Question about Delta Faucet Delta RP17453 Pull-Down Diverter Tub Spout
I have a garden tub w/o a shower attached. However, the fixture in the tub is the Delta pull down diverter (dont know why they would put that in a tub w/o a shower). Anyway, the diverter was pulled down and now it is stuck and the water wont come on/or out of the faucet. Any solutions please?
  • 43,501 Answers
If it was me... I would replace that spout...
the spout either is threaded on or it has a set screw on the bottom at the back that you loosen and then pull the spout off by pulling straight away from the wall...
Check and see if the spout has the hole for the set screw...if not then twist it counter clockwise and it will turn off...
then repalce the spout with a new one with out the diverter...
heatman101
Posted on Aug 05, 2010
I have a delta single handle tub fixture the shower diverter pops out all the time
Hi Jeff sorry about your problem. Just wanted to ask about what you mean pops out. When you try to get water to the shower head the spout "pops out" and water just goes back to the tub? If this is the case it sounds like your diverter on the spout has failed. I favor the Delta one that you have to pull the chromed plastic area where the water discharges instead of the one with the knob you have to pull up to get it to divert the water to the shower head.
These both are available at your local plumbing supply store not the big box store always but I have noticed them at the HD in Honolulu. I hope this helps if not a photo goes a long way. Dave.
Sep 21, 2014 | Home
I have a Delta shower assembly with a pull-down diverter. When I engage the diverter for the shower, half the water seems to make up to the shower and the other half is forced through the back of the...
One of 2 things is happening. Either the o-ring is shot, or you have a hairline fracture of the plastic around the brass adapter. The o-ring is a #18, but if there's a crack in the plastic you'll need to replace the spout.
Oct 03, 2010 | Delta Faucet Delta RP17453 Pull-Down...
I recently move into a condo that has a Delta single lever Series 1400 single lever bathtub fixture. The bathtub has a shower nozzle that looks like it has been used. I cannot find where there is a button,...
Is there a button on the tub filler? How about the spout on the tub, does it lift up? If there is not a tub spout then it should be shower only, if it has a tub spout it has to have a lifter of some sort, the foto I found showed the little button lifter. Hope this helps.
May 29, 2010 | Delta & Single Handle Shower Faucet
My delta faucet pull down diverter tub spout is
It sounds like it could be manufacture defect. Take it back for a new one.
Sep 28, 2009 | Delta Faucet Delta RP17453 Pull-Down...
Pull down shower diverted works, but allows bypass into tub
The diverter is supposed to leak a little bit, so it will disengage after you turn off the water. If the water is leaking out a little, that's normal. But if it is really leaking out you may need to replace the entire spout.
Aug 11, 2009 | Delta RP17453SS Standard Diverter Tub...
Water sprays out the diverter
Remove hot/cold button in handle, remove screw/pull off handle. Remove the two screws in the wall plate/remove plate. Use a wrench to remove the diverter assembly. Get new diverter assy and reinstall eveything. You don't need to turn off the water.
Jun 09, 2009 | Delta Faucet #RP320 Divert Assembly
I just moved into a new place with Delta shower and tub. However, I have no idea how to divert the water to the showerhead. There is nothing to pull up (which is what i usually see in hotel tubs) to divert...
On the bottom of your tub faucet is a ringed part that is about a 1/2 wide. Turn the water on, grasp that firmly in your fingers, and pull it straight down. Your faucet should come on.
Sirwriter
May 15, 2009 | Delta Faucet #RP320 Divert Assembly
Delta diverted spout is stuck! Can't pull it down
You probably have lime deposits built up which won't allow you to pull it down anymore. Try spraying lime away on it and use an onld toothbrush and work it up in there. If this doesn't work, you can replace the spout with a generic one. The spout should just twist off. Sometimes they can be stubborn. Hopefully this helps.
Apr 03, 2009 | Delta Faucet #RP320 Divert Assembly
Delta Faucet Delta RP17453 Pull-Down Diverter Tub Spout Logo
264 people viewed this question
Top Delta Faucet Plumbing Experts
Steve Wood Plumbing...
Level 1 Expert
joeiaaz
Level 1 Expert
doconnell13
Are you a Delta Faucet Plumbing Expert? Answer questions, earn points and help others
