Question about Kohler Model 10430: Fort® Single-control Remote Valve Kitchen Sink Fauc...
My kohler k-r10430 drips when water flow has stopped.
    Scholar:
  • 122 Answers
Replace the cartridge, if your not which one, just take the old one with you to the plumbing supply house
Posted on Aug 06, 2010
I have a 2yr old Kohler K4634 toilet. After flushing the water level drops about 1 inch in the bowl after the bowl filled. This causes a lower level in the bowl than is recommended. The main issue
check to see if waster continues to run into the bowl after the plunger has returned to stop water flowing. If it is a slow leak then replace the flush washer on the stopper plunger.
Oct 01, 2014 | Kohler K-4634-RA-0 Cimarron Toilet Tank...
Why is my Uline ice maker filling with water not ice ?
At first I wanted to say it has to fill with water to make ice but I know you mean the ice bin is filling with water. You either have an issue with the water control valve leaking or your timer isn't working properly. Listen for the water to flow and when it seems to shut off look at the tray fill spout and see if it actually stopped dripping. If it continues to drip (not flow normally) then the valve is leaking. If it isn't dripping but the water in the ice tray over flowed, then the issue is either with the timer or the adjustment is incorrect.
Jun 04, 2014 | U-Line ULN Marine Series 12-lb Crescent...
I have a steam shower cubicle and when the water is switched off it still drips from the shower head,it only stops if I run the hot water tap in the sink
Most likely the issue is the unit is not isolating the water when turned off. Inside the shower valve will be an on off valve that will likely look like thus 06a0e29a-a81e-4b1d-b746-6d8bf0394774.jpg if you can locate one of these and replace your dripping will be resolved. Alternatively if this is only dripping from the larger monsoon in the roof, this can drip for a while after use as it holds a fair bit of water.
Can also try selecting one of the other features when not in use such as he back massage jets ( if you have a 3 dial valve) if it still drips then the problem will almost certainly be a replacement on/off valve
Steam Shower Parts Spares
Jan 04, 2014 | Kohler K-1698-G Brushed Chrome Tandem...
I have a new Kohler Toilet that has a different flushing system from other Toilets. It's about 1 year old now and I'm noticing a Drip noise on the 1st floor under this Toilet. It looks to me like the water...
Basically, if water is flowing out of the overflow tube, then water must be coming in...I would suggest that you check the intake valve, it is probably not shutting off completely when the float comes up to the prescribed level,and continues to leak some water into the tank. That is what the overflow tube is there for.
Mar 17, 2011 | Kohler Toilet - One Piece with Ingenium...
How do I adjust the pressure in a Kohler pressurized flush toilet
You cannot adjust the pressure on the toilet. But you can adjust the stop setting screw at the top of the float arm. If the water is coming in too fast you can adjust the valve where the toilet water line connects to the wall water supply. Closing the valve a little will slow down the flow of water and it will take a little longer to refill the toilet water tank.
Mar 06, 2011 | Kohler - Toilet - Two-piece - Highline -...
We just installed the Cimerron two piece. After flushing the toilet, it will not stop running. Water just goes into the over flow section.
  • The exact cause of a Kohler Cimarron toilet running non-stop depends on the exact model of toilet owned. In some, the lift chain connected to the handle can become kinked, preventing the ball seal from covering the drain completely. Just unkink the chain to fix this. In other cases, the float ball is stuck against the side of the tank, preventing it from returning to its normal horizontal position. When this happens, the toilet's tank doesn't stop filling with water. The excess continuously flows into the overflow pipe. Dislodge the float ball from the side of the toilet and this should clear the problem. Likewise, you might consider shortening the armature on which the float ball sits, so it won't become stuck again.
  • Read more: Troubleshooting a Kohler Cimarron Toilet ' eHow.com http://www.ehow.com/how-does_5017443_troubleshooting-kohler-cimarron-toilet.html#ixzz1CxKmz9ZQ
    Feb 04, 2011 | Home
    I have a single handle kohler bath tub faucet I am not getting any cold water out. i have taken this apart and found nothing that i can see that would impede the flow of water ?is the mixer valve at the...
    If the faucet was working before and then just stopped, it is the mixing valve or a clogged supply line.
    turn the water off and remove the mixing valve. Turn the water on and see if you have good flow from both hot and cold ports inside the faucet.
    Caution- this procedure can get messy, close the shower curtain or door.
    Call Kohler and ask for a new mixing valve for free.
    Sep 12, 2010 | Kohler Plumbing
    Lift up leaver and no water after 10 seconds
    The aireator is clogged with dibri. Thats the part right on the tip end of the faucet where the water comes out. It will look something like this.
    It will screw off, make sure you remember how it is assembled as you dissassemble the aerator to clean it. They typically consist of a few screens, a washer, and a plastic flow desperser.
    Oct 01, 2009 | Kohler K-12176-CP Fairfax Single Handle...
    How can be removed the bonet of de Kohler kitchen faucet model K-r10430
    try this if you need more help just ask... THX
    http://www.us.kohler.com/onlinecatalog/pdf/1011154_2.pdf. The bonnet is screwed on and this should give you what you need. If you have any trouble just ask.
    Jun 13, 2009 | Kohler K-15176-PT-7 Coralais...
    Kohler Model 10430: Fort® Single-control Remote Valve Kitchen Sink Fauc... Logo
    460 people viewed this question
    Top Kohler Plumbing Experts
    Mike
    Paul Carew
    Are you a Kohler Plumbing Expert? Answer questions, earn points and help others
