Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Reprogram security code entry number? - Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
    President:
  • 3,197 Answers
Locate the smart/learn button on the motor unit near where all those white wires go. Press and immediately release this and then walk over to the keypad and key in a 4 digit code and press enter.
Posted on Aug 06, 2010
HOW CAN I UNLOCK MY 2004 LINCOLN LS? SLIM JIM...RESET KEYLESS ENTRY???
Your keylles code is located in the label on Security Module. To find it, open the right/rear door and pull the on-body weatherstrip slightly away from the body at the rear side of the door opening. Fold and lock the right/rear seat back down into the locked position.
Carefully pull the trim panel that houses the seat belt height adjuster and anchor pivot off of the body. Now carefully pull the lower trim panel from the inside outward far enough to expose the VSM (Vehicle Security Module). This module has three electrical connectors plugged into it, coloured green, grey and blue.
On the module is a label bearing a number similar to 4L2T-15K602-EA. On the same label will be FIVE large numbers. Those five numbers are your five digit keyless entry keypad code.
Additionally, if you have some "new" key, could try to re-programed and synchonized, you must have all remote entry transmitters (maximum of four) available before beginning this procedure. To reprogram the remote entry transmitters:
1. Ensure the vehicle is electronically unlocked.
2. Put the key in the ignition.
3. Turn the key from the 1 (LOCK) position to 4 (RUN).
4. Cycle eight times rapidly (within 10 seconds) between the 1 (LOCK) position and 4 (RUN). Note: The eighth turn must end in the 4 (RUN) position.
5. The doors will lock, then unlock, to confirm that the programming mode has been activated.
6. Within 20 seconds press any button on the remote entry transmitter.
Note: If more than 20 seconds have passed you will need to start the procedure over again.
Hope this helps (remember to rating this answer and leave a testimonial comment).
Oct 11, 2011 | 2004 Lincoln LS
Locked out of my 2004 Lincoln LS extra set of keys inside. Never have known my keyless entry code, wondering if there was a way to obtain that or reset it?
Oct 11, 2011 | Cars & Trucks
Want to change entry code on lock./
Reprogramming FE 375:
This link will take you to the page you need, to get started:
http://consumer.schlage.com/Service-Support/Pages/InstructionandManuals.aspx
Then scroll down to this heading on that page:
Electronic Security-Keypad Entry Flex-Lock...
There's a wealth of info under that heading. You will be able to see a PDF file of the original print instructions, as well as a video of how to install the lock. This is useful because there should be a sticker to be found on the backside of the keypad, with the code number that you need to reprogram the lock. This installation video (fourth item down) will be useful to allow you to disassemble it and view the sticker. This is also a great time to change the 9-volt battery!
The ninth item under that same header is a video which walks you through how to reprogram the keypad to your new code, using that program code that you found on the backside of the keypad.
Aug 06, 2011 | Schlage FE575-CAM-ACC FE575CAM505ACC...
Remote starter stops working every few months, I was bringing it in to have it reset every time but shop is no longer open. I would like to know how to reset the unit myself.
Use this procedure to reprogram the remote transmitters
1. Turn "on" the ignition.
2. Press the Valet Switch 5 times and wait for horn confirmation of entry into programming mode.
3. Press and release the "Lock" transmitter button on each remote to be coded (one at a time).
4. The system will respond to each with an audible confirmation.
5. Turn "off" the ignition to exit program mode.
The unit should retain the transmitter codes almost indefinitely and should not require reprogramming periodically. I suggest that you call Omega Research and Development, the makers of Excalibur, to see if your unit can be replaced. Their number is 800-554-4053 and their is www.caralarm.com
Nov 10, 2010 | Excalibur RS-310-EDP Remote Start Keyless...
Lost instructions on how to change codes on a Schlage FE595 keyless entry . How do I change the codes? Thankyou.
There's a wealth of info under that heading. You will be able to see a PDF file of the original print instructions, as well as a video of how to install the lock. This is useful because there should be a sticker to be found on the backside of the keypad, with the code number ( the programming code) that you need to reprogram the lock. This installation video (fourth item down) will be useful to allow you to disassemble it and view the sticker. This is also a great time to change the 9-volt battery! A battery should last about three years under normal usage.
A note about the PDF files: If you cannot view a given file, you need to first install Adobe reader. You can get the free download from here:
http://get.adobe.com/reader/
Good luck--and please provide feedback if this helps!
Sep 25, 2010 | Schlage FE595PLY626FLA Satin Chrome...
My lift master security plus keyless entry pad for the garage door no longer will open the garage door when I key in the four digit code. Can I reprogram the entry pad and if sohow?thank you
You can try programming it but first make sure the battery is good. Locate the smart/learn button on the rear of the motor unit near where all those white wires go. Press and immediately release this and then walk over to your keypad and key in any 4 digit code you like and press enter.
May 20, 2010 | Sears Craftsman LiftMaster Chamberlain...
I can't find the keyless entry code for my 2004 ford freestar
The code is on the fuse box under the dash near the hood release. On my van there are two bar codes on a sticker attached to the fuse box. Under the first bar code, on the right side is the 5 digit code (bring your glasses the numbers are really small). After you get this code, just search the internet and there are plenty of forums on programing the keyless remote and also adding your own unique number to the key pad entry.
Good Luck
Mar 08, 2009 | 2004 Ford Freestar
Radio code
  1. CODE ENTRY: The proper five digit code for the radio is listed on the two cards supplied in the radio security envelope. After installation or when the radio requires reprogramming the word "code" will appear on the display screen. Enter the code by using the preset buttons numbered 1 through 5 . If a "beep" sound occurs when the code is initially entered, it is then necessary to re-enter the code starting with the first digit. The "beep" sound was provided to indicate the starting point for code entry. If the code has not been properly entered after three successive attempts , the radio will then not accept any entry until the radio has been left "ON" for one hour (vehicle ignition must be "ON"). After one hour in the "ON" position, the radio will then accept three additional entry attempts. Also, if a push-button is touched accidentally when the ignition is "OFF", a warning tone will sound. Turn the ignition to the "ON" position and the warning tone will stop.
  2. Radio security codes will not be given to anyone under any circumstance other than authorized jaguar dealer personnel after proof of vehicle ownership and proper identification has been established. A separate security envelope with the attached instruction is provided in each radio package. If the radio has been port installed, the security package will be placed in the vehicle glove box. NOTE: When the car arrives at the dealership, the radio will be in the inoperative mode even though it has already been installed. It is imperative that no attempts be made to install a tape cassette while the radio is in this mode. The cassette will not eject and damage may occur when removal is attempted.
Nov 04, 2008 | 1991 Jaguar XJ6
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
75 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
