and stall
I have not solved the problem yet, however, at this point I am thinking it may just be a crankcase vent problem. Builds to much pressure and stalls and that is also the cause of the leak??? I used the blower again today and when I took out the dip stick there seemed to be a pressure.
I had listed my problem as a lawn mower cause the snowblower wasn't in your list of options to pick from??
Mar 25, 2009 | Garden
92 Pontiac Grand Am stalled & leaked antifreeze and oil
This happened right after you bought it? Take it back.
Dec 28, 2008 | 1997 Pontiac Grand Am
Kohler CH25 PA-CH730-0040 Command Gasoline Engine Logo
122 people viewed this question
Top Kohler Electrical Supplies Experts
John Trevino
Wayne McNeil
Craig Butler
Craig Butler
Are you a Kohler Electrical Supply Expert? Answer questions, earn points and help others
