Question about Viking VGIC485-6G Gas Kitchen Range
I Have A Viking Range Model no.EVDSC 4856 GSS and I don't have a user manual. where can I get one. I really can't use my oven properly until I have one. Thanks
  • Clairb Aug 05, 2010
    Thanks this was a great help
  • 942 Answers
Go to this site and click this link:
Fill it up all the necessary information and they will reply to you on how you will get the brochure straight from Viking Corporation...
Posted on Aug 05, 2010
Part numbers for door gaskets Viking double oven ved0530ss
Go to searspartsdirect.com with your model number. You'll find parts lists and diagrams there
Dec 01, 2017 | Viking Ovens
I have an Eaton Viking stove that has a broken baking element. Is there anyplace that can supply one for me.
Amazon or direct
Amazon.com: Bake Element for Viking Range, PJ010004: Appliances
https://www.amazon.com/Bake-Element-Viking-Range-PJ010004/dp/B00OJ5VL0U
Rating: 4.8 - ‎17 reviews
Buy Bake Element for Viking Range, PJ010004: Range Parts & Accessories - Amazon.com ? FREE DELIVERY possible on eligible purchases.
Viking Parts by Viking - Factory Parts for Viking Appliances
www.allvikingparts.com/ Need a part for a Viking Range, Stove, Oven, Grill, Refrigerator or Dishwasher? We stock thousands of Genuine Viking parts.
Locate Your Viking Model and Serial Number - Allvikingparts
https://www.allvikingparts.com/Articles.asp?ID=142 What do Viking Model Number and Serial Numbers Look Like? Viking ... For Viking Open Burner Ranges and Rangetops(You have an Open Burner Range or ... Eaton Viking stove Google Search
Mar 13, 2017 | Heating & Cooling
Part schematic for viking vmor205ss
Viking VMOR205SS Manual
https://www.manualowl.com/p/Viking/VMOR205SS/Manual/122009
Manuals and user guide free PDF downloads for Viking VMOR205SS.
Aug 27, 2015 | Viking VMOR205SS Microwave Oven
How do I set the digital clock on Viking Range Model RS3026W1? I don't have the user manual.
HI Hold down the timer button until the numbers flash then up or down to set
Hope thats it. Mike
Apr 03, 2015 | Viking Kitchen Ranges
Viking double oven control panel labels rubbed off
The control panel face can be ordered from Viking Range unless the unit is very old, then I would suggest partstown.com, You will need the model and serial number from the rating plate on the unit. These parts are usually not very expensive and are really easy to replace.
Hope this helps....GOD BLESS...Randy...
Feb 02, 2012 | Viking Designer DEDO130 Dual Double Oven
Calibrate oven
i couldn't find your model on the sears site,every viking stove i've worked on had two ignitors,if one of the ignitors isn't working correctly could cause heat changes in the oven.if you pull out the racks,then remove the side rack holders,lift up the floor so you can see the ignitors,start the oven,as soon as the ignitors start to glow time them,if they don't ignite the flame within 40 seconds the ignitor is bad.if this is the problem you don't have to calibrate the oven.also if the ignitor or both are bad check the burner tube to see if there's a hole in it.my friend john had trouble with his oven,i went over,had to change out both ignitors and both burner tubes,the ignitors weren't working correctly and burnt a hole through the tube.so check the ignitors first,if you want to calibrate it look at your manual and it should tell you how to do it,or oull off the thermostat knob,look on the back there might be screws there to calibrate it or if there's a hole in the shaft in the shaft that you pulled the knob off of you might need a small screw driver to stick in there,turn it slowly and not to much to the right to increase the temp.hope this helps but start with the ignitors,they are usually the problem.
Dec 18, 2011 | Viking 30" Dual-Fuel Range, VDSC3054B...
Viking model vdsc4874gss small oven works fine large oven element on bottom only gets hot in cleaniong mode, fan comes on when dial is turned to convection but no heat power is on light works
One thing that you can check is make sure that you have 220 volts at the plug. Leave the unit unplugged and check continuity on the burners. You should have continuity on the burners.
Oct 18, 2010 | Viking 48" 6 Burner, Grill Professional...
Have a Viking range, gas top, electric oven, neither work.
Check connector block where electric is brought into stove for loose or burnt wires. Check Breaker in house power box. Push the breaker firmly to off and then return to On position. Read owner's manual to see if ignitor circuit has a fuse and check said fuse.
Sep 12, 2009 | Viking 30" Dual-Fuel Range, VDSC3054B...
Viking Range oven door does not close properly
sounds like the door hinges need replaced. order a part #PC020009 qty 2
Jan 12, 2008 | Viking VDSC365-6B Dual Fuel (Electric and...
Viking VGIC485-6G Gas Kitchen Range Logo
81 people viewed this question
Top Viking Kitchen Ranges Experts
Ismael Rodriguez...
Craig Butler
Craig Butler
Paul Carew
Are you a Viking Kitchen Range Expert? Answer questions, earn points and help others
