Question about Kenmore 98702 Stacked Washer/Dryer
Wobble problems Hi, I was wondering if you got your washer fixed? The reason I ask is because I have the same problem. Thanks
  • 1,294 Answers
Try lifting the inner drum to check if there is any movement between the inner and outer drums, also turn the drum and listen for any grinding or scraping sound from the rear of the drum. Its possible that your bearings have gone out & need to be replaced. The job is far from easy.
Posted on Jun 17, 2008
I have a craftsman snowblower that I replaced the auger bearing on assuming that was what was causing my pulley to wobble. The wobble is still there. Is this going to wear my belt or bearing out?
I am wondering if your pulley is bent. It will wobble if it is. Is it possible a piece of ice got jammed into it. Is the auger shaft bent? There has to be a reason it wobbles. It will eventually wear something out if not repaired.
Dec 14, 2016 | Craftsman Garden
What is average going price for a new or used wobble pump for a Campbell Hausfeld PW2200V1LE. My 6.0 Briggs & Straton engine is in very good condition Reason I ask is a brand new pressure washer in my...
keep the briggs if your just gonna use it for yourself get the sjv axial pump 239.00 put it on your briggs.many retail stores use s disposable pump no sightglass or drainplug sjv has forged brass head no pot metal.
Jul 30, 2013 | Campbell Hausfeld Garden
Which hot and cold pressure washer?
Something with a Honda GX motor
May 08, 2009 | Garden
Wobbles when spinning
Hi thanks for using
The washer is not level or it has a broken spring or strut causing the wobble of the whole machine.
this requires hands on service! it is a job to change these!
please remember to leave a rating before you leave the site
Dec 07, 2008 | Washing Machines
F-24 fault code on my duet sport washer
f24 is water temp sensor ..look for loose wires on control remove bottom panel look for loose wires around heater while you have panel off look for tech sheet on rear of panel or taped to side wall this will help in locating connections for sensor and aid in troubleshooting any other reason for f24
Sep 23, 2008 | Whirlpool Washing Machines
Error code F-08
Did you fix this? I have the same issue.
Sep 20, 2008 | Hotpoint Ultima WF860 Front Load Washer
hi there,
just wondered if you fixed your washer.
Sep 16, 2008 | Maytag PAV2300 Top Load Washer
A ratchety sound is made while washing
hi thanks for the question i would check the pump some foreign object could be caught
Sep 15, 2008 | Maytag PAV2300 Top Load Washer
Drainpipe leaking
Hi Mary, I'm going through similar experiences with my new Whirlpool which I learned to hate. I'm not an expert, however, I learned a thing or two about washers recently. Your problem could be related to one or two things: The drainpipe hose should not be placed more than 8" in length in the drainpipe as it creates a siphon effect. Also, the new washers are designed to spin fast, thus higher water pressure exiting into the drainpipe. If your drainpipe is clogged up for some reason and cannot handle the high water pressure, that may also create a problem. This can be solved by using some Draino in the drainpipe. Hope this helps.
Feb 03, 2007 | Whirlpool Ultimate Care II LSQ9564J Top...
Kenmore 98702 Stacked Washer/Dryer Logo
53 people viewed this question
Sal De
 Brian Main
Brian Main
