Question about Yamaha HTR-5650 Receiver
Hooked up to 4 speakers for 3 years. Played great. Recently kept shutting down 5 minutes in and had CHECK SPEAKER WIRES alert. Changed all speaker wires. NO it wont turn on at all. Makes audible click and the lights go dim for a second but wont turn on. Junk it or fix it???
  • Sarge54 May 06, 2008
    Similar problem... Shuts off while watching a DVD when there is a loud soundtrack (action type movie with explosions etc.) and says "Check SP Wires".
  • intdevco Aug 25, 2008
    Press the Standby/On button but it does not turn on at all.
    The speakers are connected but the RECEIVER WILL NOT TURN ON anyway.
    Any intelligent suggestions?
    Thank you!
  • 88 Answers
First you have to test separatly your speakers outputs
disconnect all wires speaker and speakers, turn on your reciever and look if you still have the same problem «CHECK SPEAKER WIRES alert» if yes you have to go to a specialist to fix it... if no test one line after one line with and without speaker connected until the problem reappear to locate the bad line or bad speaker.
Posted on Apr 26, 2008
Pioneer SX-315 Speaker Problem
The bump may have broken or disconnected speaker wires.
May 17, 2017 | Pioneer SX-315
I have a sony amp model str de475 - one speaker (rf) crackles when its turn pass 3 on the volume scale
The problem is in the audio driver and audio output stages, check speaker wires for shorts, if okay! you will need a technician because of the complexity involved.
Mar 21, 2012 | Sony STR-DE475 Receiver
I installed the pioneer DEH-1300MP in my 1991 f150, works great for about 10 mins then slowly loses sound, I turn it off for a minute and it works fine for 5 minutes.. it doesn't stay on all the time....
You may have a bad speaker. Are you using the stock speakers or aftermarket speakers? If you can, check the resistance of the speakers, they should be around 4 ohms or so. If they are less than 3, they are probably bad, You may also have a bad output Ic.
Jun 23, 2011 | Pioneer Car Audio & Video
I have a TRC 502A CB radio that hasn't been used in about 5 yrs. I recently tried to use it and when I transmitted, the audio came thru the speaker. Any idea what's wrong?
it could be grounded inside...Somebody may had it set for Talkback features.. Take it apart look for speaker wires (see if soldered to resistors) if its shorted seperate wires ..just have speakers wires attached. Try external SPKR. Try different mics or radio may have gone bad completely.
Apr 07, 2011 | Radio Shack TRC-503 CB Radio
Why have the speakers stopped working on my stereo. they were working fine until i had to brake sharply then thet all went off together. the stereo is only a month old & is still connected at rear...
Hello.. I am sorry to hear you are having a problem. If you have had your speakers changed out recently, it could be that one of the speaker wires or terminals are touching a metal part of the car. What happens is the aftermarket stereo detects this problem and it shuts down all of the outputs to keep from burning up. So all of your speakers going out is a good thing because your stereo protection is working as it should. You can cut all of the speaker wires loose behind the radio and hook them back up one at a time and when the radio cuts off, that will be the bad line. I am assuming of course that you dont have them hooked to an aftermarket amplifier. Even if you have not changed your speakers, it is still a protection circuit that will detect a bad speaker as well. Sudden jolts, braking, etc. can cause a bad speaker to fault. Hope this helped!! Good luck with your venture!
20 year car audio/video installer
Bay manager
Mar 14, 2011 | Car Audio & Video
My Onkyo 808 shuts down when i raise the volume, and when I try to set it up using the micophone.
Amps shut down in most cases because the receiver is detecting and impedance (below 4 ohms) that might damage the amplifier. Do a quick check of the speaker connection and look for wires that might be shorted to the frame or have crossed each other. This is the most common cause of the unit shutting down. Check your speakers impedance if you have a meter. If you don't then unplug power from the unit and then un-hook all speaker wires from the receiver. Next connect just one speaker (Front Left) and power the unit back on and take the volume up. If it shuts down then try the Front right all by itself, bring the volume up again. If the unit seems ok then add one speaker at a time and test. Continue until you find the bad speaker/cable. Your amp should be able to drive speakers down to 4 ohms. The NR808 has power monitoring (sometimes called crowbar) that looks for to much current and then shuts down. I suspect you may have a short in a cable or in a speaker. The 808 is a great amp and hopefully your problem is external. If your amp continues to shut down even with just one speaker connected then one or more of your channel amps (internal) is likley bad causing the unit to shut down. Good Luck.
