Question about HP Compaq nx9010
I installed one gigabyte of memory to replace the virus-eaten original 512 that was currently on this laptop. I ran the OS and now this computer is working very well. The only problem with it is that the recovery software reconfigured the monitor, so now the main window is only displayed on about 60% of the full screen. Whole web pages can't be viewed without scrolling left and right. I haven't been able to figure out how to fix this. Thank you in advance.
  • luckymommy12 Aug 06, 2010
    Thanks for your help. I'd already tried to change the resolution on the desktop properties, but I can't take the gauge any lower than 800 x 600, which I think is the main problem.
  • 385 Answers
You will need to change the resolution of the desktop. Go into the settings of the desktop screen and find where you can adjust the resolution. The new memory probably changed the video settings back to default.
Simply change the resolution and it should fix it.
Thanks,
Lolita
Posted on Aug 05, 2010
  • Rona  Heredia
    Rona Heredia Aug 09, 2010
    I think the resolution should go higher, not lower.
    Try it and see if that helps.
    Problem Solver:
  • 11 Answers
Try right clicking the desktop then Select "Properties" / Display sould appear, go to setting tab. you may want to write down screen resolution setting as it is now. change as you see fit "more or less" hit ok. It should say your screen has been adjusted, do you wish to save these settings "yes or no" if you do nothing it will go back after 10 seconds. play with it until you get desired look..
I have changed ma OS to windows & as a result i do have ma system hagin frequently
can you explain little bit more details. Any way try this:
before installing a new OS, make sure you save your important files in external drive/memory
format your HDD it help to delete any virus or hidden program that cause problems.
Fresh install your OS (e.g. XP, Win7).
hope it will work. Bythe way make sure the OS you installing is compitable with your current PC/laptop hardware configaration.
Jul 06, 2011 | Computers & Internet
My laptop has been slammed by viruses & thinkpoint is the most recent incursion into my system. does rebooting or restoring programs with the original cd help "restore" the constitution of...
You can restore but cannot be certain when the virus was placed. But I recommend a full restore of the computer, you will need to transfer anything to a flash drive. You will need to install all the drivers as well when the computer finishes install the OS again but that is the easiest and cheapest way to go. The only bad thing is that it takes several hours to computer it all.
Jan 14, 2011 | Toshiba Satellite A45-S151 Notebook
I have 512 K memory chip ,can I add this to my travelmate 6492
I do not know your specific model of laptop, but if the above specifications are accurate, then most likely not. Most laptops have two DIMM ports, where you place the RAM. This laptop probably has two 1gigabyte pieces already installed. This means to add yours, you must remove one and replace it, thereby decreasing your RAM to 1.5gigabyte total. Now under the rare possibility that your computer has a single 2 gigabyte RAM installed, then yes you can really easily. Just open up the panel on the back with the RAM inside and check. If only one is installed, then install the other (you can use google search to find the exact process), and your computer will be ready to go. I hope this helps, -Robert
Aug 26, 2010 | Acer TravelMate TM5720-6337 NoteBook,...
Gigabyte GA-8VM800PMD-775 @ 1.5gb memory
This is the website link for your board on gigabyte website. http://www.gigabyte.com.tw/Products/Motherboard/Products_Spec.aspx?ClassValue=Motherboard&ProductID=2159&ProductName=GA-8VM800PMD-775 Suggest you have a faulty piece of ram or a clock speed miss-match. your board supports up to 2gb of memory.Try also reseating the memory. Let me know how you get on? chris http://www.motherboardsrus.net
Jun 06, 2009 | Gigabyte GA-8VM800PMD-775 Motherboard
The memory I install to Armada wont boot
Check the specs of the computer. The model you has two memory slots. One on the bottom of the notebook. One under the keyboard. Each equal 64 mb thus 128 mb. You need to replace both with sdram 256 mb sticks not one 512.
Mar 11, 2009 | Compaq Armada E500 Notebook
Toshiba Satellite Pro M15-S405 Memory upgrade problem
This usually happens when the laptop is not able to take more then a certain amount of memory, as the system BIOS does not support higher. By saying ACPI as the blue screen, that tells me that the power subsystem does not 'like' having more then 512MB of RAM. I am 95% sure this is your BIOS because of that information. Check and see if you can find a BIOS upgrade for your computer model, and that might fix the issue, if an update is available.
Jan 21, 2009 | Toshiba Satellite Pro M15-S405 Notebook
During installation, windows XP only recognizes 131062 mb of my 320 gb hard drive
This is because "the original ATA specification used a 28-bit addressing mode, allowing for the addressing of 228 (268,435,456) sectors (blocks) of 512 bytes each, resulting in a maximum capacity of about 137 gigabytes" (wikipedia). To fix this try upgrading your computer's bios and enabling any bios entries for larger disks. Also make sure that you are running your operating system with all of the current updates.
Nov 21, 2008 | Computers & Internet
How Can I Speed Up My Slow PC?
Go to Trend Micro and run Housecall to check your PC for viruses and spyware.
If it is still slow go to Start and click on My Computer. Right click on your C: drive and choose Properties. Run the Disk Cleanup. When that finishes click on the Tools tab and do a Check Disk and Disk Defrag.
Jun 07, 2008 | Foxconn P4M800P7MA-RS2 Motherboard
Hp Pavillion laptop freezes when I install secondary memory
You may not put all together the 256 and 512, the system encountered error when two memory are not equal size and not equal brand.
Either you select 2 units 256 memory or either 2 units 512. or use only 1 unit 512 memory so that no freezes will happen.
Jan 17, 2008 | HP Pavilion dv6000z Notebook
Two problems:1) Audio2) Freezing when running AMD Overdrive
format your hdd fat32 with xp geneuin. then setup motherboard driver...
Jan 08, 2008 | Gigabyte GA-K8N51GMF Motherboard
HP Compaq nx9010 Logo
56 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
