Question about RTO Spur Sprocket For Stihl 017, 021 Chainsaws
Need to know how to take clutch off stihl chain saw ms250
    Problem Solver:
  • 10 Answers
Take the bar cover off, remove the bar and chain. there will be a lock key that u can easily remove with a flat head screwdriver, after u get it off all pices should slide out easily, just rember how to put it back and make sure not to mess up the oiler needle
Posted on Mar 02, 2011
  • Stihlfanboy Sep 30, 2011
    aye, but after you remove the spur sprocket you need to stop the piston(you could carefully use rope if you dont have the tool) and turn the clutch clockwise to loosen. and like 24 said, you will make sure the sprocket driven chain oiler is aligned with the notch in your sprocket
STIHL pole saw 101
Hi Little Bird
Chances are that the clutch needs servicing or replacement.
Here's a link that explains:
http://www.lilredbarn.net/Stihl-HT-101-Pole-Pruner-Clutch-s/29554.htm
Cheers
Jun 06, 2016 | Stihl HT101 Pole pruner
Need repair and service manual for Stihl 012 chain saw engine
google the stihl web site and if there are manuals available ,you will find them there.
May 27, 2015 | Stihl 021 023 025 Ms210 Ms230 Ms250...
Have a stihl chainsaw that's probably 10 yrs old. Will start ok but the chain won't move when given gas. It revs but won't move.
I guess the first thing to look at is chain free to move ?, do this with saw off ! and not running , if its not free to move give a good look at the chain brake , if chain moves free with a gentle push , then your clutch is in need of replacement good thing as stihl makes parts for there old saws still too , now if your saw was 20 yrs old your clutch is rebuildable
Apr 26, 2015 | Stihl Garden
The saw runs but chain doesn't turn and it starts t smoke, is the clutch bad ?
Sounds like you haven't read the manual.! Is the chain brake still on.?? The chainsaw has a centrifugal clutch, the more the saw revs, the harder the clutch grips. Sounds like you have the chain brake applied and the clutch is trying to turn the drum which is being held by the brake band
Mar 08, 2015 | Stihl Garden
Stihl MS250 Chain saw overheats. I have had two MS250 saws overheat and be ruined. I have always been careful with the fuel mixture. I have kept the saws clean. The saws were not old. In fact, I had...
Do you clean the entire saw inside and out sometimes when you keep it in a close room for months or days even they could overheat. Don't start right away but wait till its fuel is really mixed in properly. Get it checked by a service center.
Apr 11, 2014 | Stihl 021 023 025 Ms210 Ms230 Ms250...
Clicking noise stihl 250
Probably your clutch is loose and noise is coming from chain cover. Anchor the bar in a vice and remove the nuts holding the cover on.
Mar 05, 2014 | Garden
No oil to chain stihl ms250
Oil pumper oil gear, needs to be adjusted or replaced. Check out a video how to replace.
Nov 29, 2013 | Stihl 021 023 025 Ms210 Ms230 Ms250...
Need to know the oil to gas ratio for a 056 stihl chainsaw?
Stihl chainsaws are 1:50 oil to gas ratio. Make sure you use good high-quality 2-stroke oil, preferably that which is made by Stihl.
May 21, 2010 | Stihl Chainsaw 045 056 Clutch Chain Saw...
I have stihl chain saw it runes full throttle
After you let off of the throttle it dies instantly or just kind of quits slowly ?
It could be :
- 1 ) Your clutch is hanging up and not allowing the engine to idle while the chain is not moving.
- 2 ) You need to set the idle higher. You will need to remove the air cleaner, and find the small idle adjustment screw, and turn the screw clockwise, until it idles.
Please let me know.
Feb 08, 2010 | Poulan Pro Chain Saw 46cc 20"
Im having problems starting an MS250 Stihl chainsaw. Can you give
Chances are good that the compression is not to blame. I would look at:
1. Bad Fuel
2. Fuel Line/filter
3. Carb dirty/mis adjusted
3. Spark Plug
4. Ignition
Dec 01, 2009 | Standard Oregon Chainsaw Chain For Stihl...
RTO Spur Sprocket For Stihl 017, 021 Chainsaws Logo
237 people viewed this question
Top RTO Garden Experts
John Trevino
Joseph Mueller
Joseph Mueller
JOHN BROWN
Are you a RTO Garden Expert? Answer questions, earn points and help others
