Question about Car Audio & Video
Citroen c4 i have a problem with radio- cd all function on display is ok only the speakers is out of service ..so what is solution or ...?
SOURCE: No sound
I had the exact same problem. I disconnected the radio from the power cord in the back, waited several minutes, reconnected the power cord and my radio had sound!!
Posted on Nov 16, 2008
  • 3 Answers
SOURCE: radio's display won't light up
The radios in the 2000 Mountaineer are notorious to short out. You simply have to get a new one. Believe me. I had the same problem.
Posted on Jul 20, 2009
alicantecoli
  • 22359 Answers
SOURCE: Service indicator on Citroen C4
yes their is no other makes catagory ,right iam not sure if this will work but i reset one yesterday on 2005 model and i held the trip meter button down and then turned to aux position then waited 30 secs then turned key to ignition position ,waited 30 secs then turned ignition off and then started engine and it went out ,but for how long?? i dont know as the owner has taken the vehicle
Posted on Sep 17, 2010
  • 4793 Answers
SOURCE: Hi, I'm thinking of fitting
fitting rear flaps is a simple job depending on the kit you buy......you may find the rear window gets dirtier with flaps fitted,due to spray being finer.(citroen is the same a puegeot)
Posted on Feb 15, 2011
Ironfist109
  • 3018 Answers
SOURCE: how SERVICE LIGHT RESET for
  • Remember that light means it's time for a service on your vehicle. Oil change mainly. To reset the service indicator light follow these steps.
  1. Switch off the ignition.
  2. Now turn the ignition to "S" for steering lock.
  3. Next press and hold the "A" button.
  4. While holding the "A" button start the ignition and continue to hold the "A" button until the screen goes to ")" and the light goes off.
  5. Switch off the ignition and the resetting of the light is complete.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Posted on Jul 10, 2011
Testimonial: "thanks for your help"
Citroen c4 heater/air conditioner fan not working checked fuse seems ok
this website has books on how to service, repair, operate, maintain etc, any vehicle, heavy equipment and you can find all wiring diagrams, electrical, torque settings, error/fault codes, PCV, removal, installation, assemble etc, a lot more.
Try it
www.reliable-store.com
Jun 06, 2018 | Citroen Cars & Trucks
I have a citroen picasso c4 hdi is service light won't go has been serviced recently, have tried to reset as everyone explains, but the moment I start the car, the service light comes on with beep
The service engine light has to be reset back to factory setting. Even though you got engine repaired the light will not reset itself. a mechanic has the tools to do this. Now i reset my 05 Lesabre car by taking the negative battery cable off and leaving it off for a couple of hours then put it back on. In doing this you have to reset the radio and maybe some other things as well. You can try this but not sure about your make.
Dec 26, 2017 | Citroen Cars & Trucks
Towbar Wiring Diagram for 2016 Citroen C4 Picasso 7 Pin version
Have someone activate the different systems, turn signals, brakes, then while they do that use a test light (available from auto parts store for about $5 US) to identify the function of each wire and hook it up accordingly.
May 20, 2016 | Citroen Cars & Trucks
C4 / DS4 Radio Head unit removal to change
you need two u shape pin tool (x2)
push into small holes together and unit will pop out
Feb 21, 2016 | 2011 Citroen C4 1.4
Citroen c4 sx radio wont stop bleeping
Scan with Lexi 3 scanner and get it reprogrammed.
Sep 15, 2014 | Citroen C4 Cars & Trucks
Citroen c4 fuse box diagram
On this website you find fuse box diagram and description for Citroen C4 (2004 - 2010)
Citroen C4 2004 2010 fuse box diagram
May 19, 2014 | 2005 Citroen C4 1.4i
Radio wiring on citroen picasso xsara
you have power wires, memory wires speaker wires and a ground..some even have a power antenna wire
Jan 01, 2014 | Cars & Trucks
Citorin c4 2006 1.6 model fuse box diagram
There's an owners manual for Citroen C4 2006 here:
http://www.randy2006.com/2012/citroen-c4-fuse-box-layout/reading-citroen-c4-fuse-box-layout/
Its 196 pages long - scroll down to pages 156-159 for the section on fuses. Its better to download the pdf first!
Sep 14, 2012 | Cars & Trucks
Car Audio & Video Logo
470 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
