Question about Siemens SpeedStream Modem (4100) (SS4100)
We have got 1850 KW Siemens Induction motor ,3 Phase,2991 RPM:cos#:.91:A-108: 11 KV/50 hz supplied as a part of M/s Atlascopco compressor: ZH-15000-6-10H We have measured the megared value:more than 600 Mega oms. We are not able to to run on solo running to locate Magnetic centre and to see the sattor winding temp ets.and VCB(Tripping).Softstarter:ramp time is 10 second.CT ratio ;The supplier says is OK. Nothing wrong with Soft stater and the VCB. the motor is tripping on Overcurrent:after has gone.second time VCB tripped.The expert has adjusted the current even then VCB trips with in three seconds. First run fuse of GIS The measured value my be more than 600 A. We are heating the motor now. Kindly advice what is the problem. G.Surareddy Technical advisor. Indutrail gases MO;98865-30068 Mail:gsurareddy@yahoo.com
5 Suggested Answers
  • 3 Answers
SOURCE: How to connect Siemens broadband modem over ethernet port like HUB/Switch
First of all connect with the cable computer and your ethernetcard and phoneline to your modem c2110 and then turn on the power of your modem,then type the address 192.168.1.1 at the explorer bar.Their you will find a pop up requesting you to enter username and password,enter the admin as username and admin as the password.Then proceed and just click on configuration given on the left side of the page,after clicking three subheadings you will find first local network the other internet and the third one DSl home, then just click on the internet their you will find several things to edit but you only click on the edit button infront of where "pppoe_0_35" is written, after that just do next and next untill you will find at one place Broadbandusername and Broadbandpassword, their u enter the username and password provided by the BSNL, after that click on the APPLY button,and wait for few seconds. and then close the window,and now enjoy surfing internet.
Posted on Apr 27, 2008
  • 3 Answers
SOURCE: Having problems with siemens arc fault breakers tripping
check to see if ground is connected or netural is loose
Posted on May 10, 2009
SOURCE: Siemens oven tripping RCD
We need wiring diagram for HB905 Siemens double oven, to start with it kept tripping, element ok. Now we have no heat coming from the main oven.
Posted on Dec 12, 2009
jwelec61
  • 7 Answers
SOURCE: Siemens Main Breaker 125 Amp gets warm and trips
Check amp draw, make sure service calculation was completed correctly, check line side and load side connection of main breaker
Posted on Dec 07, 2015
Rpm computation
it will be the same as motor if driven directly. If you use pulleys and belts there a online calculators that will help you BTW the pulley ratio is 1.259
Dec 03, 2017 | Air Tools & Compressors
Need to transform 120v power to 240v
Bad news:
UK has 50 Hz electricity, and appliances are rated for local power..
Any appliance made for US market is rated 60 Hz.
50 Hz and 60 Hz electricity are different.
Look at label on your mixer, and then look at labels on local appliances. You will see 50 cycles or 60 cycles. Rarely appliances are labeled 50-60 cycles.
http://www.worldstandards.eu/electricity.htm#voltage
http://waterheatertimer.org/See-inside-main-breaker-box.html#Hz
http://waterheatertimer.org/What-is-3-phase-electric.html#120-240
Hz Hertz or cycles or frequency is number of rotations the electric generator turns per second.
Some appliances are rated 50-60 cycles and will work worldwide.
However most appliances are rated 50 or rated 60 but not both.
60 cycle motor will not perform as expected when connected to 50 cycles. And might overheat.
Generally, most motors can be converted to different voltages by taking motor to motor shop (if you can find one these day)
However electronic controls cannot be converted between 120V and 230V, nor will 50 Hz electronics work with 60 Hz power
Sorry Sue.
Buy another mixer.
Business will benefit from surge of consumer buying.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Mar 28, 2013 | Hardware & Accessories
Need wireing diagram for AO Smith 1HP motor S#C56A97B08 Ser32409J2
less hassle replace whole pump if motor over heated possible bad seals and distortion to pump housing will leak
Dec 04, 2017 | Pool & Spa
Why do my clocks run fast when my Briggs & Stratton 15kw generator is running?
Electric clocks use synchronized motors that run on 60 Hz AC. The power company provides AC power with a precisely regulated frequency of 60 Hz. That means that the voltage jumps back and forth (positive to negative) 60 times per second. Your generator would do the same thing if it could run at precisely 3600 rpm (that's rev's per minute) - but it can't, because the engine is not that precisely controlled. In your case it tends to run (on average) a little fast. I hope you found this helpful. By the way, in Europe 50 Hz is the norm. If you run a clock designed for 50 Hz on 60 Hz power, it will run 20% too fast! Al K
Jun 20, 2011 | Briggs & Stratton Briggs Stratton 7 kW...
Taking my P660 out out a building with 3 phase power and into one with only single phase. Converter says motor will run on 2/3 power. Good or bad idea????
Good!
MOTOR:
21?2 H.P., Hobart designed, high torque ball bearing,
ventilated within mixer enclosure. Single-phase is
capacitor-start, induction-run type.
Three-phase is
polyphase squirrel cage, induction-run type.
Single Phase 208V 20.0 Amps
240V 17.0 Amps
Three Phase 208-240V 8.6 Amps
Nov 26, 2010 | Hobart P660 Stand Mixer
We require condenser fan motors for Interclisa Carrier package (rooftop) air conditioner model AAD 250 (1980's model) model. Air conditioner - supply voltage 380 Volts 50 Hz AC. Condenser fan motor voltage...
Hi, this is an odd voltage 380 volts. Is it a 3 phase unit? To get a 220 volt 50hz condenser fan motor, you will have to go through a refrigeration/air conditioning parts house and order this. 60hz you would have no problem finding one in stock. Carrier is a good unit, and have been around for many years. You shouldn't have any problems locating one.
Sincerely,
Shastalaker7
PS You will need to go through a wholesale parts house.
Jan 21, 2010 | Carrier Heating & Cooling
Hi i am washing machine expert. sometimes i thought about to find RPM of any electric motor weather its small or large because its my passion to collect information about my business... so please give me...
i was talk about that... how to check motor RPM? so the solution is....
Calculating Motor Speed:
A squirrel cage induction motor is a constant speed device. It cannot operate for any length of time at speeds below those shown on the nameplate without danger of burning out.
To Calculate the speed of a induction motor, apply this formula:
Srpm = 120 x F
P
Srpm = synchronous revolutions per minute.
120 = constant
F = supply frequency (in cycles/sec)
P = number of motor winding poles
Example: What is the synchronous of a motor having 4 poles connected to a 60 hz power supply?
Srpm = 120 x F
P
Srpm = 120 x 60
Srpm = 7200
Srpm = 1800 rpm
Jun 23, 2009 | Haier Washing Machines
Siemens SpeedStream Modem (4100) (SS4100) Logo
113 people viewed this question
Top Siemens Computers & Internet Experts
Prashant M
Prashant M
john smith
Are you a Siemens Computer and Internet Expert? Answer questions, earn points and help others
