Question about Panasonic KX-T7633 Corded Phone
I have a panasonic KX-T7633 phone, how do I change a number in the system speed dial directory.
  • 274 Answers
SOURCE: System Directory
I assume you have the manual. I found it very difficult to follow, very poor. While "on hook" enter the number you want to call. Press "store" or "enter". Enter the name referring to the graphics chart on pages 7 & 8. It is set up for Alpha characters and it depends on which software is installed on your phone. Example: If you want the letter "A" you press the number 2 one time. If you want the number "2", you have press "2" seven times to display the number 2. Use the toggle key to move to the next letter or number you want to enter. When you have finished press "Store". It may take awhile but that's how its done. Not a very good system for the average consumer in my opinion. But that's how its done. I was unable to upload the manual. Here's the link if you don't have it: http://www2.panasonic.com/consumer-electronics/support/Phones-Fax/Business-Home-Systems/System-Phones/Digital-Hybrid-IP-PBX-Phones/model.KX-T7630
Posted on Sep 15, 2007
cnavarro
  • 2460 Answers
SOURCE: Digital panasonic kx-t7633
The 7633 has a FWD/DND button. Is it blinking, lit solid or dark? It's designed to be pressed 3 times for FWD DND or OFF....It's programmed as follows, assuming that 500 is your voice mail access code:
From the intercom dial *7101. That sets DND. Dial 710x 500 # to set call forwarding where x-2 for all calls 3 for BUSY for for NO ANS 5 for BSY/NA. 7&8 are FOLOW ME commands and they have a different set of instructions ie Dial *7107 plus your extension to have calls come to the phone you're at and *7108 plus your extension to cancel it. I have never seen it used. *7100 cancels all forward and DND arrangements from your phone..
This is just hte command set for ALL CALLS. You can also set up forwarding for Outside Calls and Inside calls seperately and you can program buttons to do the forwarding.
Your Panasonic dealer has 2 manuals that you would find interesting, one is the TDA Operating Manual and the PTPM Manual. The operating manual has a complete set of programming instructions for the manager and users of TDA systems, the PTPM has a complete set of programming features that can be performed from a Panasonic 76XX display phone.
THe pdf's aren't huge and they can be sent to your email address if you provide one under the Ask Me button.
Carl
Posted on Oct 01, 2008
cnavarro
  • 2460 Answers
SOURCE: PANASONIC KX-TDA-50 PHONE SYSTEM WITH
From the main phone, press PROG **1234 and dial 004. Press ENTER 2 times (watch out, it moves on the display) and you will be looking at 101 : OPERATOR if it's still unprogrammed. Keep pressing NEXT until you get to the one you want to change and use a combination of the keypad and the AUTO ANS button to spell out the new name. The STORE button saves it, the right arrow and clear button step back and forth on the line you're entering.
You can pick up the handset and drop it back into the cradle when you're done to exit.
Carl
Posted on Jan 21, 2009
ybchuan
  • 201 Answers
SOURCE: Hi, How do you change the time on a Panasonic
There are several way that may adjust the Panasonic phone clock, please try the following suggestion method:
Method 1:
1) Press PROG soft button, follow by HOLD button.
2) LCD show direct the time adjust, key in the correct time, let's say 8.15am, so key in 815 and press STORE.
3) Press END or HOLD to end the setting.
Method 2:
1) Press PROG soft button, follow by HOLD button, follow by # button.
2) LCD show time adjust, key in the correct time, let's say 8.15am, so key in 815 and press STORE.
3) Press again # button to select between AM and PM mode.
4) Press again STORE to save the setting.
5) Press END or HOLD to end the setting.
Method 3:
1) Press PROG button, follow by key * * 1 2 3 4.
2) Press key 0 0 0 to display the day/time setting.
3) Press |> or SP-PHONE button if u wish to change the date.
4) Press |> or SP-PHONE button to change the time.
5) Press CLEAR or TRANSFER button to change current hour entry.
6) Press |> or FWD/DND button to change current minutes entry.
7) Press |> or FWD/DND button again and AUTO ANS button to change between AM or PM.
8) Press STORE to save the setting.
9) Press END or HOLD to end the setting.
Hope these help.
