Question about Panasonic PT-61HX40 61" Rear Projection Television
Moving TV What do I need to do to secure this TV for moving?
First put a flatenned moving box to cover the screen and then put a blanket on the screen and then tape it up. This would help with the scratches. Get two long flat ropes than can slide under the tv (side to side) and the tie the ends together, get a helper and then both you and the helper put the ropes behind your neck while lifting and also supporting with your hands. This is how professional movers do it. Once its in a truck, put the flat side facing the truck wall and tie it up.
Posted on Sep 05, 2008
Furniture moving companies
Depends where you live.
Aug 26, 2017 | Furniture
To transport a loewe spheros 42 plasma unit with rotating stand does the tv unit detach from the stand? I understand that the plasma tv should be transported in an upright position only is this true?
Yes, it should be transported in upright position.
When we moved, our moving company arranged a crating company to crate our Spheros unit. They built a crate around the TV and secured it in an upright position along with the rotating stand. They then put a tilt sensor (you get the serial number of the tilt sensor) to make sure that the moving people don't tilt the crate. They also un-crate it at your destination. The only problem is that the TV is already quite heavy to begin with (~180 lbs), and with the crate, it becomes almost impossible for the movers move it in perfect upright position....though our movers really tried hard.
Sep 30, 2010 | Loewe Spheros 42HD 42 in. HD-Ready Plasma...
Controller lighting up but not moving anything on screen,
Hi gregmussmach,
There are lots of issue with this toy, try to check the batteries 4 "AA" batteries, and the connection to the tv is properly secure.
Thanks,
Banaple
Sep 01, 2010 | Vtech V.Smile TV Learning System
SELL TV: HOW DO WE MOVE IT
Howdy,
The best way to transport the TV is standing up with the front secured to a 'side' of vechile. If you don't have that choice lay the TV down on it's face. With both make sure you have plenty of moving blankets.The side would be my last resort because of stability. DO NOT LAY ON BACK!!!!
Good Move, big IRISH.
Dec 28, 2009 | Hitachi 50UX57B 50" Rear Projection...
Need to secure for moving
You should have some bolts that came with the machine. They are fitted into the rear casing and screw into the drum to hold it steady. If you dont have the bolts then you can try packing some towels around the outside of the drum ( from underneath ) to hold it steady.
May 21, 2009 | Frigidaire ATF6000ES Front Load Washer
Power cord
you would need a qualified tv personal to re- insert the power chord
Jan 20, 2009 | RCA 27V530T 27" TV
I do not have a color picture
If you had a color picture before moving the TV, then you should check the inputs. Make sure all the cabling is properly and securely attached.
If this does not help, please provide more information, such as a description of the TV, indicate whether the TV had a color picture immediately before moving it, and whether you have reason to think that there is a mode for black&white.
Nov 30, 2008 | Televison & Video
Panasonic PT-61HX40 61" Rear Projection Television Logo
54 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
