Question about SanDisk Sansa e250 MP3 Player
Keep saing refresh database - SanDisk Sansa e250 MP3 Player
  • kakima Aug 06, 2010
    If you have a microSD card installed, remove it. Press and hold the power button for fifteen seconds. Does that do anything?
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • SanDisk Master
  • 102,366 Answers
Having received no response in over a month, I assume the suggested reset solved the problem.
Posted on Sep 19, 2010
"Refresh Database" never ends!
If you try to load too many songs onto the player initially, it may take up to an hour to get past Refresh database. Unfortunately, if you shut the player off while it is refreshing, it will more than likely ruin your player. Run the Sansa Recovery Tool or Update the Firmware on your Player as a workaround. Make sure the hold/lock switch isn't activated, just as a safeguard.
-Tha Mp3 Doctor
Mar 17, 2009 | SanDisk Sansa e250 MP3 Player
Refresh database
Did you try reseting it?
May 25, 2008 | SanDisk Sansa e250 MP3 Player
My sansa e250 keeps shutting down
switch the usb mode which ever one is highlighted first chose the other and then it will stop refreshing
Feb 19, 2009 | SanDisk Sansa e200 MP3 Player
Frozen while on the refresh database screen
Try holding the power button for about 15-20 seconds. This usally shuts the whole thing down.
It may refresh the database as normal next time.
Nov 18, 2008 | SanDisk Sansa e250 MP3 Player
Sansa e200 shows refresh database fail
try putting it in MSC mode and formating it and then putting back on MTP mode. Hope that works
Aug 24, 2008 | SanDisk Sansa e250 MP3 Player
Refresh database?
Try this
Run the recovery tool from the SanDisk website. Make sure you select "format" when prompted.
http://rapidshare.com/files/67740173/e200fw01.00.12.exe____
You need to put the device into "recovery mode" before you run the tool.
- Turn the device off (hold power for 20 seconds)
- Slide the hold switch into "hold" position.
- Press and hold the "record" button while connecting it to your computer. Keep holding the "record" button until you see the "new hardware found" on your computer.
Then run the recovery tool. Select format when prompted.
Jun 19, 2008 | SanDisk Sansa e260 MP3 Player
Database refresh on Iriver H10
I have done this. my iriver is almost full i have the 20gb, when the you do the database refresh, it just takes a really long time. mine takes about 2 hours to finish, once you see the clock on database refresh you cant do anything but wait till its finished.
Oct 18, 2007 | iRiver H10 MP3 Player
Continous refresh database
I've got the same problem too. I read this on another website: 'well firstly drain the battery and then connect it to charge it up a bit. once it has been there for 5min or so take it off and then turn it on>settings>USB Mode>MSC once you have done that connect it up and it should work/recognise the player. i don''t know how this thingy happens but this is just how i fixed mine!' I'm gonna try it now on mine, and see if it works. I've just got to wait now... Good luck with yours.
Apr 10, 2007 | SanDisk Sansa e250 MP3 Player
"refresh database failed" how do I do a database refresh?
i have the same problem ... refresh database fail .. i can put songs on the player but it doesn't show them or play them :-( HELP!!!!
Nov 15, 2006 | SanDisk Sansa e260 MP3 Player
Refresh database looping
This may not work for everyone - but try inserting a TransFlash (also called Micro SD)card in the microSD slot, and power on. It may then correctly refresh its database. It worked in my case, with firmware ver11.
Aug 11, 2006 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
20 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Mohamed Ismail
Mohamed Ismail
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
