Question about Samsung Prostar DCS-24B-STD Corded Phone
While programming buttons on my phone, I want to program a DS extension on button 11. It shows on the display: 11:NONE , I tried the soft keys and the scroll but the curser will not move over to change the NONE to DS. Thank your for your help.
    Director Badge:
    Uploaded 100 video answers.
  • 213 Answers
I have uploaded a video which hopefully will help with your programmimg issue on your prostar DCS, ther are lots more on YouTube which relate to the prostar DCS search abbyetel, or visit www.abbeytelcom.com
Posted on Jan 06, 2011
I would like my phone to ring only when my extension is called.
Check you button programming by using Feature *0 and starting with the intercom button go up. If a button says "Answer xxxxxx", your phone is programmed to also answer that extension. This can be removed in programming by changing the Answer DN's down from Line Assignment. In this setting use the SCAN soft key to show the extensions assigned.
Mar 20, 2013 | NorStar T7316E Corded Phone
How do you allocate an action to a button on the keypad.
Hi to program your soft keys either follow the instruction or click on the link that I have posted, the video shows the newer handsets but these are very similar to your 12 button handset, ther are 60+ training clips at http://abbeytelecom.com
Press the transfer button followed by 200
Enter 1234
Press 1 to 'ENABLE'
Press the speaker key
Now press 722 followed by the extension number of the handset.
Type in the number of the button you wish to change.
If it is button 3 then type 03, if it is button 11 type 11 etc.
Once you have done this the cursor will move to the right hand side of the screen.
Next press the letter D on the keypad followed by plus on the volume until it says DS.
When it says DS press the 3rd grey key beneath the screen followed by the extension number. EG DS255.
Once you have done this press the 3rd grey key beneath the screen to save.
Mar 15, 2011 | Samsung Phone PDCSLCD12B
How do i reprogram my speeddial numbers on jazz 4400?
Hello.
From NorStar Support:
To Program Personal Speed Dial Numbers: (Numbers 71 - 94 only.
1. Press the Feature button, then * 4
2. Enter the 2 digit code (71 - 94). that you want to assign to that phone number
3. Enter the telephone number, then press the OK softkey
4. Display will show: "Entry xx stored"
If the above doesn't work, try:
  1. Press [Feature] [*] [4]
  2. Enter a two-digit code from 71 to 94.
  3. Specify the external line by pressing a line button, a line pool button, or the intercom button. If you don't specify the external line, the system automatically chooses a line for the call.
  4. Dial the telephone number you want to program (up to 24 digits).
  5. Press [Hold].
  6. Record the code and number you have just programmed.
Hope this helps.
Feb 02, 2011 | NorStar Jazz Plus 4400 Corded Phone
How to program a dss key on a samsung dcs 24B
The easiest way to show you how to program you dss key is to watch the video attached, you need to make this a DS key and then input the extension number or try the following
Transfer 200
1234
Speaker
MMC 722
Once in 722 type the extension number in the bracket at the top of the screen. The curser will then drop down to the button 1 key which will be call 1. Always keep the call 1/ 2 keys!!!
Press the button that you want to change and find the command on the relevant button.
Jan 18, 2011 | Samsung DCS 12 Corded Phone
How do I reprogram the phone to ring when a new call comes in, default to a certain line, and show caller id when a call comes in.
The answer to the Caller ID question:
Depend on the type of system that the phone is connected to. Late model Partner ACS equipment will display Caller ID info between the first and second rings, provided that the telephone line is plugged into a module that supports Caller ID.
The answers for the other 2 questions are taken directly out of the Partner ACS Programming Guide which is available for free download at Avaya's website.
Ther answer to the incoming call line ringing question:
Again, depends on the system. For the Partner ACS:
1) Press FEATURE 00 at extension 10 or 11.
2) Enter the number of the extension to be programmed for Line Ringing.
The green lights next to the line or pool buttons show the current Line Ringing settings for all
lines or pools assigned to the extension. (If a line or pool is not assigned to a button, the green
light next to that button is off.) The following ringing options can be shown by the green light
next to the line or pool button:
? Immediate Ring - on steady
? Delayed Ring - flashes slowly
? No Ring - flutters quickly
3) Press the line or pool button until the button light shows the correct setting (the setting for the
currently selected line or pool also appears on the display).
