Question about Philips 42PFP5332D 42 in. Plasma Television
When plugged in blue light on front flash's, unit makes tick tick noise, will not power up, green light flashing in back
How do u fix this problem
Posted on Aug 31, 2010
No power output or display.green standby light flashes.
Sounds like either a blown mainpower fuse or the thermal fuse for the power transformer. If the protect circuit was kicking in, the display would light up, but then turn off with a red blinking light. the green light with no display means the transformer is not getting power.
Dec 31, 2013 | Denon Avr-1610: 5.1 Ch A/V Home Theater...
My kobo wont turn on
How to Fix Kobo eReader Locked up Frozen or Not Responding
1)Slide power switch to right and hold for 15 seconds and release
    2)Slide power switch to right again and hold till green/blue button near switch lights up.
Dec 05, 2017 | iPhone Apps
Turned compaq off to clean it with air took off side panel put it back together now it wont turn on and there is a green light in the back flashing and making a ticking noise dont know what to do
power system off, unplug from power, while unplugged, press and hold power button for 10 seconds to discharge any residual power. Wait 3 minutes, plug system back in and try again, see is same issue occurs. IF system boots, great. If not then likely the power supply has failed.
Dec 26, 2010 | Computers & Internet
Flashing blue light on external WD hard drive & not recognised
sounds like you are using the wrong power supply. Check the amp output on the power plug you plug into the wall make sure its the same as the amp input of your external harddrive
Jun 01, 2009 | Western Digital My Book Essential 1TB...
Green light flashing on back of unit near power cord also green light flashing on motherboard near power supply plug in.
I would suggest trying to replace the power supply. If that does not fix the issue, i would need to hear more about the computer.
May 06, 2009 | Sony VAIO VGC-RB40 PC Desktop
No picture
hi..make sure the cable or dvd RCA inputs red,yellow
and white inputs are proper.There may be some loose
connections.
check it out..
thank u..
rate me..
May 05, 2009 | LG 42LC2D 42 in. LCD HDTV
Hp wont turn on flashing green light in back an flashing blue light in front.
open your cpu remove the ram clean it put it back your problem will be sloves
Jul 16, 2008 | HP Pavilion a1250n (EG194AA) PC Desktop
LG LCD TV Standby Light Flashing Red Continuously
I have had this same problem twice in the past 3 months. So far both times I've been able to get it back after a week or two. I'm not sure what works, but unplugging and detaching the antenna and cable and waiting a few days seems to be the key. In both instances, I unplugged it for a few days then plugged it in for a few days and repeated the processes until I eventually got the steady red led. Both times prior to the red led the led would flash red then green and make a clickiing noise for several hours before I was able to get it working again.
Apr 14, 2008 | LG 26LX1D 26 in. LCD HDTV
Lcd sharp tv flashing green light
Try unplugging the unit and while unit is unplugged hold the volume up button and channel down buttons down and while depressing both buttons plug the unit in. Let go of the buttons and the unit should come on in the service mode. There will be a small k on the screen. With the sharp remote press the channel up button once. This should bring up a menu that will show a lamp error line. If the lamp error is = to 5 the unit is in lamp error shut down. User channel down to highlight that line and curser right arrow to highlight the lamp error #. Hit the enter button to clear the lamp errors. Now unplug the unit and let it sit for a minute and plug back in. I hope this corrects the problem. If the unit does not come on by doing this or if it does and you do not find lamp errors the power supply pcb may have been damaged by the surge.
Jan 06, 2008 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
Philips 42PFP5332D 42 in. Plasma Television Logo
230 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
