Question about Hot Wheels Toys
I bought a hot wheels color shifter to my son today...how do I return to the original colors?
    Sniper:
  • 123 Answers
They change by temperature. Cold should make it the original color and warm will shift it to a different color
Posted on Aug 06, 2010
Optoma HD80 flashing blue lights
Sound like the original color wheel for Optoma HD80 is bad.
If the unit has been moved when hot.
If not, try un-plugging the unit for a few minutes and re-connect.
Hope this helps
Mar 23, 2014 | Optoma HD80 Projector
Color wheel flashes multiple colors after operating fine for about 7 minutes. Shuts down on it's own and temp/power light blink amber. No heat exhausting from fan. Problem persists.
hi,
You have to check the color wheel of your projector. Every dlp projector have color wheels to provide color. if the rotation of the color wheel is not in corrct RPM this will happen. Also you have to check the color wheel RPM counter sensor. There will be a sensor near the color wheel To count the rotation of the color wheel. First of all you have to remove these two items carefully and clean it well.Then refix it and check. Added the picture of color wheel for your refference.
ok
Jul 27, 2011 | Dell 1409X DLP Projector
I bought a replacement oxygen sensor providing instructions for new part wire color connections. The old and original part bring different color of wires. What should I do?
Return the Sensor
You want an OEM replacement
that is exactly like your old one
Screw it in Tighten a little
and plug in wire connector
Mar 16, 2011 | Chrysler Pacifica Cars & Trucks
My hot wheels car wouldnt change into green colour
Thank you for your question. I hope this helps solve the problem you are having with your Hot Wheels Color Shifter not changing colors.
I believe your issue may stem from the temperature of the water you are using. You will need two bowls of water - one with ice cold water and the other with hot water. Dipping your car into the ice cold water should change your car into the green color you are looking for. Dipping your car into the hot water will change it back into its original color. Here is a link to a youtube video demontrating this process - http://www.youtube.com/watch?v=2gZf7BKtInU&feature=related.
If this does not help, I would suggest you return it and get a new one. It may be defective.
Good Luck with your color shifter and have fun!
Jan 22, 2011 | Hot Wheels Toys
I need info. on what color wire provides voltage to the brake lights on a 1997 Dodge Caravan. Thank you, Dale
It will be a black wire on the back of the foot pedal, there will be three wires on the switch one will be hot oon the other side it will have the return and it will have the return to unlock trasmisson shifter and another to the brake lights.
Jul 04, 2010 | 1997 Dodge Caravan
My Sharp 65DR650 went out today, the screen got pixelated. Turned it off and back on, now Red is the main color, everything is a shade of red, tryied different inputs HDMI, COMP 1-2 and AVI all are red. I...
That humming noise was your color wheel going bad. It is part of the optical engine. I am not sure if you can replace it separately. In any case this is complicated and expensive repair.
Mar 10, 2010 | Sharp 65DR650 65" Rear Projection...
I just bought Sony Bravia flat screen television set today. The images on the screen are 90% greenish in color. How do I set it right to the right human color ? Please help ASAP or I will return the TV set...
go into menu, look for picture or setup mode. in setup look for chroma/color & tint/tone controls. you should be able to adjust to personal preferences. one other setting, is the color temp setting. this will allow you to change to warmer back wash. hope this helps because the Bravia is a good set
Sep 14, 2009 | Sony BRAVIA KDL52XBR2 Television
Screen shows only black and white
Color wheels do go bad quite frequently, if you got 5 years out of the original, believe me, that's good.
The color wheel is attached be a bearing, like a fan and when the bearing starts to ware out the color wheel on the shaft starts to wobble and that's what you hear, they spin I believe around 3000rpm. Try contacting your servicer again, don't be mad, maybe he'll be kind enough just to charge you for the color wheel. I'm sorry, but that's the best advice I can give you..Good Luck...
Feb 17, 2009 | Samsung HLN507 50" Rear Projection...
Toys Logo
98 people viewed this question
Top Hot Wheels Toys Experts
Marvin
Marvin
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Hot Wheels Toy Expert? Answer questions, earn points and help others