4) Continue programming, or exit programming mode.
Line selection:
For incoming calls, the line selection (hunt sequence) is set by the local service provider). For outgoing calls....again....it depends on the system. For the Partner ACS:
1) Press FEAURE 00, SYSTEM PROG, SYSTEM PROG, CENTRAL PROG at extension 10 or 11.
2) Enter the number of the extension to be programmed for Automatic Line Selection.
3) Press **.
4) Press the line, pool, or INTERCOM buttons in the desired order. The valid entries for Automatic
Line Selection
depend upon the type of extension:
? Key Extension: Outside system lines, Left Intercom (the factory setting)
? Pooled Extension: Pool 880 button 1, button 2, Left Intercom, Right Intercom (the factory
setting), Pools 881-883, individual lines
For each button pressed, a display similar to the following appears:
5) To exit Automatic Line Selection, press **.
6) Press CENTRAL PROG and enter a new extension number, or exit programming mode.
Changing line ringing and line selection are tasks that are normally reserved for the Administrator of the telephone system.
Jan 06, 2011 | Lucent 18D Corded Phone
Assign a new person to an extension
Changing the programming2.gif on a Partner system is done on either ext 10 or 11. At one of those ext's press the feature key and "00"
next press the left hand intercom twice
the display should say system programming
press the left hand intercom button
the display should say central telephone prog extension:
enter in the extension number of the persons phone you wish to rename
the display should say program extension xx
the display should say the extension number followed by the existing programmed name
enter in name of new person by pressing the number where the letter is then its order on the button so under the 2 button 1 would be A, 2 would be B, and 3 would be C ex. BILL = 22 - 43 - 53 - 53 use the mic/hfai button to erase entry.
either press the right hand intercom to go to the next extension or press feature 00 to exit
Oct 19, 2009 | Avaya Corded Phone avaparp18d
M7208 How do I programme the button for hands free
Programming is done on 7310, 7324 and 7316 type sets.Enter programming2.gif by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
The screen should say TERMINALS&SETS. The 4 top line/feature keys are now used for programming.
At the terminals&sets prompt, press the show key (top right arrow). The display should now ask for an extension number. Enter extension number you want to change to handsfree.
Press the show key (top right arrow)
The display should say LINE ACCESS
Press the next key (bottom right arrow) .
The display should say CAPABILITIES.
Press the show key (top right arrow) .
The display say foward no answer.
press the next key 3 times (bottom right arrow)..
The display should say handsfree. Press the show key.(top right arrow) change from none to auto
Press the release key when finished
Sep 01, 2009 | NorStar M7208 Corded Phone
How do I programme my buttons and how do set up the phone for hands free use. The phones were moved and the technician set all the phones to the original settings so none of the phones have hands free...
Programming2.gif is done on 7310, 7324 and 7316 type sets.Enter programming2.gif by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
Press the heading key (top left arrow) til the display says TERMINALS & SETS again.
enter in next extension to program.
repeat procedure.
Sep 01, 2009 | Nortel Meridian M7208 Corded Phone
Can't find code to add transfer to soft keys on prostar 816
Transfering on a Prostar 816 is done by using the DSS buttons on the right hand side of the phone. This is accomplished by having your outside call in progress and pressing the DSS button of the persons extension you wish to transfer it to. If you want to screen the call wait for the extension to answer otherwise hang up and the call will be transfered. Transfer keys were only placed on the 800 series sets and was a non movible button.
hope that helps
Jan 22, 2009 | Samsung Prostar 816 Phone
Programming DS extension
I am glad that you managed to sort your problem, I have posted a Video which you may find helpful in the future, Youtube has 60+ similar videos (search abbeytel), or visit www.abbeytelecom.com">
Jul 24, 2008 | Samsung Prostar DCS-24B-LCD Corded Phone
Samsung Prostar DCS-24B-STD Corded Phone Logo
131 people viewed this question
Top Samsung Lands Phones Experts
Don Hart
Jose Ma DM.
Jose Ma DM.
Brett Duxbury
Brett Duxbury
Are you a Samsung Lands Phone Expert? Answer questions, earn points and help others
