Question about Vector 1 Million Rechargeable Spotlight
Batt wont hold charge - Vector 1 Million Rechargeable Spotlight
  • 283 Answers
In March, 2006, Black & Decker purchased Vector Products, Inc. Since the acquisition, Black & Decker has assumed the manufacturing of all Vector products. For customer service and warranty information for Vector products, please contact Black & Decker Customer Service.
Posted on Aug 12, 2010
Does anyone know why my Samsung galaxy lite will stop charging at 30%?
try to change the batt. sometime bad batt wont hold max power when we add charging into it.
Sep 21, 2015 | Samsung Cell Phones
I have a Jet3 wheelchair not charging with internal (accoring to amp meter)
you will need a off-board charger to charge the chair Strege Mobility
I’m happy to assist further over the phone at https://www.6ya.com/expert/bill_bcbb89783b08c489
Sep 13, 2017 | Jet 3 Ultra Power Chair
Wont start sometimes wont hold charge sometimes, is that batt or starter? what is extra wire to battery for
If the battery won't hold a charge sometimes, it could have a dead cell. You would take the battery out and have it tested or drive the truck to a shop for the test.
The extra wire may be a feed for one of the fuse boxes if it is on the positive cable.
Sep 16, 2012 | 1995 Chevrolet Suburban
97 checvy astro 4.3 6cyl. I replaced battery, Starter and the batt wont hold a charge. Is it possible to check the wiring from the alt to the starter without having to remove the alternator?
Yes, If you have a volt meter, jump and start engine, with engine running you should have approx 13.5 to 14.2volts that would tell me that batt is getting charged when engine is running. you said new batt would not hold a charge, I would be thinking about a parasitic draw(small amount of power) that in time will drain batt. things to look for are glove box lights, under hood lights that dont turn off. one easy way too see if you have a draw is to disconnect one batt cable, now use a regular (12volt non-self powered) test light and touch one end to batt cable and the other to empty batt terminal, with no light switches on and doors closed, this test light should not light and if it does then you have a drain on batt that will kill it say overnight.
Feb 12, 2011 | Chevrolet Astro Cars & Trucks
Not charging replaced alternater still wont charge
Be sure to charge the battery, otherwise you might smoke the new alternator(not made to charge a dead batt.). Have the batt. load tested. Check batt. cable ends for corrosion.
Nov 11, 2010 | 1994 Plymouth Voyager
I have a sony cibershot camera for over a year now, it has always worked nicely, up until a month ago, it suddenly wont turn on anymore. I,ve already charged and re-charged the battery but nothing...
make sure the batt is charging and working fine.check also the batt contacts.make sure its clean.insert batt to your camera.instead of pressing the power button, press the play button instead to power camera on. if unit turns on,might actually be an issue w/the camera unable to power on in camera mode.if it turns on initialize cam (p.75 of the manual).see if it works.if still wont turn on try using a diff batt (or if you have an optional ac adapter model#acls5k use it, attempt to power on cam to isolate issue w/power source).if batt or ac adaptor not available try to check batt with another cam if possible to test batt. if still unit doesnt turn on using a fully charged, diff batt, or using an ac adaptor,unit would reuire service. hope this info helps.thanks:)
Apr 06, 2010 | Sony Cyber-shot DSC-H9 Digital Camera
97 civic new battery wont hold a charge alternator is fine....any ideas... thnks gf
remove pos batt cable from batt install test light in line. One end on batt other end batt cable. See if test light burn.s bright with car turnd off' Unplug fuses one at atime until you find on that makes the light go dimmer. then look in maual to see whats on that ckt'
Jun 24, 2009 | 1997 Honda Civic
Screen lights up when charging, but wont power on
Hi you have to hold the button down for few seconds if this dose not work leave to charge for longer,if you still have a problem your batt may not be holding charge
Jan 13, 2009 | LG KM500 Cellular Phone - Unlocked
Car shakes when trying to start and doesn't turn over
  1. hold gas pedal to floor while trying to start. do not pump pedal.
  2. holding pedal to floor is how you start a flooded f.i. engine
Nov 12, 2008 | 2000 Lincoln LS
Vector 1 Million Rechargeable Spotlight Logo
418 people viewed this question
Top Vector Camping, Backpacking & Hiking Experts
Marvin
Marvin
Lawrence Oravetz
Are you a Vector Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
