Question about Dell (04U621) for Latitude D600, Inspiron 600M Motherboard
Tv to laptop
Hi im trying to connect my laptop to my tv. I already have the cable with the RCA cable yellow and s-video input for my computer, and connected already to my tv but when I hit Fn(F8) a signals appears on the tv but still look completly black, what else i have to do?, am i doing somethig wrong?
  • noti15 Apr 27, 2008
    how i do that?
  • she007 May 11, 2008
    My laptop was connected to the tv with no problems. Now it wont work. I have volume but no picture. The screen says no signal
When you have everything hooked up, IE the audio and video cable to your TV right click on your desk top then click on properties, then on settings. Then click on the advanced tab. This should bring up the ATI properties window. Click on Displays then activate your TV connection. This should automaticly prompt a resolution resizing and should activate your TV connection.
Posted on Apr 29, 2008
    Problem Solver:
  • 12 Answers
Disable your laptop screen try that jules
Posted on Apr 27, 2008
How do i connect my hp2560p to tv
You can use a VGA cable to connect from your laptop to your TV.
10FT 15 PIN BLUE SVGA VGA ADAPTER Monitor Male To Male Cable CORD FOR PC TV
Just make sure you have a connector on your TV....If you only have RCA inputs, you can buy an adapter. just plug it into your laptop and run the Red, White and Yellow to your TV with RCA cables.
VGA SVGA to Video 3 RCA AV TV Out Cable Adapter Converter PC Computer...
Thanks Hope this helps!
Please rate
Gary
Mar 17, 2014 | HP Elitebook 2560p Notebook 12.5" 2.5gI5...
Which cable should be hook up to tv. Trying to hook up DVD player. I have cable with Red, white, yellow.
hi that"s easy thing. first connect rca wire red white yellow to dvd hook up same colour red white & yellow female rca connection. then use another rca wire connect to your tv be video input in yellow one . red & white be sound input - red to red . white to white. just that. good luck!!
Jun 03, 2011 | JVC C-13920 TV
Hi. I have recently purhased an Acoustic Solutions DVDRW300 DVD Recorder. I have no instruction manual and have no idea how to set it up or work it!! Please help as im totally useless!!
Hello!
I am assuming that you want to INPUT your TV/Cable Box to your DVDRW, and have the DVDRW then be able to OUTPUT to the TV.
Here's what you need to do:
1. Locate the OUTPUTS of your TV/Cable box at the back of your set. There should either be the RCA jacks (Yellow/White/Red), S-Video, VGA, DVI or HDMI . Make sure that they are OUTPUTS. It'll probably say TV-out or just out.
2. Locate the INPUTS of your DVDRW. Similarly, it should either be the RCA jacks (Yellow/White/Red), S-Video, VGA, DVI or HDMI. Ensure that they are INPUTS.
3. Match up the outputs to the inputs. Now, I have listed the OUTPUT/INPUTS going from lowest quality to highest quality. So let's say your TV has RCA, S-Video and HDMI outputs, and your DVDRW has only RCA and S-Video. HDMI is ruled out, unless you get a converter (which is pretty pricey). Choose which one, and buy/use the right cables.
4. Here are the connections for each type of OUT/IN. (TV/Cable >>>>> DVDRW)
  • RCA (Yellow/White/Red) >>>>> RCA (Yellow/White/Red)
  • S-Video + RCA (White/Red) >>>>> S-Video + RCA (White/Red)
  • VGA + RCA (White/Red) >>>>> VGA + RCA (White/Red)
  • DVI + RCA (White/Red) >>>>> DVI+ RCA (White/Red)
  • HDMI >>>>> HDMI
5. Connecting the DVDRW back to the TV. So now, you can record whatever is playing live on your TV. But you also want to play things from your DVDRW on your TV. Check the OUTPUTS of the DVDRW. It should have either the same jacks as the INPUTS. Check the INPUTS of the TV.
6. Follow Step 4, and 5. Note that for connections, you are going from the OUT of the DVDRW to one of the INs of the TV. Keep track of what INPUT on the TV you are connecting to.
Voila! Let's test it, though. Now, turn your TV and DVDRW on. Put in a DVD (a movie perhaps) in your DVDRW. On your TV, switch the channel to the INPUT channel you used. You should see your movie. If not, try another INPUT on your TV.
If it's fine, then let's try recording a TV show. Switch the channel on your TV to whatever you want to watch, say Cartoon Network. Put in a blank DVD in your player/recorder. Hit record on the player. Let it record about 2-3 minutes, and stop recording.
