Question about Canon imageRUNNER C6800 Copier
Canon ir c6800
The coper does 1 or 2 set ten it stops, it asks to be turned off and on, the problem presist anyway giving E000020-03a8
    Genius:
  • 3,587 Answers
Not surprising..sounds like either your copier is needing some internal diagnostics service(read that digital control panel board) or it's just skipping, and needs to be reset to defaults..suggest you use a qualified Canon person locally on both of these items.
Posted on Apr 26, 2008
  • Patrick Michaels
    Patrick Michaels Apr 26, 2008
    this is a complex unit, and not for the unwary to attempt to learn on the fly
Canon ir c6800cn code 0000-0043
sir; i have a canon imagerunner6570 model machine,it was coming repeatly an error code e840 . what is the problem?
pls give me a solution.
thank u
Jun 25, 2011 | Canon imageRUNNER C6800 Copier
Canon IR c6800 gives me error code E000014 - 0001
This code means that the fixing motor can't get enough power due to the fixing roller is not smooth anymore, You will have to replace the fixing roller.
Dec 22, 2010 | Canon imageRUNNER C6800 Copier
Canon IR c6800 department password
You can just reset the password if you dont have it by doing this,
press additional functions
2 + 8 simultaneously
copier
clear
right arrow button
PWD-CLR
ok
turn off then on the power switch on the right hand side of the copier.
Dec 10, 2010 | Canon imageRUNNER C6800 Copier
Canon iR C6800 prints leading and trailing blank pages
There is an option in the print driver to print a separation page (typically just a blank page unless you specify otherwise) so that each person's print jobs can be differentiated easily.
This option probably got enabled somehow on her PC. Have her go into the print driver's properties (right click on the Canon in the list of printers and select Properties) and look for the option that says separation page or separator page and deselect it. Then click Apply or OK, and it should be good.
Jul 06, 2010 | Canon imageRUNNER C6800 Copier
How to know ip adress for Canon ir c6800
Network settings are in the additional functions> system settting > network settings. If your printing to the copier the ip address should be there in the network settings.
May 13, 2010 | Canon imageRUNNER C6800 Copier
How to know IP adress for Canon ir c6800
On the control Panel
Press Additional Functions Key.
Press Report Settings
Print List should be 2 rows of choices/ Select Network and print list. TCP/IP will be on the print out.
To Change the IP Address
Press System Settings
Press Network Settings
Select TCP/IP Settings
Enter New Address or turn DHCP on
Back out by using reset key on control Panel.
Be sure to re-Power the copier by turning off/on at the main power switch on the right side of machine or any setting will not take.
Mar 22, 2010 | Canon imageRUNNER C6800 Copier
IR 5870Ci Errors: E000748-4021 & E000020-03a8
E748-4021 means the SERROR signalof PCI has been detected
solution:disconnect and then connect PCI board if the fault persists ,replace it or the main controller pcb
May 18, 2009 | Canon imageRUNNER C6800 Copier
Canon imageRUNNER C6800 Copier Logo
205 people viewed this question
old marine
old marine
