Question about Kenmore 74602 Gas Dryer
When you hook up your gas dryer, how do you ignite the iginitor?
  • 171 Answers
The ignitor ignites itself when you start the dryer.  if it is not glowing you either have a bad thermal fuse or the ignitor itself is bad.
Posted on Aug 06, 2010
I bought a gas dryer and Maytag performa and after I hooked it up I can't get it to light I was wondering if it had a pilot light an electric pilot
Should be a ceramic igniter. It heats up, and when it is at the correct temperature the gas passes over it, and it ignites. If you bought the dryer used it may be cracked. If it is cracked, it will not work and must be replaced. The crack if very hard to see but when you find the igniter turn off the gas and turn on the dryer if it glows white hot it is okay if it is a dull orange it could be the problem.
Jan 28, 2018 | Maytag Dryers
I have a imperial whirlpool dryer. I thought it was electric, it has gas hook up and a electric plug as well , can it be bothZ?
Yes, it will be both. A straight electrical dryer is hooked up to 220 volts of electricity and uses that voltage to run both the motor and the heater. In a gas dryer, you only need 120 volts to run the motor and run the igniter for the gas, which provides the heat to dry your clothes. Hope this helps!
Feb 24, 2015 | Whirlpool Dryers
Frigidarie stove model#PLGFZ390ECB burners and broiler works oven dont replace iginitor still do not work.
Good Afternoon Cheryl,
I understand that the burners and broiler are working in your Frigidaire range, model# PLGFZ390ECB, but the bake element does not work. I also see that you have replaced the igniter and it is still not working. I suggest contacting your local authorized technician for further assistance. They will be able to diagnose your appliance and determine why your oven will not come on. Hope this is helpful.
-Best Regards-
WP
Jul 01, 2014 | Frigidaire 24" Built-In Single Gas Wall...
Whirlpool dryer newly hooked up and will not heat. Do they have a reset button. Tumbler moves. It is gas. electronic ignition?
Make sure that your gas valve is on, if there is no gas, it won't be able to ignite and therefore no heat. It is possible that the unit is defective as well. If you are sure that you have the gas line hooked up and the valve is on, also make sure you have the proper electrical connection. Most gas dryers are 120V and a standard receptacle is used. If all of that is correct, then I would suggest calling the tech support number in the information on the unit or call the retail establishment you purchased it at.
Oct 27, 2009 | Whirlpool Dryers
Kenmore 80 series Gas Dryer
HI. you are correct. this dryer, although gas, is using a Glow igniter system. most older models used the snap igniter that clicks over and over to spark the burner but, this dryer is only 2 years old so, it should be outfitted with a glow igniter system. This igniter is powered by electricity.
It works in conjunction with a Flame sensor.
Jun 02, 2009 | Kenmore Dryers
Oven does not heat up - occasional gas smell
you have bad ovne ignitors( bake iginitor is no good
Jan 28, 2009 | Amana ARGS7650SS Gas Kitchen Range
No electricity to the ignitor
since it seems you know what your doing,,,when you disconnect the ignitor and turned unit on you did not get 110 im asusuming,,,now ,,i want you to jump the iginitor sensor dont use a meter just put the 2 wire together,,the white and the blue make sure therte not touching anything but each other...that the little glass sensor on the side of the flame box ,,on left hand side...onthejob
Jan 25, 2009 | Kenmore 73952 Gas Dryer
Does a Kenmore Elite H3 dryer have a pilot Light???
No. They are electronic ignition. just plug it in and hook it to gas and should heat up.
Nov 21, 2008 | Frigidaire FGQ332ES Gas Dryer
Kenmore 74602 Gas Dryer Logo
Top Kenmore Dryers Experts
Sal De
Marvin
Marvin
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