Switch the TV back to the INPUT which works, and hit play on the DVDRW. You should see what you recorded.
Hope this helps!
Mar 14, 2011 | Televison & Video
I have video but no sound from the TV
hi there send it back to nintendo the sooner the better here is there phone number for them to collect it and repair
> Nintendo UK
Quadrant
55-57 High Street
Windsor
SL4 1LP
Tel: +44 (0)870 6060247 (Calls charged at National Rate)
Fax: +44 (0)2392 383 444
Registered at
Companies House, Cardiff, (31st January 2001)
Company No. FC022968
Branch No. BR005889
Managing Director
Satoru Shibata
if you need any othere phone number or address ill be happy to post it up for you cheers
Thanks From Me and FixYa
Feb 02, 2009 | Nintendo Wii Console
I am trying to connect an akai dvd player to directv, please help
ruettab,
good day. to connect your any DVD player to any TV screen always remember this color code
from DVD back part:
yellow = video out
red/blue/green( in a row) = component video out ( this can only be used for screen with component video inputs)
Black = digital audio ( rarely use unless)
Red and white (in a row) = Audio output (left and right audio)
where to connect from TV screen.
Locate where A/V INPUTS (audio/video socket) from your TV screen, you can see it either at the BACK/SIDE or somtimes in FRONT of TV screen , having marked as "AV1"AV2"AV3' .
Once you found TV input, you must first have RCA cable (color code cable to connect player to screen) then connect the RCA cable at the back of your DVD player, simply follow color code
RCA yellow marked cable = DVD yellow socket
RCA RED and WHITE marked cable = DVD RED and white socket (second row for your player)
then connect the other end of the RCA cable to TV screen, first select which input where you gonna place the DVD player ( either AV1, Av2 or Av3 if do have multiple inputs)
once decided which INPUT to connect the player.
ex. if you select AV1 as input there would be 3socket on its row (yellow/red/white)
now connect the other end of RCA cable to the screen by following the same color code:
RCA yellow cable = TV screen A/V1 input yellow socket
RCA RED and White = TV screen A/V1 input red and white socket.
cheers,
mark
Jan 31, 2009 | Akai DVD-3850S DVD Player
No sound
tcolson,
good day, make sure your RCA red and white marked cable connected to TV screen audio input where you also connect your yellow cable which is the video.
note: always remember color code of RCA cable
yellow = video
red and white = audio (left and right)
connection would always be:
video device yellow RCA socket = TV yellow "INPUT" socket
white and red RCA = TV white and red "INPUT "socket
make sure that all this 3 cable are connected together in a specific "A/V input"
cheers ,
mark
Jan 30, 2009 | Sansui VRDVD4001 DVD Player/VCR
Connecting my acer aspire 5100/5102 to my tv via cable
There are a number of possible ways to getbthe display up onto your television. Im not certain which colours to use with which but once its all plugged in you will need to hold down the FN (funtion) key and press one of the F1-F12 buttons. to work out which one you just need to look for a button that looks like a screen or two screens and that should make the display external. good luck
Feb 07, 2008 | Acer Aspire 5102WLMi Notebook
CONNECT CABLE TO MY PROJECTOR
Depending on the specific model of your Mitsubishi DLP, you can have either S video, RCA, VGA or a few other choices of INput connection.
Depending on your cable provider and hookup, you can either have a plain cable with F connector or a cable box normally with RCA connectors and a remote control.
If you have a simple cable connection that attaches direct to a TV (no remote, no box), you would need a TV Tuner to be able to receive the different channels whose output would be a composite video signal into the yellow RCA jack. You would need an RCA to RCA cable to in turn connect it to your Yellow RCA Video INput of the projector. In the absence of a tuner, an old VCR with such a feature would also serve the purpose. In some instances either units may also have an S video connection.
If you have a cable box with with remote, then there is no need for a tuner or VCR since its output would already match the projector's input.
Either way you would need a separate audio amplifier/speaker  for the sound.
Hope this be of some help/idea. Pls post back how things turns up or should you need additional information.
Good luck and kind regards.
Oct 23, 2007 | Office Equipment & Supplies
RCA ColorTrak 27" (non flat) connection to VCR/DVD combo
Yes, To change the input to video jacks, you must change the channel to 00.
Jun 25, 2006 | RCA F27645 27" TV
Computers & Internet Logo
103 people viewed this question
Alun Cox
