Question about Pioneer CDX-FM1279 12-Disc CD Changer
Pioneer CDX-fm1257 error 50 or 60 HELP cd charger not eject
  • 44 Answers
SOURCE: Ejecting magazine on Pioneer CDX-fm1257
I have very gently taken a pair of needle nose pliers and grasping the edge of the cartridge that holds the disk carefully work it back into the magazine.
Posted on Jan 09, 2008
  • 41 Answers
SOURCE: error 70 / 60 /50
Those errors mean that there is an electrical or mechanical system fault. The pioneer website suggests to turn the car ingition off and on again, or press the power ON/OFF button on the display unit and try to play the CD again.
That seems like the obvious solution to me, which Im sure you have already done. You can try to contact Pioneer for more info.
Posted on Dec 05, 2008
  • 18 Answers
SOURCE: error 10
no you need to take it to a technition it have to be open
Posted on Mar 02, 2009
smarthome2
  • 1114 Answers
SOURCE: Not working error 50 and 70
Clean the unit if possible. does the cartridge eject? if so, load it with a cd player cleaner, preferrably one that uses a cleaning solution. put it in tray slot 1. load and wait. try this a few times then try a good disc, one that is not scratched up. changers are hard on cd's. If it's still not working, below the cartridge slot there should be an inverted dimple that you can press with a ball point pen. This is a reset. It should have this button, I just can't remember the exact location if it's not right there. Hope this helps. If you have a spare cartridge try that as well, as they warp.
Posted on May 24, 2009
  • 4981 Answers
SOURCE: wire diagram for pioneer model cdx-fm1257
Can this website provide your answer?
http://www.tehnomagazin.com/Auto-radio-car-connector/PIONEER-Car-Radio-Wiring-Connector.htm
Posted on Oct 18, 2009
Turned on my Pioneer PD M501 one day and it would not play. Disc tray will not retract into cartridge and cartridge will not eject.
Sometimes the little ball bearings that keep the cart trays separated come out causing tray jams.
Make sure your tray retracts all the way into the player flush with the face plate, gently push it in while retracting for those occasional no-read situations. (Also for Denon that takes these same carts). Also note that the CDs go in the Upside Down position.
Applicable to:
Lexus Models: CDX-M9071zt CDX-M8036, CDX-M9071, CDX-M9741, CDX-M9751
also:
Philips CDC-875 Pioneer CDX-FM35 Pioneer CDX-FM45 Pioneer CDX-M30 Pioneer CDX-M40 Pioneer PD-DM802
* Pioneer PD-DM902 Pioneer PD-M403 Pioneer PD-M423 Pioneer PD-M426 Pioneer PD-M450 PD-M453 PD-M455
* Pioneer PD-M501 Pioneer PD-M502 PD-M503 Pioneer PD-M510 Pioneer PD-M530 Pioneer PD-M550 Pioneer PD-M552 Pioneer
* PD-M600 PD-M601 PD-M603 Pioneer PD-M610 Pioneer PD-M630 Pioneer PD-M650
* Pioneer PD-M701 Pioneer PD-M702 Pioneer PD-M703 Pioneer PD-M710 Pioneer PD-M730
* Pioneer PD-M801 Pioneer PD-TM1 Pioneer PD-TM2 Pioneer PD-TM3 Pioneer CCS-430
* DCM-444 and DCM 777
BMW 740 OEM and others.
Feb 18, 2010 | Pioneer PD-M603 6-Disc CD Changer
Can't remove cd cartridge because won't power up.
With the top off the unit, you can turn the tray gears manually for slow eject function. Unplug unit before touching anything inside, check internal fuses.
Sometimes the little ball bearings that keep the cart trays separated come out causing tray jams and shorts.
Make sure your tray retracts all the way into the player flush with the face plate when loading, gently push it in while retracting for those occasional no-read situations. (Also for Denon that takes these same carts). Also note that the CDs go in the Upside Down position.
Applicable to:
also:
Many Magnavox, Denon, JVC,
Dec 04, 2009 | Pioneer PD-M426 6-Disc CD Changer
Pioneer CDX-P670 Wiring / Power
hi according to the manual the two pin connector is for the power and the pin nearest the square control plug is ground, the other pin is +12, have tried this with mine and it works
Nov 26, 2009 | Pioneer CDX-P670 6-Disc CD Changer
Wire diagram for pioneer model cdx-fm1257 where does the square plug go?
Oct 18, 2009 | Pioneer Car Audio & Video
Pioneer cdx p1280 cd changer,the cd magazine will not eject.the power is all ok,tried the rest button bt still no go.
cd changer reqs a verygood 12v source,check for a good earth&check how many volts are going to changer with a good quality voltmeter,check at changer,not head unit
Jul 03, 2009 | Pioneer CDX-P670 6-Disc CD Changer
Error 10
Mar 02, 2009 | Pioneer CDX-P1230S CD Changer
My pioneer cd changer CDX-P1200 doesn't work?
Error 11 means the CD is in upside down, flip it over and it will work like a champ.
Jan 08, 2009 | Pioneer 12DISC CHANGER
Pioneer Car CD Changer CDX FM673 Error Message
can anyone tell me were to get a installation manaual for a pioneer cd changer (cdx-fm67)
Apr 04, 2008 | Pioneer CDX-FM673 6-Disc CD Changer
Nov 07, 2007 | Pioneer CDX-FM1279 12-Disc CD Changer
No power
You have 12 volts constant on the yellow and 12 volts Switched on the red (when the car is in Ignition/Accessory)? If so, then, yup.... service shop.
Aug 11, 2007 | Pioneer CDX-FM1277 12-Disc CD Changer
Pioneer CDX-FM1279 12-Disc CD Changer Logo
228 people viewed this question
Top Pioneer Car Audio & Video Experts
Marvin
Marvin
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
