Question about Electric Mobility Invacare Pronto M41 Electric Scooter Power Wheelchair
Chair fully charged but quit running without for "no reason"
    Novelist:
    Champion:
  • 232 Answers
Are there any blinking lights? The number of lights that are blinking indicate what the problem is. Visit this site to locate the type on controller on your power chair and you will be able to see that the blinking lights mean:
http://www.pgdt.com/scenter/diagnostics/diagvsi.html
Try to reset your manual brake release as this is a common problem.
Check all of your connections to ensure nothing has come loose. Ensure your batteries are not damaged and fully charged and that the fuses are good. If a power chair has been stored for a while the charger may indicate a full charge but the batteries are full of oxidized crud instead of power and need to be replaced.
If you continue to have a problem, contact your manufacturer or dealer for service. If your insurance purchased they power chair for you, they may also cover the cost of repairs.
Posted on Oct 20, 2010
How long can i run chair on one charge'
With new, fully charged batteries, you can get a good 8 miles at full speed with a normal weight load on the chair. The chair goes about 4-5 mph, so an hour and a half or more at full speed on level terrain. Be sure to always recharge daily, keep the chair on the charger when not in use(batteries will die if you don't)and avoid running the batteries all the way down....try to stay in the top 2/3 charge range and you will get more life.
Apr 27, 2014 | Pride Jazzy 1103 Ultra Indoor Power...
Hi I have a Jazzy 614 HD. I charge my chair with (new charger) and it turns off when fully charged and my Joy stick reads fully charged (New Joystick and new batteries) but within three to four hour
perhaps since your chair is over 2.5 years old you have underlaying problems such as motorheatup or excessive drag per a locked bearing or a bushingtrhat is out of lube.somebody needs to at everything that moves thathas to do withload carry,or powertrain.
Jan 12, 2013 | Pride Mobility Jazzy 614 HD Power...
The only time the chair worked [approx. 1/2 hour] was when the repairman cleaned the cables. Since that, the chair charges, turns green for full charge, and only flashes red as soon as the joystick is...
hi.
the link below is for the owners manual for the quickie aspire power wheelchair, free download in pdf format.
http://www.wheelchair-review.co.uk/wheelchair-files/wheelchair-manuals/sunrise-medical-wheelchairs/quickie-aspire-power-wheelchair.pdf
the "cane crutch holder" is an acessory part that you can get, fitted to the back of the seat, to hold a crutch or cane. it does not affect the chair itself at all.
there are two most likely reasons for your problem, neither of which actually involve the arm and controller.
1. if the battery light is flashing 9 times when you try to move, then you need to check the motor locks are engaged properly. see page 27 of the manual for photos and location. these are also known as "freewheel levers" and allow you to disconnect the motors to push the chair manually. if the levers are engaged properly, it is quite possible that the switch, or switch wires have broken and the chair thinks that they are off. these are very cheap and easy to replace and are located where the lever connects inside the chair.
2. if the battery light comes on and stays on, then you may need to have the batteries checked. if the batteries have not been charged for a while then sulphur may have built up on the lead plates inside the battery. this can mean that the batteries will show fully charged, but as soon as you try to draw power, they cannot function due to the sulphur, and instantly show as flat.
any auto shop should be able to perform a battery load test for you to test this. a 100amp load test for about 6 seconds will test the battery performance and let you know if they need replacing. most places will do this test for free but the batteries need to be fully charged first.
hopefully, one of these solutions will work as these are the most common fault for the symptoms you are describing. you should find the manual quite useful as well.
please feel free to ask if you need more information.
hope this helps
Jul 12, 2011 | Quickie Wheelchairs Quickie Aspire Power...
I purchased a Pronto 41 wheelchair and a Winsunny battery charger. The charger didn't have a manual so I'm wondering what the best procedure is for recharging the batteries. Do I need to turn the...
Joe See my tips on charging batteries No you don't have to leave the chair on when charging. Charge overnite after using it during the day. Always have the charger off when plugging it into the chair and unplugging from the chair. The charger you have doesn't have an on/off switch so get a power strip with the on/off switch, plug that into the wall and plug your charger into the strip use the switch on the strip to turn the charger on and off this will save you having to plug and unplug the charger rom the wall. Always store or put the chair up fully charged. If you don't use the cair daily charge at least once a week. It takes 9-10 chargings to get the batteries operating at 100% so use the chair and charge overnight while you sleep Never leave the charger on the chair more than 12 hours Hope this helps you
May 30, 2011 | Electric Mobility Pronto M41 Power Chair...
