Question about Magic Chef CMV1000B Microwave Oven
Where is the fuse located to a magic chef microwave oven model number mco160uw
5 Suggested Answers
MicrowaveSvc
  • 9098 Answers
SOURCE: Replacing the fuse of a MCO160UW
A microwave can be dead for many reasons.
It may be the fuse, which is usually located on the floor of the oven behind the control panel or between the door switches.
If the fuse is good, it may be an open thermostat or thermal cutout (TCO) / thermal fuse on or near the magnetron or on top of the cavity / body of the oven.
If it goes dead for a while during or after cooking then comes back on, the magnetron is probably overheating and causing the magnetron thermostat to open.
Then when it cools, it closes the circuit and allows power through again.
When checking thermostats, if it has a hood fan thermostat, that should read open, as opposed to the others, which should read closed.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If it goes dead or blows the breaker (or GFI) when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
If it's intermittent or random, it may be a bad connection, usually on the control board or a loose fuse holder, or even an intermittent fuse.
You should do a continuity test on the fuse while it's in the holder (with the microwave unplugged, of course) then turn the fuse by hand or take it out and put it back in, then test it again.
If you remove the fuse, then press the meter leads against the ends, it can allow internal contact to be made and make a bad fuse appear to be good.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa.
There may also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Posted on Jul 19, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: my microwave magic chef mco160uw
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If it still fails, you have a failed keypad.
This can be dangerous, and you should keep it attended to when in use (as with any microwave) and unplugged when not in use.
Since it's less than one year old, it should be fully covered under warranty. I'd suggest contacting the manufacturer to get it fixed free.
For more help from Magic Chef / Ewave see here or their contact page.
Posted on Aug 08, 2008
  • 72 Answers
SOURCE: turns on and off itself
If unit heats your problem is in the control board, most commonly would be one of your door switches
Posted on Feb 04, 2010
  • 6771 Answers
SOURCE: have a magic chef mco160uw microwave. Had a recent
No! there is no reset, the power surge has more than likely damaged the keypad controller, and on the back is a circuit board that has the microprocessor with additional components that controls the vital areas of the microwave oven. If that is gone, it is cheaper to replace than to repair.
Posted on Feb 06, 2011
Testimonial: "thanks for your info."
WHERE IS THE FUSE LOCATED ON MY MAGIC CHEF MCO165UW MICROWAVE
Unplug your microwave and turn it around and remove the screws holding cover on and then remove the cover. Look for where the power cord goes into the back of the unit and follow the black wire from the cord to where it ends. It should stop an either a circuit board or a fuse holder. Make sure that you replace the fuse with the same amperage fuse as what you take out. You will find the amp rating stamped on one of the silver collars on each end of the fuse. Good luck!
Mar 02, 2015 | Magic Chef Microwave Ovens
My Magic Chef microwave oven blows fuse when i open door
If you're blowing fuses from opening the door that is the sign of a electrical short . You'll need to call a electrician to check it out. Changing the fuse in this unit can kill you. There's a capacitor that holds stored electrical energy that is dangerous. My good friend died from trying to change the fuse in his. Get a professional to check it.
Feb 05, 2015 | Magic Chef MCO160UW White Over-the-Range...
Where is fuse located, magic chef mco153sf microwave oven
fuse-located-magic-chef-mco153sf-4e5eoo02uytabw1vwgixtmyx-2-0.jpg fuse-located-magic-chef-mco153sf-4e5eoo02uytabw1vwgixtmyx-2-2.jpg
Cylindrical fuse is located inside a cylindrical casing (approx. 2 inches long), found suspended amongst the wiring.
The fuse is NOT fixed to a circuit card nor another fixed point in the microwaves, as is common with other microwaves.
Apr 13, 2012 | Magic Chef Microwave Ovens
No power to my Magic Chef over the stove microwave oven. Is there a fuse that can be replaced, and where if so?
There should be a fuse and one or more thermostats or thermal cutouts.
We would need your full model number.
Nov 30, 2011 | Magic Chef Microwave Ovens
Have a magic chef mco160uw microwave. Had a recent
Feb 06, 2011 | Microwave Ovens
We have here below the link with the parts layout of your microwave
oven model. The fuse is part no 15 Line fuse
Part Number: AP3119665
made by WHIRLPOOL
Which as you can see is
located in the internal control parts area.
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5168435&diagram_id=28370772#d28370772
Dec 19, 2010 | Magic Chef CMV1000B Microwave Oven
Turns on and off itself
Feb 04, 2010 | Microwave Ovens
MCO160UW goes dead after 3 minutes
I returned the item to Home Depot and they took it back no questions asked.
Nov 30, 2008 | Magic Chef CMV1000B Microwave Oven
MICROWAVE WILL ONLY HEAT ON CERTAIN SETTINGS. how do i set the heating instructions?
I have a Magic Chef model MC0160UQ. Within 2-3 minutes of heating food it shuts off completely for about 5min. Also, when I select the low fan it does not work, however the high fan works. Please assist with these issues if possible. Am I able to fix or adjust the magnetron myself since it may be overheating? or what should i do?????
Jul 18, 2008 | Magic Chef CMV1000B Microwave Oven
Magic Chef CMV1000B Microwave Oven Logo
271 people viewed this question
Top Magic Chef Microwave Ovens Experts
William Miller
William Miller
Oloyede Monsuru
Are you a Magic Chef Microwave Oven Expert? Answer questions, earn points and help others
