Question about Husqvarna Garden
I want to replace the head and piston on my Husqvanna 575 XP chain saw : 6 years old : with a new Husqvarna head and piston from a HUsqvarna 576 XP kit will it fit.
  • 252 Answers
Here is web site
http://www.partstree.com/parts/?lc=husqvarna&mn=576+XP+EPA+%282009-01%29&dn=90_07_0045
576 xp 2009 parts should fit on 575 xp to s/n up to 081700001
but do x ref on parts 1st before purchase
these were on the 2009 576 - service update #1 in that list
check stroke and piston sizes carefully
cheers
Posted on Aug 08, 2010
Chain saw runs for 15 min then cuts out ?
could be several things, first always inspect the cylinder for scoring, if there is scoring there will be compression loss once the saw warms up, second check for fuel hose damage either in the tank or out side of the tank, third, ignition coil could be shutting down after it gets hot.
Jul 14, 2014 | Husqvarna 362 365 371 372 385 570 575 576...
Husqvarna 365 backfireing
Check your spark plug for 'whiskering' (tiny strands of carbon collecting across electrodes) and clean and re-gap. If this not the problem, check carburettor fixing to engine - may be drawing air through failed sealing gasket. Good luck!
Jun 09, 2012 | Husqvarna 362 365 371 372 385 570 575 576...
Looking for a repair manual for husqvarna 136 chainsaw
Below is the link to the Husqvarna website where you can download a repair manual for free. Click the link and just find the year of your chain saw and you are good to go!
http://www.husqvarna.com/us/homeowner/support/download-manuals/?query=136&types=O
Oct 18, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Piston seizure in Husky 359 chain saw-how to remove old top end, evaluate damage and install new piston and ring or all new top end.
Probably going to be a paired piston&cylinder http://www.ebay.com/itm/HUSQVARNA-359-357-CYLINDER-AND-PISTON-KIT-47MM-/140580138020
you will need to replace both.. remove your muffler and see scorched(black streaks) piston, fused rings. Remove air filter and carb to see scored cylinder wall(on hot side)
Aug 23, 2010 | Husqvarna Chain Saw 20" Bar
How to replace a oilker on a 575 husqvarna
The video is a fantastic guide. R² Drive Link Outboard Clutch by Drivelink.blogspot.com
http://www.youtube.com/watch?v=cdqkIuVNUQc
  1. Check the IPL for your saw to see if any special tools are needed. Poulan (Craftsman, Jonsered, Husky) clutch removal tool part number 530031112 if needed, is under $5 from many sources (look at the visible area between the weights if 2 small round sockets are visible you need the tool).
  2. There are metal piston stops available, when square (almost never) with the piston top these work well, if not square they have been known to punch through the piston. I suggest a length of nylon rope (nothing left behind) be used instead of the piston stop (retain 6" ± so you can remove it). Make sure the piston is near the top of the cylinder before feeding the cord or it can fall through the exhaust port and damage the piston as it rises.
  3. Everyone I have ever removed had a left handed thread (tighten it to loosen it).
HusqvarnaUSA.com
Enter the 3 digit model number (no XPs, Es, just the numbers)
Serial number decode – useful when downloading IPLs and Manuals
06 1500198
06 = year produced – 2006 (single digit before 2000)
15 = week produced - March
00198 = 198th unit Husky produced that week
HTH
Lou
Jan 23, 2010 | Husqvarna Garden
I need to replace the chain sproket on my Hsuqvarna 345e chain sa
It has an out board clutch, please view this it is essentially the same.
  2. There are metal piston stops available, when square (almost never) with the piston top these work well, if not square they have been known to punch through the piston. I suggest a length of starter cord or nylon rope be used instead of the piston stop (retain 6" ± so you can remove it). Make sure the piston is near the top of the cylinder before feeding the cord or it can fall through the exhaust port and damage the piston as it rises.
    Let us know how it worked for you.
IPL and operator's manual download
HusqvarnaUSA.com
06 1500198
You may find detail B beneficial. HTH
Lou
Dec 17, 2009 | Husqvarna Forest & Garden No.967012396 345...
I have a Husqvarna 445 chain saw and it does not get enough oil to the bar and chain. I have to stop saw after about 10 minutes of cutting because it freezes the chain so I remove bar and chain clean out...
Your Manual nor IPL mention an oiler adjustment..
445 IPL (may not be your saw)
Is this the original bar? A longer bar requires more oil and your saw is not equipped to supply it.
http://weborder.husqvarna.com/order_static/doc/USA/2007/I07000/I0701086.pdf
Detail B (Clutch/Drum/Oiler)
We are seeing many of these does not oil/oils to much problems with these no adjustment models. I recommend you contact Husqvarna, there may be an unannounced recall/repair. If they aren't willing to help you consider contacting your Atourney General and the BBB.
Contact Husqvarna here:
http://www.husqvarna.com/us/homeowner/support/customer-support/
It has an outboard clutch, the oil pump is behind it. If you attempt a repair this will be helpful.
  3. Everyone I’ve ever removed had a left handed thread (tighten it to loosen it).
Source for Manual and IPL:
HusqvarnaUSA.com
Serial number decode – for use with IPL
06 1500198
Nov 24, 2009 | Husqvarna Chain Saw 20" Bar
Looking for fuel mixture for Husqvarna chain saw. Help please!
It is either 25:1 or 50:1 depending on the model and your location.
Oct 03, 2009 | Husqvarna Garden
Fuel Mixture Husqvarna 455 Rancher Chain Saw
Page 17 of your Operator's Manual says 50:1.
Fuel/Oil Mixture
  1. Use a quality 2 cycle oil and mix it to the OIL supplier's recommended ratio. Today I use Stihl 2 cycle oil mixed @ 50:1 in a Pioneer that I purchased new in 1980. There are no gouges or scratches on the piston or cylinder and I have no carbon build up on the piston top. The manual (on stone tablets) recommends 24:1. Over the years the mixture has leaned from 24:1 (Saw Recommendation) to 28:1 (Lawn boy mower recommendation) to 32:1 (Oil provider 8oz/2gal - used for many years) and finally the last 5 (±) years 50:1 (Stihl 2.6oz/1gal)
  2. Most gas in the US of A contains ethanol; not good with chainsaws. Mix what you expect to use within a few months. Anything over 6 months old use up in a 4 cycle engine. HTH
    Lou
Sep 25, 2009 | Husqvarna Craftsman 36cc, 16 In. Gas Chain...
Garden Logo
131 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Tim Whalen
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