Dec 09, 2010 | Onkyo TXNR808 Receiver
Jensen vm9411 has no sound from radio hookups put rca wires have sound
If the previous radio played all the speakers and the new one wont either:
1. You have not hooked the speakers up right.
2. All your speakers are blown.
3. There is a factory amp, you just don't know about it.
4. The radio has blown final outputs.
5. One or more speakers or speaker wires is seeing a ground (shorted out)
First check the radio, hook up a know good test speaker directly to the speaker outputs on the radio. If it works, then take a 9volt battery and try to pop the inside speakers with it. When you touch the + & - speaker wires to the battery + &- you should hear a pop at the speaker. If you do you don't have an amp. If you don't you might have an amp or the wire going to the speaker is dead or shorted out. It is unlikely that all four speakers would be bad or have bad wires. If none of them will pop you need to turn on the factory amp. Then they will play. If only one speaker wont pop then that is the bad speaker. If they all pop then you have a bad speaker or wire.
Dec 18, 2008 | Car Audio & Video
The Kenwood VR517 home theater system wants to just turn itself off at about 5 minutes of being on. this just started happening this week.
If this unit stays on for 5 minutes, and it appears to be playing normal, a bad speaker could be the cause unless you are using speakers that are not compatible with this unit.
The specs on this unit are 100 watts per channel and require 8 ohm speakers. if you are using speakers that are 6 ohms or 4 ohms, you will overheat the unit quickly and it will shut down. It is not designed to use anything less than 4 ohm speakers.
If you are using the speakers this unit came with, or you know that the speakers are 8 ohms (it should be listed on the speaker where the wires plug in), go ahead to the next step.
The first thing to do is to unplug one speaker, it does not matter which one, just pick one to unplug from the back of the receiver or right at the speaker. If you unplug one right at the speaker, make sure that the speaker wires do not touch together or touch anything else, they must be insulated from anything metal or conductive.
After one speaker is unplugged, turn the unit back on and let it play normally the way it was when it shut down after five minutes. If the unit continues to play for a long time, at least 30 minutes or more and does not shut down on its own, you have just found the culprit causing your problem. Some speakers may sound like they are OK, but still can cause a problem.
If the unit shuts down again after five minutes like before, go ahead and plug that speaker back in and do the same thing with one of the other speakers.
Continue this process until you have isolated one speaker as being the problem.
If you go thru the entire process and it still shuts down, you may have an internal amplifier problem. It can be something as simple as some heat stressed solder joints that need to be reflowed, or it could be a bad amp IC. This unit uses 3 different amp IC's and it could be any one of them or a component in the amp circuit. Sometimes it can even be a power supply failure. In any case, if the above steps do not work, you need to take it in and be serviced. There are no other end user options to perform.
I hope this helps with your problem, if you need more help just ask.
Jun 21, 2008 | Audio Players & Recorders
Pioneer posted this on it's Canadian Web Site:
Poor wiring connections, bad wires or a bad speaker may cause this. As you increase the volume, you will increase the amount of current you are drawing from the receiver. To troubleshoot this issue, try the following:
  1. Disconnect each speaker wire connection. Inspect for any frayed or damaged wiring and replace it.
  2. Check the impedance of the speakers; make sure they are properly rated for your stereo. In most cases, they need to be 8 ohms. Only a few Pioneer receivers will support lower impedance.
  3. If the problem still continues, try these steps:
    1. Turn the receiver off.
    2. Remove one speaker.
    3. Turn the receiver on.
    4. Increase the volume.
If the receiver overloads, repeat steps 1-4 (selecting a different speaker each time). If you disconnect a certain speaker and the receiver no longer overloads, have this speaker checked at a service center. It could have a bad speaker component, like a tweeter, sub-woofer, or even a bad crossover.
Dec 08, 2007 | Pioneer VSX-D514 Receiver
Immediate shut
Unplug all the speaker wires first, then unplug the unit from the wall for at least 24 hours, The plug back in without the speaker wires or anything else plugged in. Then see if it goes to the protection mode. If it does not, plug in each speaker at a time, and see if any speaker, when hooked up, makes the receiver shut down. If it does shut down, My friend, I'm afraid you will need to take this unit into a repair shop, OR get a new unit. Good Luck
Jun 06, 2007 | Yamaha RX-V630 Receiver
Yamaha HTR-5650 Receiver Logo
310 people viewed this question
Top Yamaha Audio Players & Recorders Experts
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