YBC (/\)
Posted on Oct 19, 2009
  • 547 Answers
SOURCE: KX-T7633 Voicemail rings
The Voice Mail feature is set by your phone company, not by the phone. Typically the phone company will set it for 20 seconds, or approximately 4 rings. This is called your voice mail "Ring Cycle"
Call them up (the customer service number should be on your phone bill) and they should be able to increase or decrease your ring cycle for you at no charge.
Posted on Dec 02, 2009
How do I change the number of rings before the answering machine picks up the call on my panasonic KX-T7633 phone
If this is forwarding to the answering machine on YOUR phone, from the intercom dial *713xx where xx is a number of seconds. I think by default it's using the system number of 40 or 45 seconds. Try 24 for 4 rings (or multiply the number of rings by 6 and you get seconds).
If you're talking about SYSTEM rings before the VM, it's a different story and it requires system programming.
Carl
Aug 24, 2011 | Panasonic KX-T7633 Corded Phone
Trying to get phone numbers programmed on a Panasonic KX-T7633. I can store them in a directory, but am having trouble assigning them to the "Flexible CO buttons".
It's a trick. Assign the button, then press PROG the button, and dial 2 then 9, or whatever your access code is for an outside line, then the number and ENTER. You can press more buttons and dial more numbers, or press EXIT to quit.
Carl
Aug 18, 2011 | Panasonic KX-T7633 Corded Phone
Using a Panasonic KX-T7730 phone can I load speed dial names to the phone so when dialing the speed dial number the name comes up who you are calling?
This manual http://www.discountphonesystems.co.uk/acatalog/Panasonic-KXT7000-Series-Phone-User-Guide.pdf will show you a graphical instruction on how to do it.
Thank you for visiting FixYa! We answer your concerns promptly for FREE. Please spare a few seconds to click on YES button in return. Have a good one!
Jul 18, 2011 | Panasonic KX-T7730 Corded Phone
How do i divert the Panasonic KX-T7633 to a mobile?
Dial *7105 then 9 then number to dial then #
call forward external needs to be enabled on your system
Nov 12, 2010 | Panasonic KX-T7633 Corded Phone
How can I change the speed dial number programmed on a CO button?
press PROGRAM the button, dial 2 9 plus the number and SAVE
Carl
Oct 20, 2009 | Panasonic KX-T7633 Corded Phone
How do I program numbers into the system (not personal) speed dial directory on the KX-T7630
The installer or system manager has access to system program 001, either by a phone or by the maintenance console. All system speed dial numbers and names are entered from there.
Carl
Oct 08, 2009 | Panasonic KX-T7630 Corded Phone
Having trouble entering speed dials - please help!
Not knowing the specific model of the phone system itself (the PBX cabinet in the telephone closet) I would guess you are using the "personal directory" and it only has 10 number memory and it goes from 0-9. The system directory will give you more mems.
Sep 03, 2009 | Panasonic KX-T7730 Corded Phone
Cannot get the correct time set on the phone. Panasonic kx-t7633
Try this....
For Panasonic system (especially for KX-T7633), you have to make changes from extension 101.
1. leave handset in the cradle then press "program".
2. Dial *# then "SP-PHONE" button until you see something like time set something something
3. manually input correct date then time then press "auto dial/store" button.
4. pick up the handset then hang up to save.
Aug 24, 2009 | Panasonic KX-T7633 Corded Phone
How do i change the telephone number on an extension? panasonic kx-t7633
It's done in system programming. You can't directly change it, you may have to manufacture a number like 666, change A to 666, B to A, then 666 to A. It's the Panasonic way, no SWAP Directory command :-)
Carl
Aug 13, 2009 | Panasonic KX-T7633 Corded Phone
Revising extension directory on LCD
Correct. Changes are done in system programming. In a TDA it resides in system program 004. You get there by going to the main phone or phone used to program, dial PROG **1234 004 and enter the extension number of the name you want to change. It will display the present name and let you use the keypad to spell out new names. For example 2 gives you ABCabc2. The right arrow steps to the next character and ENTER saves it.
Carl
Sep 23, 2008 | Panasonic KX-T7633 Corded Phone
Panasonic KX-T7633 Corded Phone Logo
217 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
john milligan
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