My uncle left my hoveround chair out in the rain is this the end of my chair? when i plug in the charger the light on the charger lights up green but the chair wont come on
Angel the charger light should only turn green when the chair is fully charged. If you know the chair isn't fully charged then there is a problem with the charging system. if the circuit board in the joystick got wet then that is a serious problem. If you have a voltmeter you can check the battery voltage thru the charging port located under the front of your joystick Set the meter to 200 volts dc and plug the leads into the 2 outter holes of the charger port. Fully charged you should read 27-30 volts if you aren't getting any reading then the batteries are completly dead or there is a problem with the charging circuit (the reason you are getting a green light on the charger) The joystick will have to be replaced sorry If Medicare paid for your chair then they will pay 80% of the repair costs to get your chair working again If they did contact Roadrunner Mobility @ 1-800-467-2668 to get it fixed thru Medicare Hope this helps
Apr 27, 2011 | NRS Hoveround MPV 5 - Used Power...
Do not know if chair is taking a charge lights just keep moving across armrest .how do u tell when fully charged?
hi let me see if i can help ,
When the lights go back and forth on your joystick that means the chair knows its pluged in .Now the chair itself has a built in charger that is mounted on the back of your chair .The back of the chair ,there is a opening a cutout in the frame .when you plug in your chair there will be a red light and a yellow ,yellow means the chair is charging, wait till it turns green,this means fully charged.When you plug in the chair youll see the lights through that hole.Look for the lights.
I recommend my customers to leave there chair charging over night look at the light it will be green when you turn the chair on the joystick should show fully charge.
Good luck hope i was of some help.
Jan 20, 2011 | Invacare Supply Group Invacare Pronto M51...
Hello, After fully charging my mother's Jazzy power chair overnight, the rear battery indicator/pointer shows zero meaning it's fully charged. I leave it unplugged all day and then by 5pm when I check...
Sorry but it sounds like weak batteries. I would replace both batteries and after installation fully charge before use. Then ask Mom to use the chair more each day so you can charge them overnight each day for the next 20 days. It will break in the batteries and get them operating at 100%. If you can get her to use it more and charge it overnite and always put it up at full charge the batteries should last 2-3 years Hope this helps
Dec 16, 2010 | Jet 7 Portable Power Chair
I had not used the chair in 2 months, when i charged the battery in my electric wheelchair, the lights near the top of the joy stick shows its fully charge, but when i unplug the cord, it go's...
Yep It sure does Why didn't you charge the chair for 2 months? Charge at least once a week if you don't use it daily. Always break in the new batteries by using the chair daily for 10-15 days charging everynite then charge once a week if it sits for that long without use. Always put up fully charged. Do this and your batteries should last 3 -4 years Charge overnite if you use daily and never charge more than 24 hours Good Luck
Nov 15, 2010 | Electric Jazzy 1115 Power Wheelchair
I have a Rascal 305. How long should built-in charger run to fully charge batteries. Mine only charges about one hour at 3.5 amps (on meter on back) before shutting off. What should charging current be,...
moleman If the batteries are fully depleted then the on-board charger will not pick them up and charge them to full strength. It is not designed to charge very low batteries. If the batteries stayed fully depleted for a period of time you will have to replace both of them. You should never fully discharge your batteries. The battery level gauge on your chair should be used to determine when to charge if it is the red recharge overnite. Get into the habit of recharging overnite if you use the chair daily. Always store the chair fully charged and if not used weekly charge once a week. Never leave the charged plugged in more than 18 hours. The chair only operates on about a 5-6 volt range from about 21-26 volts. If you are in the red the voltage is down to about 20-21 volts. Hope this helps you
Sep 29, 2010 | Health & Beauty
Not sure if jet 3 is charging
Does all your lights on the joystick come on after charging? If you can have someone look behind your chair while still plugged in for charging, the green light on the charger will be lit if the batteries are fully charged. They will have to kneel and look under the shroud to locate the charger they will see the light if it is on. Also check the meter on the rear of the chair the meter should read zero when the chair is plugged in and fully charged. I fyour chrger is working then if the chair does not stay with power for what was normal then new batteries are probably needed
Aug 21, 2010 | Jet 3 Ultra Power Chair
Electric Mobility Invacare Pronto M41 Electric Scooter Power Wheelchair Logo
260 people viewed this question
Top Electric Mobility Health & Beauty Experts
Robin Hill
Robin Hill
Colin Taylor
wcdoc1953
wcdoc1953
Are you an Electric Mobility Health and Beauty Expert? Answer questions, earn points and help others
