Question about Dell 5210n Laser Printer
What does this error message mean: "917.00 service transfer roll"
  • 225 Answers
The transfer roller is missing, not touching the drum, poor contact to the transfer high voltage or transfer high voltage shorted.
The trasfer roller is below the drum. Its bearings are on springs to press the paper against the drum. The drum rotates it by gears at one end. One of the bearings have electrical contact with the spring and the spring is connected to the DC controller. The transfer roller receives high voltage that attracts the toner from the drum. It's current is measured and when it's not within specifications the error occures.
Posted on Aug 05, 2010
How I fix the error 917 service transfer roll
Try replacing/reseating transfer roll.
  1. The right and left transfer arm assemblies
  2. The high voltage power supply (HVPS)
  3. The main engine/system board
Feb 18, 2015 | Lexmark E350d Laser Printer
917.00 transfer roll
The cuase is the HVPS card. Clean it or replace it.
Mar 30, 2012 | IBM Infoprint 1552n Printer
Printer displays 917.00 print error. seems to be transfer roller. changed the transfer roller same error.
The exact definition of this error is "Problem with transfer-transfer servo start error"... NOT the transfer roller. The service manual directs you to the Transfer roll service check.
The service check tests for proper operation of the HVSP, system board, and sensors.
The most likely cause of your problem is the HVSP ( High Voltage Power Supply ).
Change the HVPS and you should be good to go!
Feb 28, 2011 | Lexmark T640 Laser Printer
How i can solve the 913 service motor error lexmark sc1275 my printer?
913 Transfer Roller Error
The printer fails to completely transfer the image to the paper or does not transfer it at all.
The image transfer roll does not lift when paper is passing over it.
Suspect either the transfer roller solenoid or transfer roller motor malfunction.
The printer would have to be professionaly serviced by authorized service centre.
http://www1.lexmark.com/content/en_us/technical_support/find_service_provider.shtml
Copy and paste link above for Lexmark Service Centers.
Pre
Jan 14, 2011 | Lexmark Optra SC 1275 Laser Printer
I received an message 917.00 service transfer roll. How do I fix this ?
Here's an article on A 917 or 917.00 Service Error Is Appearing on a Lexmark T640, T642, T644, or an X64xe Series Printer. Just click on this link: http://bit.ly/aQD8jS. Follow the recommended actions. If error won't clear, printer may require service. Don't hesitate to contact Lexmark technical support for assistance. Thanks.
Aug 06, 2010 | Lexmark T640 Laser Printer
91700 Service Transfer Roll was appearing on my screen so I ordered a new one replaced it and it is still showing me the error.
Here's an article in the Lexmark website to guide you on what to do when having 917.00 Service Transfer Roll error. Just click on this link: http://bit.ly/d7uyzZ. Follow the instructions carefully. Basically, when having this kind of error, you will need to primarily change the transfer roll or the High Voltage Power Supply. If this doesn't help, it may require service to replace the system board assembly, transfer roll left and right arm.
Jun 01, 2010 | Lexmark T640 Laser Printer
Need Help! What does the Error message "Set transfer roller" mean?
"Set transfer roller" means that the set transfer roller is missing or not installed properly. Install or reseat the transfer roller.
Mar 30, 2010 | Lexmark C500n Laser Printer
Error message 917.00 service transfer roller. I replacedn the service roller but still the error message comes up.This is from the IBM Infoprint 1552.
A 917 transfer roll error code on all models at service level may
display if an incorrect level HVPS is installed in a printer that has the erase lamp assembly installed.
Check to make sure the correct level HVPS is installed.
Feb 11, 2010 | Office Equipment & Supplies
SERVICE CALL 14 XFER ROLLER Have installed new transfer belt. Still had error message. Came here and read tips. Cleaned the sensor both in the printer and on the transfer belt; reinstalled. Still...
the transfer roller is a foam roller that transfers the toner onto the paper. It will be visible with toner removed, a little wider than a piece of paper, and about the thickness of a roll of quarters. I don't know how to physically remove it on your model, but transfer roller issues in general can be remedied by removing the transfer roller and wrapping it in packing tape until the tape comes off clean.
While you're in there, vacuum everything out for good measure; but never, ever use canned air on a laser printer.
Jan 03, 2010 | Minolta magicolor 2200 DeskLaser Printer
Printer problem
Your transfer roller needs replacing.
Feb 22, 2008 | Lexmark T630 Laser Printer
Dell 5210n Laser Printer Logo
841 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
