I have attached a hose to the dehumidifier for use while I am away for the next few days. If I remove the water collection bin the dehumidifier shuts off--if I replace the container the water goes in container rather than the hose. Sorry but I can not find my manual.
  • 69 Answers
Towards the back there is a switch. when u put the container in the switch is depressed. tape it closed with some black duct tape.
Posted on Aug 06, 2010
Why does Frigidaire dehumidifier send water outside bucket?
Good Afternoon Jean,
I understand that your Frigidaire dehumidifier, model# FAD704DWD, is putting the water that it collects out onto the floor as oppose to the bucket. I suggest contacting the manufacturer for more information. They should be able to point you in the right direction for assistance. Hope this is helpful.
-Best Regards-
WP
Jul 02, 2014 | Frigidaire FAD704DWD 70 Pint/Day Energy...
Dehumidifier lights up comes on will only run for a few minutes does not collect any water
You probably have it set for too high (moist) a setting, so it doesn't need to run long.
Slowly reduce setting to Drier settings to get it to run longer.
Sep 19, 2017 | Kenmore Dehumidifiers
How do I switch from continuous drain to draining into the bucket? I have a Danby Pro dehumidifier. Thanks Tyler
Disconnect the hose and reattach the hose connection drain cap, that was removed when the hose was attached. The water will then be diverted into the water collection bucket
Hope this helped you, Tyler and thanks for choosing FixYa.
Aug 01, 2011 | Danby DDR5009EE Dehumidifier
/my dehumidifier has a hose attachment on the back. how does that work?
The hose attachment is used in place of the water collection bucket, to drain the water directly into a floor drain or a sump pump holding tank. A garden hose is connected to the "hose attachment" and run to the floor drain or sump pump holding tank. However, it will not drain UP, only DOWN.
Hope this helped.
Mar 20, 2011 | Amana Dehumidifiers
My Danby Premiere DPAC 13009 is leaking water through the bottom. I have attached the continuous drainage hose, and no water is going through it. I tried to manually drain the tank using the drain at the...
Water is collected from cooling mode, not just dehumidifier mode. It does not always evaporate into the exhaust stream due to design limitations.
Of course the water should never leak even on the hottest day. Two suggestions:
Try removing the hose and attaching the external tank to see if it has any effect. Otherwise, you'll need to locate the exact source of the leak.
May 25, 2010 | Danby DPAC12031 Air Conditioner
Hoshizaki ice maker am-50bae . Made ice regularily--- filled ice bin half way...next day-- all ice melted away with no more new ice? next day shut off for 3 hours now o new ice.
make a few quick checks. If there are water filters on the system, be sure they are not restricked. Could be clogged. Next, check the bin stat. It usually is mounted in the ice bin. If it breaks or goes bad, it shuts down the machine. Start there and let me know if I can be of any further help.
May 19, 2010 | Hoshizaki Freezer Commercial Ice Machines...
Attached a pump to drain collected water. The
the water should still collect into the tank. the dehumidifier had a float switch that shut the unit off when the tank is full. In turn it should have a second switch, probably a float switch that turns the pump on and off so that the pump doesnt continue to run when there is no moisture in the tank
Nov 26, 2009 | Frigidaire FDL50R1 Dehumidifier
Problem
Is your pump hose connected tightly?
Jul 20, 2008 | DeLonghi DE500P Dehumidifier
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
