Question about Homelite Mighty Lite Lawn Trimmer
Homelite weedeater only runs with choke half on
  • Homelite Master
  • 7,482 Answers
Sounds like you will need to clean your carburetor.
Sometimes you can get by with priming it a few times, and letting it run a few times like that and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
If the mower/weedeater is over a couple years old, then I also recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
When you clean your carburetor and remove the jet screws, You will first seat the jet screws and count the number of turns it takes to seat the jets from their original position.
That way when you go to put the jets back in, you know how many turns they were in/out.
Please do not forget to rate me,
Thanks
Good Luck,
I hope this helped
Posted on Aug 11, 2010
The problem sounds to me like you need to clean the spark arrester. It will be on the muffler just a little cover with three screws holding it on. To check if this the problem just take the cover off and the metal screen will have all kinds of funk on it. Just crank the trimmer with it off and it will crank up just like new again. If this is the problem just clean the screen really good and put it back together and your done. 10 minute job at tops.
Posted on Aug 30, 2010
4 Suggested Answers
boscia
  • 163 Answers
SOURCE: Engine dies when excelerating - more gas
check the fuek lines for hole and leaks, check the fuel filter and clean if necessary. remove the carbuerator and inspect the gasket; it should be soft and flexible, if it seems hard or brittle replace it. clean the carb with carb cleaner sray (available at any local auto parts store) and compressed air. make sure you get inside the small fuel rail holes. if that doesn't work have the carb repaired at a service center or replaced.
Posted on Nov 28, 2008
#1 Taper
  • 1041 Answers
SOURCE: Homelite gas trimmer will not run without half choke and throttle
You need to disassemble the carb. and spray with carb. cleaner. If you need tips on how to do this, just let me know. You may need a new carb. kit as well, but we won't know that until you first perform the first step, or if the carb. parts are more than 3 years old. If they are, then go ahead and buy the carb. kit and replace the parts.
Jim
Posted on Jun 02, 2009
hunter19_46m
  • 7482 Answers
SOURCE: Homelite trimmer will not start.
Check your fuel filter if you have one, and also make sure you are using fresh fuel and oil mix...to the right mixture and not too much oil.
If the mower/weedeater is over a year old, then I recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
Sounds like you will need to clean the carburetor or replace your carburetor internal rubber parts like the diaphgram and O rings.
Be sure to use compressed air to blow out all the fuel and air passages.
Be careful when blowing out the passages, because there are sometimes small rubber type seats in the bottom of some of the passages.
Sometimes you can get by with priming the carburetor or using starting fluid and letting it run a few times like that and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
Keep in mind that the float for the carburetor must be level when you go to reassemble the carburetor or follow the instrucitons you get with the carburetor kit.
When you clean your carburetor and remove the jet screws, you will first need to lightly seat the jet screws.
But before you lightly seat the jet screws count the number of turns it takes to seat the jet screws from their original position.
Be sure to mark the turns down on a piece of paper.
That way when you put the jets back in, you know to lightly seat them first and then turn them back out to their orginal position before you started.
This is a FREE answer,Please rate me
Posted on Oct 16, 2010
My murray weedeater want run off choke why?
Carburetor needs to be rebuilt. I won't even think twice about. the diaphram is on it's way out.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/anthony_e4f197748c31eabd
Aug 29, 2017 | Weedeater Garden
How do I start a weedeater fb25?
Press primer bulb 6 times
Move throttle lever to start position
Move choke lever to full choke position
Pull starter rope sharply until engine attempts to start, but no more than 5 pulls.
Move choke lever to half choke position. Pull starter rope sharply engine runs. If engine hasn't started after 5 pulls, repeat all steps above.
After warming up for 10 seconds, move choke lever to run position.
Manuallib.com has a manual for this model available for free download
Oct 20, 2014 | Weedeater Garden
My homelite string trimmmer will not run when choke is run position. it will run, but not at full throtle, when choke is set between full choke and half-choke.
you've got a fuel system issue , most likely carb problem, if this a newer trimmer it will likely need the carburetor replaced or adjusted, also check for cracking fuel lines or signs of old fuel varnish in the tank
May 31, 2010 | Homelite Mighty Lite Lawn Trimmer
Weedeater dies when you open choke
After you start it and are in the second stage of the choke (half choke ) let it run for awhile until it warms a bit then try openning choke and going to full throttle.
May 21, 2010 | Poulan 25cc 2-Cycle Gas Powered String...
Carb settings mixture jets on a homelite weedeater st155
ther is no set setting but to get it to run so it can be adjusted. lightly close the high off then open the low about two turns. try to start if starts slowly adust the low screw till it runs normal with the choke all the way off. then start to add throttle while turning the high out till regiured rpms ar reached with no misses. this takes awhile even fo a seasoned mech and may require several attempts
Dec 24, 2009 | Garden
Jim
Jun 01, 2009 | Homelite Mighty Lite Lawn Trimmer
Nov 17, 2008 | Homelite Mighty Lite Lawn Trimmer
Homelite Mighty Lite Lawn Trimmer  Logo
1,626 people viewed this question
Top Homelite Garden Experts
Jim Parker
Jim Parker
roeb
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
