Question about Broan-NuTone Intermediate Whispaire WA6542SS Stainless Steel Kitchen Hood
I have a ns6530ww i need a fan motor for my range hood thank you jt
  • 8,197 Answers
Posted on Aug 07, 2010
HJA2540 cooker hood fan not working. Lights work and little red light comes on when switches for fan speeds are pressed so has the fan gone or is it the capacitor? Many thanks Steve
Unless that's a much bigger range hood than I imagine, there won't be any capacitor - the motor will be of a shaded-pole design. If you have a multimeter, you could measure for voltage on the motor wires when the motor should be running - if reasonable voltage is there but the motor isn't spinning, then the motor's dirty or unlubricated or dead. If no reasonable voltage is present, the electronic controller has failed.
Aug 03, 2014 | Kitchen Ranges
Faber range hood fan stuck
Can you start the fan while holding the motor? If it runs fine while not in the hood, then likely the fan is rubbing against something that is not letting it get up to speed. If the motor does not run when removed from the hood, then there's something wrong electrically - a start capacitor, bad motor, etc. Try to verify the fan is not rubbing on something first.
Jan 21, 2014 | Faber Kitchen Ranges
Whirlpool accubake
follow this steps with VOM and fix it. God bless you
1. No power to the range hood
Make sure there's power getting to the range hood. Check for a tripped circuit breaker or a blown fuse. Check the wall socket (unless the hood is hard wired) for power with a voltmeter or by plugging something else in.
2. Fan switch
If your range hood only has a fan and no light or any other features, it won't start with a broken fan switch. Replace the switch if found defective.
3. Fan motor
If your range hood only has a fan and no light or any other features, it won't start with a broken fan motor. Replace the motor if found defective.
Read more: http://www.appliancepartspros.com/repair-help/rangehood-repair-help.html#ixzz2aSy5FKwN
Jul 29, 2013 | Kitchen Ranges
The fan in my has not stopped working in a few weeks now.what can I do to make it stop blowing air
test this steps and fix it. God bless you
2. Fan switch
3. Fan motor
KWCU405SSS fan motor high speed only
Agreed! It totally works. Our fan and lights were stuck on high. Flipped the hood circuit breaker off for 30 seconds then back on again and all controls are working normally again. Thanks!
Jan 15, 2013 | KitchenAid Architect® II KWCU405SSS...
Range hood blower motor - rangemaster
I'm not sure if it a regular home range hood but if it is. Check the price of a new one. A regular home range hood cost around $100.00 and a fan motor runs around the same. If it a commercial type is another story. If commercial Heritage Food Service Equipment will have the motor.
Oct 01, 2009 | Kitchen Ranges
Nutone range hood fan motor quit
You can remove it and bench test it by applying 120 volts to the fan leads. Do you know how to do this -- it can be dangerous if not done properly.
You can also use a voltmeter to measure resistance and check continuity of the motor coils.
May 07, 2009 | Broan-NuTone Intermediate Whispaire ...
NEED NEW MOTOR FOR KICTHEN RANGE HOOD BLOWER
hey I am looking for the same thing I think I found one at emotorstore.com it's a cframe motor #k120
Feb 02, 2009 | Marley PJ1257 Heater
Fan Motor
They carry Nutone at Home Depot. If you have a HD near you go and pick one up. Good luck.
And please rate my answer. Thank you.
Feb 02, 2009 | Broan-NuTone L700L In-Line Exhaust Fan...
Range Hood Issue
Definetly need a new motor control.
Nov 26, 2008 | Kitchen Ranges
Broan-NuTone Intermediate Whispaire  WA6542SS Stainless Steel Kitchen Hood Logo
313 people viewed this question
Top Broan-NuTone Kitchen Ranges Experts
Dan Phillips
Level 1 Expert
Phil Lovisek
Phil Lovisek
Marvin
Marvin
Are you a Broan-NuTone Kitchen Range Expert? Answer questions, earn points and help others
