Question about Acer Aspire One PC Notebook
How do you zoom in and out of a screen. Which key to press
  • 942 Answers
Press Ctrl + trackpad of your mouse. If your mouse does not have the track pad, you can use Ctrl + left click or Ctrl + right click..
Posted on Aug 06, 2010
How to enlarge pribnt on screen
There are a couple of ways you could do this.
Depends on what program you are using, often just pressing the "command" key then the "+" key will 'zoom' the view, then use "command" + "-" to zoom out... this just zooms in on the file you have open at the time.
You can use the 'Zoom' function in System Preferences -> Accessibility, Zoom. This will 'zoom' on where the cursor is currently located to enlarge just an area on the screen.
If you want to change the whole screen, you could change the display resolution. Go to System Preferences -> Displays. Depending on your monitor, you can change the resolution to a lower number which will make everything 'bigger' on the screen.
Thanks,
John
Feb 16, 2015 | Apple 24" iMac Desktop
I CAN'T play my pogo games because my screen won't expand all the way to expose the entire game board, and my maximize screen doesn't work. I've tried Screen resolution without Success. I am about t
according to pogo, there is only two reasons for not fitting on screen.
  • Zoom level - First, please make sure to set the zoom level of the game screen to 100% by using "Ctrl" key and (+) or (-) to get the desired screen size.
  • Resolution - Try to adjust the resolution, for guidelines please check out this article : How to adjust your Screen Resolution / Size or this one if the game has been downloaded: How can I change my screen resolution?
So since you tried screen resolution, try the zoom level inside the game by holding the ctrl key and pressing the (-) key to zoom out or (+) key to zoom in. if it doesn't work, post to EA games the issue, games affected and your operating system so they can see if it is a bug.
Sep 30, 2014 | Dell Computers & Internet
Make screen bigger
To zoom in on a website in your favorite browser, making the website appear bigger, follow these steps:
Using the keyboard and a mouse with a scroll wheel:
  • Hold down the "Ctrl" key on your keyboard and roll the mouse wheel up to zoom in, or down to zoom out.
Using only the keyboard:
  • Hold down the "Ctrl" key and press the "+" key to zoom in, or the "-" key to zoom out.
To make the browser full-screen, taking up the whole screen on your computer, press the "F11" key. Press the "F11" key again to exit full-screen mode.
I hope that helps you!
Jun 21, 2014 | Computers & Internet
Fix zoom level
This amazingly easy trick will instantly enlarge hard to see text on your screen! Should you ever want to decrease the text, this trick in reverse will minimize text as well!
Spending lots of time online can cause eyestrain, especially if you encounter very small text. Don't squint or hunch over your screen! Squinting causes wrinkles! Using these tips you can read screen text comfortably! With the press of two keys, you can enlarge the screen text without going into your settings. Simply press and hold down the "control" key, while pressing the "plus sign" key. Be sure to keep the "control key" depressed while you press the "plus sign" key. Each repetition will enlarge the text. This can make reading small text SO much easier! To return the text back to its original (being polite to the next user), simply press, and hold down the "control" key and the "minus sign" key. Each repetition will decrease the text . also Create Menu tab right click in the top of screen (toolbar) you will see a number of toolbar options select the menu bar this will add to your screen toolbar File Edit View Favorites Tools and Help select the view from the drop down list will be a Zoom with percentages %
and text s largest to smallest
Mar 10, 2013 | Acer Aspire 5500 5570-2609 Laptop
My laptop screen is zoomed out how do i zoom in???? (facebook)
Press the CTRL Key and + Key together to zoom In. To zoom out press the CTRL Key and - key together
Aug 10, 2011 | Computers & Internet
Hi i'm having a problem my computer screen is acting really weird every thing is zoomed in and is really big i just installed windows 7 and afterwards every thing stayed zoomed in i tried restarting it and...
  • If you have a mouse with a wheel, hold down the CTRL key, and then scroll the wheel to zoom in or out.
  • If you click the Change Zoom Level button c3f4930f-73f0-494b-a11a-eba6f829dede.png, it will cycle through 100%, 125%, and 150%, giving you a quick enlargement of the webpage.
  • From the keyboard you can increase or decrease the zoom value in 10% increments. To zoom in, press CTRL+PLUS SIGN (+). To zoom out, press CTRL+MINUS SIGN (-). To restore the zoom to 100%, press CTRL+0.
Dec 30, 2010 | Computers & Internet
How to set up mode for graphing
To draw a graph, it helps if you know approximately where it is going to show up so that you can set up a window.
Try this:
Press the [Y=] button
Enter the following equation: 5*x^2-5*x (five x-squared minus five times x) by pressing the following calculator keys:
5 X (times) x^2 (x squared key) - (minus) 5 X (times) x (key labled x,t,n) in between the ALPHA and STAT keys
now press the zoom key and select #6 - ZStandard (this will give you a standard zoom)
You should see a parabola drawn on the screen.
If you enter in some equation and do not see it on the screen, you can try zooming out (zoom key) or setting up your display window, using the window key.
This is where it helps to know where your x and / or y intercepts are.
From there, you can use trace to move around the graph, 2nd+graph (table) to see your x and y intercepts.
Dec 22, 2010 | Texas Instruments TI-83 Plus Calculator
Every thing is to large print and screen
Welcome to Fixya.
If the prints on your screen is large, it is possible that it is zoomed in. You can zoom out by pressing down CTRL key then press minus sign (number pad). This will zoom it out. If you want to zoom in again, CTRL key then press plus sign.
Please let me know if this is the fix you are looking for.
Cheers!
Nov 09, 2010 | Computers & Internet
I accidentally shrank my web screen and I don't know how to zoom back into normal size. Help
Hi!
To zoom in or zoom out your web screen.. here's what you need to do.
ZOOM IN: Press and hold Control key (CTRL), while holding Control key press plus sign ( + ) to make your screen bigger.
ZOOM OUT: Press and hold Control key (CTRL), while holding control key. .. press minus sign ( - ) to make your screen bigger.
Hope it helps you.
Much appreciated if you rate this help.. thanks
May 19, 2010 | Computers & Internet
Dont know which keys to press to zoom out
try the Fn key and choose option. Otherwise try a different computer to go to manufactures website and search support/ troubleshooting
Dec 07, 2008 | Computers & Internet
Acer Aspire One  PC Notebook Logo
241 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
