Question about Epson EMP-S3 Multimedia Projector
My projector has an operation lock which prevents me from turning the projector back on.
    Novelist:
    Champion:
  • 225 Answers
  • faith_love_p Aug 06, 2010
    sorry my cuzin told you the wrong name of my projector my projector is an epson projector powerliite Emp s5 the full operation lock is on and the projector is turned off now when i plug it in its goes right to standby and does nothing else and i cant do nothing to it cause there is no remote i tryed holding and pushing all the buttons on the projector and kept it unpluges for a few hours and i have had no luck and the standby light is orange by the power button its solid orange. please and thank you for you help
I hav e a vivitek 1080hd projector and it turns on for a couple of seconds then shuts off. it blinks a code of 62. 6 blue blinks of the power button then 2 red blinks of the ready button
That code indicates a fan-2 error. These projectors generate a lot of heat and depend on air circulation to keep everything cool. Make sure nothing is blocking the vents on the projector. Check the fan for lint and dust. Make sure fan spins freely and is operating correctly. Keep projector away from any other heat sources. Hope this helps.
Jan 01, 2014 | Vivitek H1080 H1080FD DLP Projector -...
How to remove a Croussel from Ektagraphic AF1
First of all, make sure the LOCKING RING is in position on the tray & locked! This will prevent all the slides from falling out when you remove the tray. Next, place a quarter (or a dime or a penny) in the SLOT in the HUB of the projector. Turn the coin to release the Emergency Latch Release and lift the tray off. Flip the tray upside down. Remove the jammed slide from the optical gate of the projector (inspect it for damage - "dog-eared" slide corners cause this kind of jam) and re-insert it in the slot of the tray from the underside (now facing you). Now rotate the tray until the pointing arrow and the notch on the bottom of the tray align. At this point the tray should be back in the "Zero" position and can be re-installed on the projector. I have attached copies of Kodak instructions for this, as well. Good Luck !! Jim4d786888-c152-4bd3-b086-29e6f8e29e37.jpg409ae3e8-80fd-44c8-820b-23fd94def009.jpg
Mar 14, 2013 | Kodak A Ektagraphic 35mm 140 Slides Rotary...
My PDJ6553w projector turns on, giving me 2 min picture, turns off and the fans goes crazy
sony lcd turns on, giving me signal and picture in 2 minutes, then suddenly turns off and the fans goes crazy. what can I do to prevent this? I have tried to reset the projector and switched the powermode to normal, but this didn't help.
Feb 16, 2013 | Viewsonic Corporation Viewsonic PJD6553w...
Need to remove bad lamp from the HC100 projector
1. Reverse the projector gently.
2. Loosen the screw (a) using a Phillips screwdriver (+), and remove the lamp cover (b).
3. Loosen the screws (c) using a Phillips screwdriver (+).
4. Pull up the handle.
5. Pull out the lamp box by the handle while holding the projector.
Pull the lamp box out of the projector slowly. If it is pulled out quickly, the lamp may break scattering
glass fragments.
Do not spill liquid on the removed lamp box or do not place it near any flammable object or where children
can reach to prevent injury or fire.
6. Load a new lamp box securely into the projector in the right orientation.
7. Put the handle back to the original position.
Make sure that the handle is locked.
8. Tighten up the screws (c) using a Phillips screwdriver (+).
9. Tighten up the screw (a) using a Phillips screwdriver (+) to secure the lamp cover.
Jul 20, 2011 | Mitsubishi HC100 DLP Projector
We have a indicator "
Clean or replace the air-filter after every 100 hours of use to prevent overheating, which could damage the projector.
1 Make sure the projector is cool and the power cord is unplugged before beginning. 2 Vacuum the air-filter.
WARNING: Never operate the projector without the air-filter; doing so will damage the projector.
Feb 27, 2011 | ViewSonic PJ750 Multimedia Projector
Miss operation to launch "Control
When the control panel lock ON of the projector so that the projector can be operated only with the REMOTE CONTROL.
If you loos your remote control then keeping the POWER key on the projector control panel pressed for 10 seconds turns the projector ON when it is in standby mode, and turns the projector to standby mode when the power is on. If you press and hold the MENU key for about10 second when the power is on the lock will be released and "panel key lock" is automatically set to "OFF"
Feb 23, 2011 | Sony VPL-CX70 Multimedia Projector
When i turn on the video projector and send me this message"the panel keys are locked "
Your projector key panel locked you have two option to operate the projector
1 . Use remote control press MENU the menu window displayed.
use DOWN ARROW key and select SET SETTING.
press ENTER
use DOWN ARROW key to select PANEL KEY LOCK.
press RIGHT ARROW key to OFF the panel key lock
press ENTER and then press MENU key to exit the menu.
now you panel keys are working
2. If you loss your remote control then;
When the key panel lock is ON keeping the power key on the projector key panel pressed for 10 seconds turns the projector ON when it is in standby mode, and turns the projector to standby mode when the power is on. If you keep pressing the MENU key for about 10 seconds when the power is ON, the lock will be released and "panel key lock" is automatically set to OFF.
Feb 05, 2011 | Sony VPL-CS7 Multimedia Projector
The projector does not operate the "lamp" led blinks in green and turn red after one minute. The switch on button does not replied.
either it's overheated or needs a replacement bulb.Do not cover this unit with anything as it will prevent cooling down..
Jul 27, 2009 | Philips ProScreen 4750 Impact Multimedia...
Displayed massege to check air flow
With most projectors there is a foam air filter behind a grill that is the opening to the cooling channels. A fan ensures air flow to cool the lamp, etc. This filter prevents dust from gumming up the works (and depending on design) may prevent dust getting into the optics. As the filter gets dirty it gradually cuts off the air and at some point a protective circuit kicks in and turns off the lamp.
If the projector is on you will feel a stream of hot air coming out of the exit vent. Projectors vary in terms of amount of air flow, so its difficult to define what is normal for a specific model. However, you can simply hold a hand in front of the vent and see if there is air flow (It will be hot air so, careful). If there is a "good" stream of air things are fine, but if only a very light flow is felt the filter may be dirty.
If the filter has not been cleaned or replaced recently make sure the projector is turned off and cooled down then take off the inlet cover and remove the filter. Clean or replace per the instructions for the projector (and periodically as defined .. but taking into account the operating conditions). Once cleaned turn on the projector and feel the "normal" air current for future reference.
Heat is one of the major causes of projector failure, so make sure cooling vents (inlet and outlet) are not obstructed and filters are kept clean
Oct 02, 2006 | Hitachi CP-S240 Multimedia Projector
Epson EMP-S3 Multimedia Projector Logo
633 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
