Question about Polaroid TLX-01911C LCD TV
How do i get the stand off my tv - Polaroid TLX-01911C LCD TV
First pop the base off by pushing in on the four tabs simultaneously and pulling it out... once you have the base off you will need a long phillips head screw driver to get the single screw inside the arm that is connected to the base loose. After that you can work the arm off and your stand will be completely removed.
Posted on Sep 26, 2010
CANN NOT SEEM TO MOUNT THE TV ON THE STAND PROPERLY
Mounting instructions are in with the setup instruction for the TV or TV Stand. Did a mount come with the stand, or is it a separate add on to the stand? In some cases TV Mounts do come as an option?
Feb 26, 2014 | Whalen Furniture Austen 3-in-1 TV Stand...
Looking for table top stand for Sony LED TV
Just try by any authorized dealers for Sony. If not available, check www.alibaba.com
Nov 27, 2013 | Televison & Video
Where can i get a LG 20LS7DC LCD TV STAND - 20" -
Tries websites like Amazon.com,Ebay.com to buy a new or used LCD or Plama tvs base stands.
Feb 25, 2011 | LG 20LS7DC 20 in. LCD TV
Looking for tv stand for 32" Insignia flat screen
  1. 32 TV Stand- Ship Free1700+ TV Stands Arranged by Size, Price, Color & More. Lowest Costs!
    Exclusive Deals - Gift Certificates - Best Sellers -Entertainment Centers on Sale www.tvstands.com
  2. TV Stand For 32 InchGreat Selection of Brand TV Stands. Free Shipping on Your Order Today! Google Checkout thesimpletvstandstore.com
Jan 28, 2011 | Insignia NS-RTV32 32" TV
HI how do I remove the tv stand part because i want to mount it?
After disconnect power/antenna/any AV wires, turn your TV. Look at back side of your TV (on TOP of Stand part). You should see some screws there. To remove your stand, you should unscrew them all. Then Hold your stand and pull UP your TV. Be careful with your TV once your stand taken apart .
Nov 28, 2010 | Proscan 19LA25Q 19 in. LCD Television
I just purchased a JVC 47'' LCD just need to know how to remove the stand. I have it hanging on a Unti do not need the stand.
1. remove the 4 screws on the back of the TV (these are located in the deep holes above the stand)
2. after the screws are removed, the TV will lift from the stand.
The stands sits inside the TV. after the screws are removed the TV will still sit on the stand. you (and someone else) will need to lift it from the stand.
Nov 10, 2009 | JVC LT-47X788 47 in. LCD HDTV
Try to mount TV to the wall and need to release the TV stand
To Display your LCD TV using a Wall Bracket:
If you decide to wall mount your LCD TV, always use a ULlisted wall bracket appropriate for the size and weight of the LCD TV: 32HL37/32HL37U/32HL17/32HL17U: 38.6 lbs (17.5 kg)
37HL17: 46.3 lbs (21.0 kg)
42HL17: 59.5 lbs (27.0 kg)
1) CAUTION: Two people are required for installation.
2) Unplug and remove any cables and/or other component connectors from the rear of the TV.
3) Follow the instructions provided with your wall bracket. Before proceeding, make sure the appropriate bracket(s) are attached to the wall and the back of the TV as described in the instructions provided with the wall bracket.
4) After attaching the appropriate bracket(s) to the wall and the back of the TV, remove the pedestal stand from the TV as described below.
Removing the Pedestal Stand
1) Carefully lay the front of the unit face down on a flat, cushioned surface such as a quilt or blanket. Leave the stand protruding over the edge of the surface. Note: Extreme care should always be used when removing the pedestal stand to avoid damage to the LCD panel.
2) Remove the jack pack cover on the back of the TV to expose the pedestal stand screws. The jack pack cover can be removed without tools.
3) Remove the five screws. This will allow removal of the pedestal stand.
4) Once you have removed all five screws holding the pedestal stand in place, remove the pedestal stand from the TV by sliding the pedestal stand away from the TV.
Sep 28, 2009 | Toshiba REGZA 32WLG66 32 in. Television
Taking stand off toshiba regza tv
forget the four holes on the bottom of the stand. Remove the five allen bolts on the back bottom of the tv-not the stand. Yank on stand and metal plate slides out with stand.
Jan 25, 2009 | Toshiba REGZA 47HL167 TV
Mounting to TV Stand
there are two types of stands, some are wall type which needs to be mounted using rawl bolts, nuts are suppose to hold a stand, some are ground stands which are suppose to be put on a flat surface in order to balance.
Jul 29, 2008 | Panasonic TH-50PZ77U 50" Class Plasma HDTV
Open Questions:
See all Polaroid TLX-01911C LCD TV Questions
Polaroid TLX-01911C LCD TV Logo
125 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
