please confirm if you are referring to a dishwasher or washing machine. Usually the spin cycle applies to washing machine. Check where the water is leaking from. Most likely the drain pump hose is cracked. Need the model number of washing machine to make further suggestions.
913T is a very old model (1996), I have one, I'm not a repairer, I have the same fault. It doesn't have drawers or infrared or a display.
I've just shortened the ribbon cable, which had pinch damage at the door close pinch point. I used a male & female ribbon squeeze connector pair to make a good clean joint. With the cable fault it wasn't even starting the drain cycle. Now it does start, but then long beeps, and I suspect it's detecting a fault with the motor or a sensor or faulty wire, and is halting.
I've found running the rinse cycle first then allows the main wash cycle to run, no longer stopping at 10 seconds (after the initial drain), just as the first power wash commences.
Hello, Thank You for using FixYa. I will be helping you today.I would start by removing the outer door panel remove the screws around the inner door to do this.Then close the door and start a cycle. Sometimes you can see obvious signs of leaks just by removing the panel too. But if not let it run and see if you see water leaking anywhere. You will see water in the bottom corners its normal. If water is splashing over those corners the check the lower spray arm gor damage or cracks it can cause this problem also make sure the screws under the spray arm are tight. also check the upper arm.
Thank You and please rate my answer if it was helpful..
1 has the machine been pushed into the cupboard hole,this will push the door away from the front of the machine,does it hit the trim around the opening before the closeing?pull out check under are the legs still straight,some you can remove the lower front panel to look under
Without knowing the model number of this Sears Kenmore dishwasher, it is difficult to be specific in a solution.
There is a float/switch that controls the amount of water added before each wash or rinse cycle. Replacing that float would be the first step.
Can not be more specific without knowing the model number.
Assuming that you have checked under the dishwasher for a leak (through a faulty sump gasket):
Since there is not actual leak, check the following:
-Confirm that the height of Drain Hose connection
(sink-Drain Hose) rises greater than 20′ _minimum_ as it travels to the drain connection.
-If that does not solve the problen, it is probably a worn/broken Impeller of the Washing Pump.
Unless you are mechanicly incliend, a service call is probably the way to do. If you need further steps, please reply. Otherwise, after you ahve used the advise, please accept this solution.
