Westpoint WTA 108 washer spin dryer (Laparisienne)- how old and are parts still available. What would a good used one be worth ?
2 Suggested Answers
  • 489 Answers
SOURCE: only spin dry available?????
Yes, turn on the machine, push the button for spin to select the speed and then press start.
Posted on May 02, 2008
Dryer doesn't power-on.
Simple answer: way too much dryer lint. Worth cleaning out.
Mar 04, 2018 | Bosch Axxis WTA 3510 Electric Dryer
ASKO 7000 series washer drum stopped rotating. Smelled of burning. Could not turn the drum by hand. Guessing a burned out bearing as electronics and pump still work and are trying to turn steel drum. ...
check inside your washer for nails or other objects . I already seen a nail fall down in one of the basket holes and the nail stuck into the outer tub not allowing the basket to spin. If you dont see anything in the basket holes, then it is your bearings. The burning smell is coming from your belt. The motor is spinning but your basket is not. It is cheaper to buy a new washer. In ordered to fix your washer you have to rebuild it. The bearing are built into the outer tub of the washer.
Jul 13, 2011 | Asko 8005 Front Load Washing Machine
Looking for manual for the bosch wta 2000 tumble dryer. thank you.
I've made a PDF of the Bosch WTA2000 Tumble Dryer User Manual and (hopefully) it will be available on this link in case anyone else still needs a copy, as the original request above is a bit old now.
It's a leeeettle blurry as I should have used a higher dpi when scanning the pages, but I can't be bothered doing it all again. I think it should be sufficient for purpose anyway.
https://onedrive.live.com/?cid=5D5DECF4115C2175&id=5D5DECF4115C2175!189
Nov 21, 2010 | Dryers
Our 9 year old WFK 2401 needs >$900 repair (drum bearing bad=needs both inner and outer drum; pump motor squeals.) But dealer says we must replace BOTH washer and WTA 3500 drier (which if fine) because...
yes he is right!!! ask yourself this,,,,after 9 years have you had your money worth out the dryer yet? and the washer???
go on treet yourself,,,buy a new lot,,,you know you wont to?
and what a slap in the face for all your friends,,,"look what i got!"
rasssssp!
Aug 28, 2010 | Bosch WFK 2401
Washer/Dryer is not spinning
Friend,
ngfam1 At your service!
Sometimes this can happen when the connector from the transmission to the drive of the agitator is worn and needs to be replaced.Similar to the drive shaft of a rear wheel drive v-8 car!
Could make this sound first, like a knock,knock,knock or klack, klack,klack
OR,SOMETIMES JUST NO SOUND AT ALL AND JUST NOT CONNECTED FROM THE TRANSMISSION TO DRIVE THE ROTATION OF THE TUB!
This means you need parts! and service!
How old is the washer if it is 10 years old or more I recommend being prudish about investing a lot of money in to it!
The newer models are so much more energy efficient, that they save you water,gas or electricity And detergent too!
They can pay for them selves in energy savings in a few years!
If so here is a good company that's found nation wide.
A&E Factory Service
A&E has schedulers available to take appointments 24/7
And they do warranty work too, for most manufactures!
1(800) 905-9505
You will be fine
Bless You ngafm1
PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OFF!
Aug 30, 2008 | Smeg WDI12 Front Load Washer / Dryer
Drum on washer wont spin
It's not worth fixing if it's 10 years old or more, better off replacing it with a newer machine which will be much more efficient!
The belt is gone and or snapped off or the transmission is shot! And it's not worth replacing an old transmission.
If it's 10 years old or more buy a new one
and save your money ,fixing it is a waste!
Not worth the money to fix!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Try You should call service.:
A&E Factory Service
1-800-905-9505
Nation wide / 7days/24 hours
Good work
Please give me a "Solution Solved Rating", in this site!
Thank You
Neil
Jul 28, 2008 | Frigidaire FEX831CS Top Load Stacked...
Dryer won't dry
I also have one for several years now.
I also had problems with dry function at first.
If your washer is still covered by warrenty, call them. They were very friendly and helpful and came out and made service call at no charge.
My problem was that I had attached the discharge hose to an existing discharge pipe that connected to the sewer. This pipe was too narrow and burned out the condenser.
Also, try cleaning out the lint filter on the lower right side of front. Put a cookie sheet under the opening to catch about a cup of water that will come out.
Good luck,
wsf
Mar 30, 2008 | Malber WD1000 Front Load Washer/Dryer
Kenmore stackable
Dryer probably element or thermostat, washer sounds like a suspension arm collapsed. Price up the parts & then decide if its worth it! Regards
Apr 09, 2007 | Kenmore 98702 Stacked Washer/Dryer
Washing Machines Logo
130 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
