Question about Photography
The Elmo 912 Dual 8 Editor is displaying the image out of frame how do I adjust that and is the some special attachment that is meant to be attached to the frame where there is an obvious place something should be attached?
  • c_jrsanders Aug 12, 2010
    my elmo 912 d 8mm editor is not one of the old 8mm only types, what is the "clip" attached to the frame just above the film exit of the viewing space? Also is there a way to frame the image when it is split about 25% below the top so you see the end of one frame and the top of the next?
    No comments back on the viewing framing issue but perhaps it is just and issue on how the film is tracking on the sprocket. The answer on the shoe purpose is helpful, I was wondering if it was a place to hold a spare sprocket, ie one for regular 8 and another for super 8, I only have the one.
  • 3,083 Answers
On the old 8 mm units, there is a frame sync adjustment- it's usually a round knob, so that's what you should probably look for, unless they have another type of system on this one.
As far as the attachment, go to this web page and read about the Elmo Sound Editor- sounds like that might what goes there.
Good luck, thanks for using FixYa, and hope this helps!
Posted on Aug 05, 2010
  • c_jrsanders Aug 11, 2010
    IT IS A 912 DUAL 8 NOT JUST AN 8MM, AND YOU REFERRED TO "GO TO THIS WEB PAGE" WHAT WEB PAGE?
  • Tom Carson
    Tom Carson Aug 12, 2010
    I found this about the shoe feature, from a unit on Ebay:
    provision of the accessory shoe permits easy installation of a number of editing accesories such as sound monitor, film cleaner and film counter, etc
  • 12,061 Answers
Http://www.super8stuff.com/manuals.html
I have at least found a manual for you, that should be handy.
http://www.cameraweb.com/manuals.htm
Above this site says it has a repair manual
Below is a Forum, where you can ask other people that actually have these items for help.
http://8mmforum.film-tech.com/cgi-bin/ubb/ultimatebb.cgi?ubb=get_topic;f=1;t=004892
sorry i couldn't be more help.... But I hope all info is in the manual.
Posted on Aug 12, 2010
How do I screenshot with my netbook device?
Assuming the netbook keyboards are similar, there should be a key labelled PrtSc near the upper right corner of the keyboard (see attached pics). Pressing the shift key and this one will save the screen image to the clipboard. Open a photo editor or document editor capable of displaying images (e.g. MS Word, OpenOffice Writer) and paste (Ctrl-V). If the PrtSc on the key is printed in blue, press the Fn key (located near the lower left on the keyboard) rather than the shift key.
Nov 02, 2015 | Computers & Internet
Can I still buy a new 150watt bulb for an old Elmo Slide Projector CV and CS
never tried them personally but you could try
http://www.bulb-source.com
Jan 23, 2013 | Elmo Projectors Office Equipment &...
Ink cartridges will not move in place error # 1200
Lexmark X4270 Error 1200 Fix - Click here for document link
1. Unplug printer from wall and remove power supply.
2. Unplug any phone lines or USB cords connected.
3. Remove printer attachments, paper trays and phone.
Figure 1 - Printer paper holder and completed print tray
4. Lift the front cover of the printer and remove the white rubber bar by pulling the blue lever on right towards you.
Figure 2 - Top view of printer showing the white rubber feed bar with purple attachment
5. Remove the screws underneath the front cover (6 screws), back of printer (2 screws), and bottom of printer (1). View the images below to find where to remove the screws.
Figure 3 - Top view of printer showing which screws to remove.
5. Cont...
Figure 5 - Bottom view of printer. Image on left is cover to screw. Gently remove ribbon cable to reveal the gold screw beneath
6. Flip the front cover open and gently lift the top of the printer cover. Keep front cover open.
7. Remove the ink cartridges out of their carriage.
Figure 6 - Displays ink cartridge carriage with ink cartridges removed.
Caution: Electrical hazard. Keep hand and metal pieces clear of board or any other electrical wires or parts.
NOTICE: The ink cartridges are all the way to one end. If the X4270 is plugged in, the cartridge carrier is stuck and doesn't move. After further investigation a noticeable small black plastic lever is preventing the ink cartridges from moving. Photo below shows lever up and down (cartridges already moved in image below).
Figure 7 - Shows inside of X4270 and the lever that causes error #1200. Image on left displays lever up. Image on right displays lever down.
8. Push lever down clockwise so it is flush with plastic wall. Refer to image on right in Figure 6.
9. Lift the front cover open (if not already open) and plug in the X4270. Cartridges should move to center as if preparing for replacement.
10. Unplug the X4270 and remove power supply.
11. Remove bottom assembly carefully.
Figure 8 - Displays bottom assembly with lever and spring
Note: The cause of this problem is the spring slides out of place over time, probably because of ink shed on one end of its loop and loop attachment.
Figure 9 - Displays loop attachment
12. Place spring in loop attachment and use hot tip of heated tool to melt top of loop attachment to prevent further errors. Melt top of loop attachment similar of that to a mushroom top.
Figure 10 - Displays fix for jammed carriage.
13. Reattach the lever to the bottom assembly and slide back into place inside the X4270.
14. Plug in and check if operational.
15. Reassemble X4270 using steps 3-7.
Jan 31, 2011 | Lexmark X4270 All-In-One InkJet Printer
How do I set up my Elmo to a data projector & a laptop? Specifically, Where do I put the RGB cords - what get's hooked up to what? Thanks!
I am going to bet you got a manual with the TT-02rx that explains the connectivity. If not, you can go to www.elmousa.com and download the manual from the TT-02rx page. Look on page 30.
TT-02rx can be connected in a couple of ways:
1. Directly to Projector - connect a standard VGA cable from the RGB output on the TT-02rx to a RGB (VGA) input on your projector. This will allow you to directly display anything you put under the Elmo camera.
2. USB to laptop, VGA from laptop to your projector. You can connect a standard USB cable from the Elmo to an open USB port on your laptop. From the laptop, you will need to connect VGA cable from output jack to projector input. To view images from the Elmo, you need to have installed the Imagemate software on your laptop first. Elmo can only be viewed thru the software interface.
3. The last option is run VGA from your laptop to VGA input on the Elmo. Then run VGA from Elmo to your projector. This offers the greatest amount of versatility as you can switch between the image on your computer screen and the image on the doc camera. Adding the USB cable as described in 2 above will also allow you to use the digital features such as image capture, reveal, spotlight, etc.
Dec 09, 2010 | Elmo Projectors ELMO TT02RX DIGITAL...
It wont print and everytime i try to print it says error #1200
Figure 2 – Top view of printer showing the white rubber feed bar with purple attachment
5. Cont…
Figure 5 - Bottom view of printer. Image on left is cover to screw. Gently remove ribbon cable2_bing.gif to reveal the gold screw beneath
7. Remove the ink cartridges2_bing.gif out of their carriage.
Figure 6 - Displays ink cartridge2_bing.gif carriage with ink cartridges removed.
NOTICE: The ink cartridges are all the way to one end. If the X4270 is plugged in, the cartridge carrier is stuck and doesn’t move. After further investigation a noticeable small black plastic lever is preventing the ink cartridges from moving. Photo below shows lever up and down (cartridges already moved in image below).
9. Lift the front cover open (if not already open) and plug in2_bing.gif the X4270. Cartridges should move to center as if preparing for replacement.
Click Here for the Documents
May 03, 2010 | Lexmark X4270 All-In-One InkJet Printer
How can i adjust the scanner to scan DARKER?
From the scanner menu in the “Advanced mode settings”, you can find the buttons for color settings.
Using Color Settings buttons, you can adjust the brightness and contrast of the whole image, specify highlights and shadows, and adjust the contrast and balance in an image.
Favorite Settings enables you to save a set of settings (Input Settings, Output Settings, Image Settings, Color Settings and Preferences) made for the focal cropping frame. If there are no cropping frames, settings for the whole preview area are saved.
You can also recall the saved settings and apply them to the selected frames or the whole preview area.
And you can adjust the scanner to scan darker.
Please find the explanation pictures attached.
Hope this helps.
If you would like to vote for the answer, this will help the others to see the similar problems solved and also will be a satisfaction factor for me to continue helping you.
All the best.
Mar 26, 2010 | Canon ImageCLASS MF4370dn Laser All-in-One...
I get a 1200 error when trying to fax
5. Remove the screws underneath the front cover (6 screws), back ofprinter (2 screws), and bottom of printer (1). View the images below tofind where to remove the screws.
5. Cont…
NOTICE: The ink cartridges are all the way to one end. If the X4270 isplugged in, the cartridge carrier is stuck and doesn’t move. Afterfurther investigation a noticeable small black plastic lever ispreventing the ink cartridges from moving. Photo below shows lever upand down (cartridges already moved in image below).
Figure 7 - Shows inside of X4270 and the lever that causes error #1200.Image on left displays lever up. Image on right displays lever down.
9. Lift the front cover open (if not already open) and plug in theX4270. Cartridges should move to center as if preparing for replacement.
Note: The cause of this problem is the spring slides out of place overtime, probably because of ink shed on one end of its loop and loopattachment.
12. Place spring in loop attachment and use hot tip of heated toolto melt top of loop attachment to prevent further errors. Melt top ofloop attachment similar of that to a mushroom top.
Feb 16, 2010 | Lexmark X4270 All-In-One InkJet Printer
When the frame is in the 4 wheel position but without the bassinet or seat frame is the frame meant to lock? currently the front wheels will retract as the it feels as if it hasnt locked into the centr...
Hi, i'm sure you have already figured this out but the frame will not lock into postiton until the carrycot or seat unit is attached to the frame. Once this is attahced the frame should lock.
Nov 11, 2009 | Bugaboo Cameleon Jogger
How to work a atlas warner super 8 film editer model 500
My Atlas warner dual 8 editor is mot showing pictures. Everything is there, light, mirrors, magnify. all in place, still no light on screen. Please help. Sincerely. H. Amit
Apr 26, 2009 | Kano Technologies Atlas (K752HCDR) DVD+R...
Evere 6th or 8th frame james very frustad
I have a slide jaming problem and got this from ELMO support. I have not tried it as yet. I am using 80 slide carousels.
If the unit is jamming like the way you described it may be that the arm needs to be adjusted. If you hold down the SELECT button and turn off the unit while still holding for about 20 seconds at the same time as holding up the arm, you will be able to get to a screw that can adjust the height of the arm.
Dec 20, 2008 | Elmo Projectors TRV-35H Slide Projector
Photography Logo
835 people viewed this question
Top Photography Experts
pontelemon
pontelemon
TC CAMERA REPAIR.Com...
Are you a Photography Expert? Answer questions, earn points and help others
